To get into vinyl, or not?, I was set on constructing an analogue system, but..
almostmitch
post Nov 28 2012, 07:43
I was set on constructing an analogue system, but I have seen several users criticize the various aspects of the vinyl medium.
(sound quality/accuracy, cost of equipment, effort to play/digitize)
I'm 20 years old and have never truly experienced vinyl. However, I am extremely intrigued by it. I very much like the idea of setting up an affordable but quality system to listen to vinyls on. Also, I would be digitizing my dads old albums and some of my own. I look at it as more of a hobby/interest than its practicality regarding current tech and sound quality. I like the idea of starting a record collection and listening to them with my friends. The nostalgia and audio technology are other aspects that interest me (big tech geek here). I'm aware of the imperfections of vinyl's sound and this is why I want to make sure I get a quality system to achieve the best possible sound the LP will produce (within budget). For my system, I had the Pro-Ject Debut Carbon and a pair of decent floor standing speakers in mind but was not set on which components I wanted to use with it (pre-amp + receiver, integrated amp, or just a receiver w/ phono inputs). This was originally the question I was going to ask you guys. Something I could connect my computer to in order to play music files is something I'd like to be able to do. I have always cared about sound quality and the majority of my albums are perfect CD rips (.flac). I currently do not have a hi-fi system to fully enjoy my music on which is another reason why I'm looking to purchase one. Also, this is something I plan to take with me and enjoy for many years to come.
-So I ask, how do you like the vinyl experience compared to the CD experience? Can the added complexities with vinyl add to the experience?
-Also, if I decide to go for a system, which device(s) combination might produce the best sound quality at a reasonable price?
Thanks for any input!
2Bdecided
post Dec 5 2012, 17:26
ReplayGain developer
I've had two Goldrings, bought from the same shop, both now over 20 years old. They looked identical, but the earlier one had much softer outer fibres. The later one had harder fibres - these would visible mark an LP if dragged across it in the wrong direction. But I'd wrecked the older one by trying to wash the fibres, after unfortunately using it to clean (what turned out to be) a greasy record.
Nessuno
post Dec 5 2012, 18:30
I have one of those with plastic pivoting flange (no brand) bought some 25 years ago and still in good conditions (used daily for about 15 years) and I remember the difference in cleaning ability with the velvet one I used before was quite remarkable. Never noticed shedded fibers.
I also remember back in the day they sold a version with a thin cable attached to the metal handler, intended to be connected to amp ground pin to discharge static from record surface.
By the way: what about those little brushes meant to clean the stylus from dust and other debris? I have one also, but resorted to use only very seldom (and very weakly).
This post has been edited by Nessuno: Dec 5 2012, 18:32
... I live by long distance.
Engelsstaub
post Dec 5 2012, 19:08
QUOTE (Nessuno @ Dec 5 2012, 11:30) *
Mine looks like an eyelash brush and I refill the bottle with 91% isopropyl alcohol. I use it gently after I play each record. Perhaps that is too often and a bit hard on the stylus? I'm not certain.
The Loudness War is over. Now it's a hopeless occupation.
cliveb
post Dec 5 2012, 20:36
WaveRepair developer
QUOTE (Engelsstaub @ Dec 5 2012, 18:08) *
Cleaning a stylus with isopropanol should be perfectly safe, when you consider that Linn used to recommend sandpaper!!!
Honestly, I'm not kidding. You could buy expensive green stuff from them and the technique was to gently drag it from back to front each side of the stylus. As far as I could make out, their green stuff was something like 1000 grit wet-and-dry.
Engelsstaub
post Dec 5 2012, 21:04
QUOTE (cliveb @ Dec 5 2012, 13:36) *
Thanks for the advice, cliveb.
I would like you to know that, based on your many unbiased contributions here and elsewhere, I greatly respect and appreciate your point of view regarding vinyl and audio in general. In fact, more so than anyone I know personally/offline.
- almostmitch   To get into vinyl, or not?   Nov 28 2012, 07:43
- - Glenn Gundlach   QUOTE (almostmitch @ Nov 27 2012, 22:43) ...   Nov 28 2012, 08:18
- - Light-Fire   QUOTE (almostmitch @ Nov 28 2012, 02:43) ...   Nov 28 2012, 08:19
|- - Nessuno   Upon reading the first post I was preparing to wri...   Nov 28 2012, 09:08
|- - clobon   QUOTE (Light-Fire @ Nov 28 2012, 09...   Nov 30 2012, 16:30
- - Engelsstaub   Do it, almostmitch. The Pro-Ject Debut III is a d...   Nov 28 2012, 09:01
- - Kohlrabi   The merits of vinyl are larger artwork (if you car...   Nov 28 2012, 09:46
- - Porcus   What about the following compromise: - listen to ...   Nov 28 2012, 10:38
- - dhromed   Vinyl is entirely about the ritual around the medi...   Nov 28 2012, 10:50
|- - Engelsstaub   QUOTE (dhromed @ Nov 28 2012, 04:50) Viny...   Nov 28 2012, 13:42
- - 2Bdecided   It's fun (if you like that kind of fun), but a...   Nov 28 2012, 11:01
|- - Destroid   QUOTE (2Bdecided @ Nov 28 2012, 11:01) Ot...   Nov 28 2012, 12:13
- - rgtb   QUOTE (Engelsstaub @ Nov 28 2012, 13:42) ...   Nov 28 2012, 15:57
|- - Engelsstaub   QUOTE (rgtb @ Nov 28 2012, 09:57) ...I ra...   Nov 28 2012, 18:19
- - mjb2006   Digitizing vinyl is fun and educational. You are e...   Nov 28 2012, 17:17
|- - krabapple   QUOTE (mjb2006 @ Nov 28 2012, 11:17) As f...   Dec 4 2012, 03:16
- - cliveb   I have a soft spot for vinyl, but let's not tr...   Nov 28 2012, 17:59
- - almostmitch   Thanks for the responses guys, great input. I...   Nov 28 2012, 18:08
|- - greynol   QUOTE (almostmitch @ Nov 28 2012, 09:08) ...   Nov 28 2012, 18:53
|- - Porcus   QUOTE (almostmitch @ Nov 28 2012, 18:08) ...   Nov 28 2012, 19:42
- - almostmitch   QUOTE (mjb2006 @ Nov 28 2012, 11:17) Digi...   Nov 28 2012, 22:08
|- - Engelsstaub   QUOTE (almostmitch @ Nov 28 2012, 16:08) ...   Nov 29 2012, 03:42
- - DVDdoug   I grew up with vinyl, and I always hated the ...   Nov 28 2012, 23:22
- - Porcus   If you are playing old vinyls, and at the risk of ...   Nov 29 2012, 10:20
|- - 2Bdecided   QUOTE (cliveb @ Nov 28 2012, 16:59) I hav...   Nov 29 2012, 10:51
|- - dhromed   QUOTE (2Bdecided @ Nov 29 2012, 10:51) Li...   Nov 29 2012, 11:34
|- - pdq   QUOTE (dhromed @ Nov 29 2012, 05:34) QUOT...   Nov 29 2012, 14:38
- - RonaldDumsfeld   QUOTE which device(s) combination might produce th...   Nov 29 2012, 13:12
- - almostmitch   QUOTE (DVDdoug @ Nov 28 2012, 17:22) When...   Nov 29 2012, 16:08
|- - Engelsstaub   QUOTE (almostmitch @ Nov 29 2012, 10:08) ...   Nov 29 2012, 17:19
- - pdq   I wouldn't worry about impedances and wattage ...   Nov 29 2012, 16:31
- - DVDdoug   QUOTE One thing I'm still unsure about is impe...   Nov 29 2012, 20:12
- - almostmitch   QUOTE (pdq @ Nov 29 2012, 10:31) I wouldn...   Nov 29 2012, 22:26
- - botface   The most important thing is to ensure you set up t...   Nov 30 2012, 09:42
- - RonaldDumsfeld   QUOTE I'd feel safer spending an extra $1...   Nov 30 2012, 14:40
- - almostmitch   QUOTE (botface @ Nov 30 2012, 03:42) The ...   Dec 3 2012, 14:43
|- - Engelsstaub   QUOTE (almostmitch @ Dec 3 2012, 08:43) Q...   Dec 3 2012, 16:42
||- - rgtb   QUOTE (Engelsstaub @ Dec 3 2012, 16:42) A...   Dec 4 2012, 08:24
||- - cliveb   QUOTE (rgtb @ Dec 4 2012, 07:24) in what ...   Dec 4 2012, 10:09
||- - Engelsstaub   QUOTE (rgtb @ Dec 4 2012, 02:24) QUOTE (E...   Dec 4 2012, 15:46
||- - rgtb   QUOTE (Engelsstaub @ Dec 4 2012, 15:46) I...   Dec 4 2012, 17:58
||- - Engelsstaub   QUOTE (rgtb @ Dec 4 2012, 11:58) QUOTE (E...   Dec 4 2012, 22:08
|- - botface   QUOTE (almostmitch @ Dec 3 2012, 13:43) Q...   Dec 3 2012, 19:49
- - almostmitch   QUOTE (Engelsstaub @ Dec 3 2012, 10:42) I...   Dec 3 2012, 18:20
- - almostmitch   QUOTE (botface @ Dec 3 2012, 13:49) I gue...   Dec 3 2012, 20:15
- - greynol   When you say something without obvious emphasis (b...   Dec 5 2012, 00:09
- - Engelsstaub   That's fair enough, greynol. I was providing h...   Dec 5 2012, 00:22
- - greynol   Yes, that you have been helpful was not lost on me...   Dec 5 2012, 07:51
- - Engelsstaub   I apologize for the tone and my part in the bicker...   Dec 5 2012, 15:14
- - almostmitch   QUOTE (Engelsstaub @ Dec 5 2012, 09:14) A...   Dec 5 2012, 15:52
|- - cliveb   QUOTE (almostmitch @ Dec 5 2012, 14:52) I...   Dec 5 2012, 16:25
- - Engelsstaub   Mine has a plastic flange, so I would actually pre...   Dec 5 2012, 16:54
- - 2Bdecided   I've had two Goldrings, bought from the same s...   Dec 5 2012, 17:26
|- - Nessuno   I have one of those with plastic pivoting flange (...   Dec 5 2012, 18:30
|- - Engelsstaub   QUOTE (Nessuno @ Dec 5 2012, 11:30) ... ...   Dec 5 2012, 19:08
|- - cliveb   QUOTE (Engelsstaub @ Dec 5 2012, 18:08) I...   Dec 5 2012, 20:36
|- - Engelsstaub   QUOTE (cliveb @ Dec 5 2012, 13:36) QUOTE ...   Dec 5 2012, 21:04
- - J.Philippe   One thing that might be worth mentioning is that m...   Dec 5 2012, 18:21
RSS Lo-Fi Version Time is now: 29th July 2015 - 05:08
