Headphone amps, external power supplies: what difference do they make?, was: "First post here, Hi."
1096bimu
post Dec 7 2012, 00:35
Ever since I was told that it is possible to tell 320kbps CBR from loseless, I've had some interest in hi-fi, and that was a few years ago. Today, I use an ASUS Xonar Essance sound card and an AKG Q701 headphone. I am pretty confident that it sounds better than all the cheaper alternatives I've had before, and I am quite proud of my own ability to eliminate biases without blind testing (because of lack of equipment). However, 320kbps MP3 is still transparent to me. The absolute best I can do is tell 128kbps, and it is extremely difficult as I have to go through the samples multiple times to try and spot one or two obvious distortions, and tell from that. If I couldn't find any than they sound identical to me. I have read through many of the FAQs, compilation of test results and older posts so I know this isn't uncommon and isn't what I am worried about. I keep everything loseless even though I can't tell the difference because I don't have that many music, only a few gigs which isn't a problem for today's mobile devices (exported selected few from CD images).
The biggest problem is I keep running into this claim that headphone amps are supposed to make ginormous differences, especially with the AKG Q701. Some people say there is more difference with the K701 but aren't they identical except the colors? Of course nobody could show any blind test results and they are nothing more than testimonies. I am not a hard core audiophile I don't have any audiophile friends so it's not possible so it is not possible for me to try out stand alone amps. It just seems to me that many of these audiophiles believe in some kind of mystical superiority of external boxes. You gotta have an external DAC, and an external amp and you have to connect them together. I mean today they are just intergraded circuits why do they have to be external? The Xonar Essance says "Headphone amp card" and it does have an amplifier chip as well as those small ones that you can swap out and everything, so What's the difference?
In fact, I tried the Q701 on my cell phone, iPad, on-board intergraded audio, and even an iPod shuffle. They sound slightly worse I would say, the difference is quite subtle when compared to the Xonar. And I could not tell any difference between my phone, iPad and iPod shuffle.
I've also heard that you have to use an external power supply (it has a port that plugs into the computer power supply) for the Xonar to "bring out its full potential". Again, what's the difference? are computer power supplies not stabilized? I guess I also count as an overclocker so I know how voltages in the computer are set to two or three digits after the decimal, it is really sensitive stuff. I mean maybe the computer with its variable power requirement will destabilize the power source, but I don't listen to music while playing games or anything, I leave the computer idle for that. Also being a fairly high-end spec, the -12V power supply has a capacity of 650W (for 12V alone) , isn't that enough head room for small fluctuations?
saratoga
post May 11 2013, 06:48
^^^Amping a fuze to use with iems makes zero sense. The fuze is already a low impedance out. At best the amp literally does nothing.
psgarcha92
post May 11 2013, 07:59
QUOTE (saratoga @ May 11 2013, 11:18) *
Am gonna say it once again, the Amp opens my IEMs up, widens the sound stage. Adding to it, instrument separation is better through the amp. I like the change in sound signature that the Mini^3 provides over the Default Signature of the Fuze.
Nessuno
post May 11 2013, 09:20
QUOTE (psgarcha92 @ May 11 2013, 08:59) *
There is a reason why correct ABX tests must be level matched: you could very likely obtain the same improvements just pushing up a couple bars of volume level on the same Fuze! wink.gif
And in doing so, take care of your ears: with IEMs one could easily reach high and undistorted sound pressures which can cause damage in the long run. I love my Etymotic most of all because of their insulation, as lowering so much the noise floor they allow me to listen at lower average levels without loosing too much on... well... details, soundstage, instrument separation and so on! biggrin.gif
By the way, that's an easy test you can do: start listening at moderate level for a while, get your ears accustomed to it and then pull the volume a little up. Chances are you'll actually perceive the variation as an "opening" instead of simply "increasing".
... I live by long distance.
- 1096bimu   Headphone amps, external power supplies: what difference do they make?   Dec 7 2012, 00:35
- - DVDdoug   QUOTE The biggest problem is I keep running into t...   Dec 7 2012, 03:05
|- - 1096bimu   QUOTE This could be a voltage issue. I don't r...   Dec 7 2012, 05:19
|- - Nessuno   QUOTE (DVDdoug @ Dec 7 2012, 03:05) But, ...   Dec 7 2012, 09:04
||- - Arnold B. Krueger   QUOTE (Nessuno @ Dec 7 2012, 03:04) QUOTE...   Dec 7 2012, 14:44
||- - bennetng   QUOTE (Nessuno @ Dec 7 2012, 16:04) QUOTE...   May 11 2013, 09:42
||- - Nessuno   QUOTE (bennetng @ May 11 2013, 10:42) QUO...   May 11 2013, 11:00
||- - bennetng   QUOTE (Nessuno @ May 11 2013, 18:00) In b...   May 11 2013, 13:51
|- - Arnold B. Krueger   QUOTE (DVDdoug @ Dec 6 2012, 21:05) QUOTE...   Dec 7 2012, 14:40
|- - CSMR   QUOTE (DVDdoug @ Dec 6 2012, 18:05) If yo...   Dec 14 2012, 02:06
|- - Arnold B. Krueger   QUOTE (DVDdoug @ Dec 6 2012, 22:05) I don...   May 13 2013, 17:33
- - arward72   http://www.stereophile.com/computeraudio/a...ards/...   Dec 10 2012, 21:48
|- - Arnold B. Krueger   QUOTE (arward72 @ Dec 10 2012, 15:48) htt...   Dec 11 2012, 01:03
- - arward72   The external power connector for the ASUS Xonar is...   Dec 10 2012, 23:23
- - J.Philippe   Doesn't the Essence card already have a headph...   Dec 14 2012, 08:36
- - psgarcha92   Ok, so i was going through the forums, looking for...   May 11 2013, 04:56
- - saratoga   ^^^Amping a fuze to use with iems makes zero sense...   May 11 2013, 06:48
|- - psgarcha92   QUOTE (saratoga @ May 11 2013, 11:18) ^^^...   May 11 2013, 07:59
|- - Nessuno   QUOTE (psgarcha92 @ May 11 2013, 08:59) Q...   May 11 2013, 09:20
- - skamp   psgarcha92: this isn't head-fi, you have to ab...   May 11 2013, 08:34
|- - psgarcha92   QUOTE (skamp @ May 11 2013, 13:04) psgarc...   May 11 2013, 08:40
||- - skamp   QUOTE (psgarcha92 @ May 11 2013, 09:40) T...   May 11 2013, 10:28
||- - bennetng   QUOTE (skamp @ May 11 2013, 17:28) FWIW, ...   May 12 2013, 06:17
|- - db1989   QUOTE (skamp @ May 11 2013, 08:34) psgarc...   May 12 2013, 02:17
|- - skamp   QUOTE (db1989 @ May 12 2013, 03:17) Thank...   May 12 2013, 10:21
|- - Arnold B. Krueger   QUOTE (skamp @ May 12 2013, 05:21) QUOTE ...   May 12 2013, 14:31
- - psgarcha92   Skamp, How am i supposed to ABX Headphones? My Re...   May 11 2013, 19:52
|- - saratoga   QUOTE (psgarcha92 @ May 11 2013, 14:52) S...   May 11 2013, 20:51
- - psgarcha92   Respected Moderators, I am sorry that i did not r...   May 12 2013, 20:55
- - saratoga   ^^ unless something is really screwy with that amp...   May 12 2013, 22:36
- - saratoga   Any sound card will use a regulated voltage anyway...   May 13 2013, 22:41
- - Klipspringer   Hi Folks, This is my first post and I'm very ...   Jun 14 2013, 20:28
|- - saratoga   QUOTE (Klipspringer @ Jun 14 2013, 15:28)...   Jun 14 2013, 20:47
|- - Klipspringer   QUOTE (saratoga @ Jun 14 2013, 11:47) QUO...   Jun 15 2013, 00:57
|- - Arnold B. Krueger   QUOTE (Klipspringer @ Jun 14 2013, 19:57)...   Jun 15 2013, 14:42
- - Klipspringer   Thanks Arnold for the thorough reply. I can't ...   Jun 16 2013, 08:47
- - Arnold B. Krueger   QUOTE (Klipspringer @ Jun 16 2013, 03:47)...   Jun 16 2013, 10:23
- - Klipspringer   QUOTE There's not a lot to understand. Making ...   Jun 16 2013, 18:54
- - Arnold B. Krueger   QUOTE (Klipspringer @ Jun 16 2013, 13:54)...   Jun 17 2013, 12:32
RSS Lo-Fi Version Time is now: 25th May 2015 - 01:54
