lame3100g, a functional extension
halb27
post Dec 9 2012, 21:33
I know, alpha versions can't be recommended, but due to the very promising experiences with 3.100a2 so far I couldn't resist porting 3995f to this 3100g variant of 3.100 alpha2.
I personally don't care too much about the alpha state and will use 3100g for several CDs I have to encode. I want to share this version so everybody can try. You can download lame3100g from here.
Whatís the functional extension?
It offers additional VBR quality settings -V5+ to -V0+ which cover the average bitrate range from ~176 to ~300 kbps.
What is it good for?
Lameís moderate VBR quality settings like -V5 or -V4 usually yield a very good quality. Thatís why many users are happy with these settings. Sometimes however tracks contain spots which are not encoded well. Many users want a better quality also for these rather rare events. From current experience Lame3.100 alpha2 seems to scale well quality of tonal problems with -Vn level, but temporal resolution can still be an issue.
-Vn+ uses -Vn as the encoding basis, but adds a certain amount of brute-force safety by forcing audio data bitrate to a target bitrate which depends on -Vn+ level. Moreover care is taken to always provide maximum possible audio data space for the encoding of short blocks which are used when the encoder thinks it is appropriate for a good temporal resolution.
Emphasis is on issues with temporal resolution, but tonal problems are tackled as well.
In a sense -Vn+ combines the quality advantages of both VBR and CBR.
Recommendations
Users who donít like rather obvious issues in their music even when theyíre rare but who also care about filesize are best to choose from -V5+ to -V2+ according to their needs.
Average bitrate for pop music goes from ~176 kbps (-V5+) to ~224 kbps (-V2+) in steps of 16 kbps.
Best care of temporal resolution is taken even with -V5+. For a significant potential for improving tonal issues -V3+ (~208 kbps) or better is recommended.
Users who donít care much about filesize but much more about universal top quality are best served by using -V1+ (~256 kbps) or V0+ (~300 kbps), or anything in between.
Installation
lame3100g.exe was compiled with Visual C++ 2010. For this reason it is necessary to install the Microsoft Visual C++ 2010 Redistributable Package vcredist_x86.exe. You can download it from http://www.microsoft.com/en-us/download/details.aspx?id=8328
lame3100g.exe uses the fast and lossless mp3packer tool internally to squeeze the otherwise unused bits out of the mp3 file. You can download mp3packer from http://www.hydrogenaudio.org/forums/index....st&p=282289. Put mp3packer.exe into the same folder where lame3100g.exe is located. Many thanks to Omion for this great tool.
In case there is no mp3packer.exe in lame3100g.exeís folder lame3100g.exe will work, but the mp3 files will be somewhat larger than necessary.
IgorC
post Dec 16 2012, 22:58
Well, I can do some blind tests and see how it works out. Seems reasonable.
I also have noticed some different behavior of 3.99.5/3.100. It tries to preserves up to 17 kHz at 130-135 kbps (V5). unsure.gif
I like more Helix (16kHz) and 3.98.4 V 5.7 (15.8 kHz) at 130 kbps. Even state of art AAC encoders have lowpass at 15.7-15.8 kHz at 96-100 kbps and they are at least as good as MP3 encoders at 130-135 kbps.
It's very likely that 15.8-16 kHz is the most appropriate for MP3 encoders at 130-135 kbps.
It's worth to try.
Sorry, I wanted to talk more but must go and will be busy but later this week I will be glad to help and test your extension.
http://listening-test.coresv.net/results.htm
halb27
post Dec 16 2012, 23:17
QUOTE (IgorC @ Dec 16 2012, 22:58) *
... It's very likely that 15.8-16 kHz is the most appropriate for MP3 encoders at 130-135 kbps. ...
I'm of the same opinion. As I'm modifying lowpass behavior with the highest quality settings I think I should change it with lower settings, too. Default lowpass, of course, so that everybody can override it according to personal needs.
This post has been edited by halb27: Dec 16 2012, 23:19
- halb27   lame3100g, a functional extension   Dec 9 2012, 21:33
- - BFG   QUOTE (halb27 @ Dec 9 2012, 14:33) I know...   Dec 10 2012, 00:02
|- - halb27   QUOTE (BFG @ Dec 10 2012, 00:02) Have the...   Dec 10 2012, 00:19
- - Kamedo2   I'm considering an ABC/HR test of your extensi...   Dec 15 2012, 20:24
|- - BFG   QUOTE (Kamedo2 @ Dec 15 2012, 13:24) And ...   Dec 15 2012, 23:13
|- - halb27   QUOTE (BFG @ Dec 15 2012, 23:13) ...Perha...   Dec 15 2012, 23:29
|- - BFG   QUOTE (halb27 @ Dec 15 2012, 16:29) I tri...   Dec 16 2012, 00:26
||- - BFG   Halb, I have ripped and encoded around 25 of my CD...   Dec 16 2012, 03:41
|- - Kamedo2   QUOTE (halb27 @ Dec 16 2012, 07:29) QUOTE...   Dec 16 2012, 14:28
|- - halb27   QUOTE (Kamedo2 @ Dec 16 2012, 14:28) Is i...   Dec 16 2012, 21:13
|- - Kamedo2   QUOTE (halb27 @ Dec 17 2012, 05:13) QUOTE...   Dec 17 2012, 03:03
- - halb27   a) If it's up to me, I prefer lame3100g over l...   Dec 15 2012, 23:21
- - halb27   a) What is the -X switch? b) Why would you want to...   Dec 16 2012, 11:48
|- - BFG   QUOTE (halb27 @ Dec 16 2012, 04:48) Respo...   Dec 16 2012, 12:26
|- - [JAZ]   QUOTE (BFG @ Dec 16 2012, 12:26) a) -X is...   Dec 16 2012, 14:11
|- - BFG   QUOTE ([JAZ] @ Dec 16 2012, 07:11...   Dec 16 2012, 19:51
- - halb27   I've read the -X documentation: that's not...   Dec 16 2012, 12:35
|- - BFG   QUOTE (halb27 @ Dec 16 2012, 05:35) I...   Dec 16 2012, 12:43
- - shadowking   The -X is automatic . The switch itself has been d...   Dec 16 2012, 13:28
- - IgorC   halb27, Nice to see the work in progess. Thank You...   Dec 16 2012, 20:59
|- - halb27   QUOTE (IgorC @ Dec 16 2012, 20:59) ... It...   Dec 16 2012, 21:32
- - IgorC   Well, I can do some blind tests and see how it wo...   Dec 16 2012, 22:58
|- - halb27   QUOTE (IgorC @ Dec 16 2012, 22:58) ... It...   Dec 16 2012, 23:17
|- - BFG   I'm definitely seeing the point to a lowpass, ...   Dec 17 2012, 00:49
- - halb27   I tried -V5+ --adbr_long 80 --adbr_short 370 --adb...   Dec 16 2012, 23:10
- - halb27   The suggestions have found their way into lame3100...   Dec 18 2012, 01:16
RSS Lo-Fi Version Time is now: 18th April 2015 - 13:33
