Can you change the Foobar default folder?
Tiger-Heli
post Dec 10 2012, 13:26
I'm kind of a long time casual FooBar 2000 User.
I'm still using FooBar2000 0.9.4.3, but I didn't see a way to do this in Foobar 1.1.8 either - but it seems like it should be simple enough.
I only use FooBar for converting files, but it's a great program.
Anyway - when I launch FB and select Add Directory, it points to G:\My Documents (I think). I want it to point to something like G:\Data\Music\Temp\New\ (and then I can drill down from there).
I tried typing that in manually, but it didn't work the next time I opened FB.
FB will typically open to the last folder I selected, but I typically move the files so that folder no longer exists.
Thanks in advance!!!
Dynamic
post Dec 10 2012, 17:57
Ctrl-P (or File/Preferences)
Look under Media Library and note the Add button.
Is that what you're after?
Tiger-Heli
post Dec 10 2012, 18:23
QUOTE (Dynamic @ Dec 10 2012, 12:57) *
No, that doesn't seem to do what I want. It's mostly my own fault with my file structure.
Here's an example:
I open Foobar - no files are selected. Let's say I want to convert the music files in G:\data\music\temp\new\someartist-somealbum.
I select "File - Add Folder" and it comes up at "My Documents", so I have to drill up to "Computer", then down to G:\, down to Data, etc.
If I left the folder, Foobar would start at G:\data\music\temp\new\someartist-somealbum, but I usually re-name or delete that folder when I am done, so I have to start over again.
What I want is for FB to start at G:\data\music\temp\new\ - which will always be there and then I just have to drill down to subfolders of that folder.
Tiger-Heli
post Dec 10 2012, 19:41
I figured out two workarounds that will get me where I want to be. Not what I was planning, but ...
Instead of selecting "Add Folder" from the menu, I can simply drop the folder I want to add from explorer.
And instead of using "Convert To" and specifying a destinatation folder, I think I can specify an default "Output" folder and then move the files to my desired folder after the conversion.
Tiger-Heli
post Dec 11 2012, 12:56
It pretty much works - I had to use 1.1.8 b/c 0.9.4 did not have an explicit option to save to a specified folder.
One thing - under MP3 (LAME) - 0.9.4 had an option for fast mode (--vbr-new). I didn't see this in 1.1.8 and it seemed much slower - is there any way to enable it?
Not a big deal if you can't.
RSS Lo-Fi Version Time is now: 7th May 2015 - 02:05
