Frequency Response of Vinyl, Split from "To get into vinyl, or not?" (TOS #5)
almostmitch
post Dec 3 2012, 20:15
QUOTE (botface @ Dec 3 2012, 13:49) *
I guess you can expect a factory installed arm/cartridge to be set up properly. I'd still want to check though even if only for reassurance that things haven't gone "off" in transit.
This was something I considered. I will most likely double check things, because as you implied, you never know what kind of beating the box took in transit.
BFG
post Dec 4 2012, 00:16
This whole conversation has me intrigued about the technical limitations of vinyl. For example, is there a minimum or maximum frequency that can be "encoded" in vinyl (akin to the ~20Hz and 44.1kHz cutoffs on digital CDs)? Does this differ for 33s, 45s, 78s? Is there a way (based on the needle tip and equipment setup) for a knowledgeable person to precalculate the bands that the most noise interference will likely be in, and thus minimize or remove it? Etc.
It's particularly pertinent as I'm planning to attempt a vinyl-to-FLAC encoding soon.
This post has been edited by BFG: Dec 4 2012, 00:17
Canar
post Dec 5 2012, 01:10
In theory, it's still wrong. There is a theoretical upper bound to vinyl's frequency reproduction. Like I said, precisely how you define that limit will change where you place that theoretical upper bound.
It's not as clearly defined as CD, but that does not imply that there is no theoretical upper bound!
This post has been edited by Canar: Dec 5 2012, 01:11
2. Assume good faith.
Nessuno
post Dec 5 2012, 09:10
QUOTE (Canar @ Dec 5 2012, 01:10) *
Well, in very strict theory, every time-limited signal has infinite bandwidth, so... wink.gif
... I live by long distance.
RSS Lo-Fi Version Time is now: 6th July 2015 - 15:05
