Personal Listening Test of Opus, Celt, AAC at 75-100kbps, ABC/HR blind test, 1 Listener
Kamedo2
post Nov 17 2012, 09:25
Abstract:
Blind Comparison between 2012/09 new Opusenc(tfsel5), old Celtenc 0.11.2, Apple AAC-LC tvbr, cvbr.
This is an English version of my original post in Japanese. http://d.hatena.ne.jp/kamedo2/20121116/1353099244#seemore
Encoders:
libopus 0.9.11-146-gdc4f83b-exp_analysis
https://people.xiph.org/~greg/opus-tools_exp_dc4f83be.zip
celt-0.11.2-win32
https://people.xiph.org/~greg/celt-0.11.2-win32.zip
qaac 1.40
qaac 1.40
Settings:
opusenc --bitrate 66 input.wav output.wav
celtenc input.48k.raw --bitrate 75 --comp 10 output.wav
qaac --cvbr 72 -o output.m4a input.wav
qaac --tvbr 27 -o output.m4a input.wav
opusenc --bitrate 90 input.wav output.wav
celtenc input.48k.raw --bitrate 100 --comp 10 output.wav
qaac --cvbr 96 -o output.m4a input.wav
qaac --tvbr 45 -o output.m4a input.wav
Samples:
20 Sounds of various genres, from easy to modestly critical.
http://zak.s206.xrea.com/bitratetest/main.htm
To download, access to the link above, 2nd paragraph, 3rd-6th links. (40_30sec - Run up)
Hardwares:
Sony PSP-3000 + RP-HT560(1st) , RP-HJE150(2nd), took the average of the two results.
Results:
Conclusions & Observations:
I could not detect a significant improvement in the new September 1st version of Opus, from the old Celtenc in 2011.
It's possibly because the new Opus inflates bitrates more than it improves qualities, although the set of sounds contain easy samples.
On 75kbps, Opus/Celt are markedly better. On 100kbps, there is no big difference between those codecs.
Raw data:
40 Logs and encoders, decoders log
http://zak.s206.xrea.com/bitratetest/log_o...kbps100kbps.zip
% Opus, AAC 75kbps, 100kbps ABC/HR Score
% This format is compatible with my graphmaker, as well as ff123's FRIEDMAN.
opus_75k    celt_75k    cvbr_75k    tvbr_75k    opus100k    celt100k    cvbr100k    tvbr100k
%features 6 75kbps 75kbps 75kbps 75kbps 100kbps 100kbps 100kbps 100kbps
%features 7 OPUS OPUS AAC-LC AAC-LC OPUS OPUS AAC-LC AAC-LC
3.050    3.100    2.500    2.750    3.500    3.750    3.700    3.800
3.750    2.950    2.700    2.750    4.050    3.800    4.000    3.950
2.800    2.550    3.000    3.000    3.600    3.250    4.050    3.900
2.700    3.150    2.350    2.300    3.350    3.800    3.600    3.700
4.000    3.400    2.850    2.850    4.350    3.900    3.550    3.550
2.600    2.550    2.800    2.800    3.350    3.150    3.950    3.900
3.400    3.950    3.000    3.200    3.850    4.500    3.700    3.800
3.450    3.500    2.900    2.800    3.850    4.050    4.050    4.150
2.950    2.700    3.550    3.450    3.250    3.450    4.000    3.850
3.100    3.400    2.750    2.600    3.800    3.850    4.150    4.000
3.350    3.100    2.600    2.600    3.750    3.400    3.450    3.500
3.750    3.350    2.800    2.950    4.050    3.750    3.800    3.850
3.550    3.300    2.600    2.650    4.250    3.950    3.750    3.600
3.100    3.350    2.750    2.550    3.650    3.700    3.850    3.800
3.400    3.450    2.900    2.900    3.650    3.950    3.750    3.900
3.250    3.300    2.750    2.800    3.650    3.850    3.950    3.750
3.600    3.800    3.300    3.300    3.550    4.000    3.650    3.700
3.700    3.350    3.300    3.300    3.900    3.650    4.100    4.000
3.100    3.600    3.150    3.000    3.700    3.800    4.100    3.850
3.650    4.050    3.000    2.900    4.050    4.250    3.750    3.550
It's not strange that some scores get 0.050 scale because I did tests twice per each music.
lvqcl
post Nov 19 2012, 20:32
I took my Opus compile (libopus v1.0.1-140-gc55f4d8 from git) and encoded several albums with it (pop/rock/electronic etc).
X axis: the value of the --bitrate option. Y axis: real bitrate. One album = one line on the graph.
Kamedo2
post Nov 19 2012, 23:19
QUOTE (jmvalin @ Nov 20 2012, 04:03) *
it was a version where the VBR is supposed to be properly "calibrated". That is, on a large collection of samples, the average output rate matches the target rate.
Thank you. Nice to hear that Opus developers have a sensible way to avoid tweaks that increase bitrates on virtually anything and perceive them as 'improvement'.
QUOTE (lvqcl @ Nov 20 2012, 04:32) *
I'm pleased to see, according to your graph, in real life application as a music storage, Opus always creates files with users' desired bitrates. Very close.
According to the bitrate table I posted, only 2 samples, mybloodrusts and Dimmu Borgir are what Opus felt as 'easy' samples(the value of the --bitrate option > real bitrate). Although I'm reluctant to include more easy samples because they adds more time ABXing and statistical noise, I should have included more easier samples.
jmvalin
post Nov 20 2012, 18:39
Xiph.org Speex developer
QUOTE (Kamedo2 @ Nov 19 2012, 17:19) *
Well, you could also just "calibrate" on a large set that includes a bit of everything, which I believe is what most tests do. I had a closer look at the bitrates and indeed it seems like your test really focuses on hard samples -- probably more than any other test I've seen so far. Are the audio samples available so I can check why Opus is finding them hard?
- Kamedo2   Personal Listening Test of Opus, Celt, AAC at 75-100kbps   Nov 17 2012, 09:25
- - C.R.Helmrich   Thanks for this interesting test, Kamedo, and welc...   Nov 17 2012, 10:28
|- - Kamedo2   QUOTE (C.R.Helmrich @ Nov 17 2012, 18:28)...   Nov 17 2012, 10:40
- - Dynamic   Thank you for your time and dedication, Kamedo2 ...   Nov 17 2012, 10:48
- - IgorC   Kamedo2, Thank You for all your tests. Glad to see...   Nov 17 2012, 11:04
- - Kamedo2   The samples I used The ABX criteria is 12/15(p=0...   Nov 17 2012, 18:44
- - Anakunda   QUOTE (Kamedo2 @ Nov 17 2012, 09:25) Blin...   Nov 17 2012, 23:45
|- - C.R.Helmrich   QUOTE (Anakunda @ Nov 18 2012, 00:45) Is ...   Nov 18 2012, 00:54
|- - Kamedo2   QUOTE (Anakunda @ Nov 18 2012, 07:45) Is ...   Nov 18 2012, 05:47
- - Dynamic   QUOTE x-axis=actual bitrate That was one query I ...   Nov 18 2012, 09:20
|- - Kamedo2   QUOTE (Dynamic @ Nov 18 2012, 17:20) QUOT...   Nov 18 2012, 10:23
- - Dynamic   Thank you for the clarification. It seems that du...   Nov 18 2012, 20:07
- - IgorC   Kamedo2, I'm not here to criticize your test...   Nov 18 2012, 20:12
|- - Kamedo2   QUOTE (IgorC @ Nov 19 2012, 04:12) As all...   Nov 19 2012, 02:17
|- - jmvalin   Hi Kamedo2, thanks for the test. From what I see, ...   Nov 19 2012, 20:03
- - lvqcl   I took my Opus compile (libopus v1.0.1-140-gc55f4d...   Nov 19 2012, 20:32
|- - Kamedo2   QUOTE (jmvalin @ Nov 20 2012, 04:03) it w...   Nov 19 2012, 23:19
|- - jmvalin   QUOTE (Kamedo2 @ Nov 19 2012, 17:19) Acco...   Nov 20 2012, 18:39
- - Dynamic   Thanks again to everyone in this thread. I'm c...   Nov 20 2012, 03:03
|- - jmvalin   QUOTE (Dynamic @ Nov 19 2012, 21:03) We d...   Nov 20 2012, 05:13
- - C.R.Helmrich   QUOTE (Kamedo2 @ Nov 17 2012, 10:25) Samp...   Nov 20 2012, 23:01
- - Kamedo2   QUOTE (jmvalin @ Nov 20 2012, 13:13) CELT...   Nov 21 2012, 02:08
|- - jmvalin   QUOTE (Kamedo2 @ Nov 20 2012, 20:08) I as...   Nov 21 2012, 03:15
|- - Kamedo2   QUOTE (jmvalin @ Nov 21 2012, 11:15) Actu...   Nov 21 2012, 05:37
|- - jmvalin   QUOTE (Kamedo2 @ Nov 20 2012, 23:37) I me...   Nov 22 2012, 02:45
|- - Kamedo2   QUOTE (jmvalin @ Nov 22 2012, 10:45) QUOT...   Nov 22 2012, 07:33
|- - jmvalin   QUOTE (Kamedo2 @ Nov 22 2012, 01:33) Ther...   Nov 22 2012, 18:10
- - Kamedo2   Bitrate vs Score plot of the 20 samples used. Opu...   Nov 21 2012, 03:26
- - Dynamic   I think the objectives in tests (experiments) matt...   Nov 22 2012, 19:03
|- - Kamedo2   QUOTE (Dynamic @ Nov 23 2012, 03:03) Ques...   Nov 22 2012, 22:42
- - Kamedo2   QUOTE rjamorim: There's some inverse proportio...   Nov 23 2012, 16:35
- - Kamedo2   I measured an average bitrate over wide range of n...   Nov 23 2012, 21:51
|- - jmvalin   QUOTE (Kamedo2 @ Nov 23 2012, 15:51) The ...   Nov 24 2012, 19:49
|- - Kamedo2   QUOTE (jmvalin @ Nov 25 2012, 03:49) QUOT...   Nov 25 2012, 15:34
- - Kamedo2   My post #34 might be too difficult. I wish I had b...   Nov 25 2012, 21:35
- - IgorC   Interesting. The Opus'es scores have less devi...   Nov 26 2012, 03:08
|- - Kamedo2   QUOTE (IgorC @ Nov 26 2012, 11:08) The Op...   Nov 26 2012, 23:56
|- - DonP   QUOTE (IgorC @ Nov 25 2012, 21:08) In thi...   Jan 3 2013, 02:57
- - Dynamic   Once again, Kamedo2, I applaud you for your testin...   Nov 26 2012, 21:57
|- - Kamedo2   QUOTE (Dynamic @ Nov 27 2012, 05:57) As I...   Nov 27 2012, 00:14
- - jmvalin   Kamedo2, can you give 1.1-alpha a try? It includes...   Jan 3 2013, 01:09
- - Kamedo2   QUOTE (jmvalin @ Jan 3 2013, 09:09) Kamed...   Jan 5 2013, 11:50
RSS Lo-Fi Version Time is now: 29th May 2015 - 12:32
