FLAC1170: a ITU BS.1770 loudness scanner for FLAC
pbelkner
post Dec 2 2012, 17:26
FLAC1770 is a ITU BS.1770 loudness scanner and tagger for FLAC. For tagging it should do exactly tha same as "metaflac".
Binaries are available for Win32, Linux, and Linux64:
$ flac1770
FLAC1170 v0.1.0, a ITU BS.1770 loudness scanner for FLAC.
Usage: flac1770 [options] <files>
Options:
  --help: dispaly this usage information and exit.
  --version: dispaly version information and exit.
  --tag: write replay gain tags to the input files (off).
  --r128: use EBU R128 compliant presets (default).
  --a85: use ATSC A/85 compliant presets.
  --rg: use ReplayGain compatible presets.
  --reference=<float>: set reference loudness (-23.0).
  --gate=<float>: set BS.1770 gate (-10.0).
  --partition=<int>: set BS.1770 partition (4).
  --unit=LU|LK|dB: use the respective loudness unit (LU).
  --progress=on|off: display progress percentage (on).
  --true-peak=fast|medium|best|off: determine inter-sample peaks (off).
Some examples:
  • Analyze some individual tracks:
    flac1770 track1.flac track2.flac track3.flac
  • Analyze some individual tracks and write RG tags to them:
    flac1770 --tag track1.flac track2.flac track3.flac
  • Analyze all tracks from a folder:
    flac1770 dir/*.flac
  • Analyze all tracks from a folder and write RG tags to them:
    flac1770 --tag dir/*.flac
  • Analyze all tracks from a folder and write RG tags to them, compatible with standard ReplayGain:
    flac1770 --rg --tag dir/*.flac
  • Analyze all tracks from a folder, including inter-sample peak determination, and write RG tags to them, compatible with standard ReplayGain:
    flac1770 --rg --true-peak=fast --tag dir/*.flac
This post has been edited by pbelkner: Dec 2 2012, 17:30
Wombat
post Dec 7 2012, 20:23
QUOTE (pbelkner @ Dec 7 2012, 21:15) *
FLAC1770 v0.2.0 released
What's new?
[*]Unit for absolute loudness is dB.
Edit: How to prevent reporting of positive album peaks like "REPLAYGAIN_ALBUM_PEAK 1.00003052" ? --true-peak=off is not it.
This post has been edited by Wombat: Dec 7 2012, 20:32
With 24bit audio you can listen to silence much louder
- pbelkner   FLAC1170: a ITU BS.1770 loudness scanner for FLAC   Dec 2 2012, 17:26
- - eahm   Thanks for the software. Shouldn't the / be ...   Dec 2 2012, 17:32
|- - pbelkner   QUOTE (eahm @ Dec 2 2012, 17:32) Shouldn...   Dec 2 2012, 17:42
|- - pbelkner   QUOTE (eahm @ Dec 2 2012, 17:32) Also, wh...   Dec 2 2012, 18:38
|- - Surfi   QUOTE (pbelkner @ Dec 2 2012, 18:38) I do...   Dec 3 2012, 21:40
|- - pbelkner   QUOTE (Surfi @ Dec 3 2012, 21:40) from fo...   Dec 4 2012, 08:22
|- - Surfi   QUOTE (pbelkner @ Dec 4 2012, 08:22) flac...   Dec 4 2012, 11:31
- - Wombat   Hi, finally something to replace metaflac while it...   Dec 3 2012, 03:18
- - skamp   The first two thumbs show the same values, except ...   Dec 4 2012, 11:46
- - Surfi   :: ... so why that many decimals? And why does f...   Dec 4 2012, 12:17
|- - pbelkner   QUOTE (Surfi @ Dec 4 2012, 12:17) I know ...   Dec 4 2012, 18:06
- - Surfi   :: Thanks for answering, all of your tools and yo...   Dec 4 2012, 20:30
- - leo-bogert   Very nice, thank you. This is a component which I...   Dec 4 2012, 21:55
- - Triza   I use loudness command from libebur128. Works grea...   Dec 5 2012, 00:33
|- - Surfi   QUOTE (Triza @ Dec 5 2012, 00:33) That us...   Dec 5 2012, 07:58
|- - Triza   I have read through libebur128 thread and tested a...   Dec 5 2012, 21:28
|- - Surfi   QUOTE (Triza @ Dec 5 2012, 21:28) ... Qua...   Dec 6 2012, 11:29
- - jangk   Target for EBU R128 is -23dBFS, but this possibly ...   Dec 6 2012, 12:15
|- - Surfi   QUOTE (jangk @ Dec 6 2012, 12:15) Target ...   Dec 6 2012, 15:35
|- - pbelkner   QUOTE (Surfi @ Dec 6 2012, 15:35) Have a ...   Dec 6 2012, 17:39
- - Singtoh   Hello All, Just stumbled upon the r128gain progra...   Dec 6 2012, 13:22
- - Surfi   :: Thank you very much for clarifying. ::   Dec 6 2012, 21:02
- - Singtoh   Hello All Again, I am not sure if this is the cor...   Dec 7 2012, 05:15
|- - pbelkner   QUOTE (Singtoh @ Dec 7 2012, 05:15) 3. Th...   Dec 7 2012, 07:42
- - Singtoh   Sure thing, and thanks again for your hard work on...   Dec 7 2012, 07:59
|- - pbelkner   QUOTE (Singtoh @ Dec 7 2012, 08:59) Sure ...   Dec 7 2012, 17:42
- - pbelkner   FLAC1770 v0.2.0 released What's new? Test cas...   Dec 7 2012, 20:15
|- - pbelkner   FLAC1770 v0.3.0 released What's new? Computat...   Dec 9 2012, 21:47
- - Wombat   QUOTE (pbelkner @ Dec 7 2012, 21:15) FLAC...   Dec 7 2012, 20:23
|- - pbelkner   QUOTE (Wombat @ Dec 7 2012, 21:23) How to...   Dec 7 2012, 21:53
- - Wombat   QUOTE (pbelkner @ Dec 7 2012, 22:53) By u...   Dec 7 2012, 23:24
- - JJZolx   As a casual follower of these threads, is there a ...   Dec 8 2012, 06:01
|- - pbelkner   QUOTE (JJZolx @ Dec 8 2012, 07:01) As a c...   Dec 8 2012, 07:33
- - pbelkner   FLAC1770 v0.4.0 released Download: https://sourcef...   Dec 12 2012, 18:28
- - pbelkner   FLAC1770 v0.4.1 released Download: https://sourcef...   Dec 19 2012, 18:58
RSS Lo-Fi Version Time is now: 3rd March 2015 - 21:25
