Any reasons NOT to use FLAC?, Time to rerip my CD collection. Fun!
BFG
post Nov 13 2012, 22:45
Last year - when I didn't know any better - I decided to "archive" my entire CD collection as high-quality MP3s. Now that I realize archiving with a lossy encoder is a very bad idea, I'm going back to do it the right way.
I'm planning to use FLAC since it's free, seems to have pretty wide support, and the version of LAME I use for MP3 encoding supports FLAC inputs.
Are there any good reasons NOT to go this route:
CD --> Exact Audio Copy (WAV) --> FFmpeg (FLAC), retained
FLAC --> LAME (MP3), retained --> MP3Gain --> album art embedder
For example, is there any way to rip CDs directly to FLAC with EAC? If so, would it be possible to simultaneously create the FLAC and MP3? Will I be able to pass the album art (and other ID3 tags) from EAC to FLAC to LAME?
FreaqyFrequency
post Nov 14 2012, 16:42
http://freac.org is an excellent tool, and is also able to encode to Vorbis, AAC, WMA, and a quirky speech-oriented codec called Bonk (which I haven't seen supported by any players, AFAIK.) I use it daily.
This post has been edited by FreaqyFrequency: Nov 14 2012, 16:49
FLAC -2 w/ lossyWAV 1.3.0i -q X -i
BFG
post Nov 14 2012, 22:05
Another reason to switch from MP3 to FLAC: it turns out my portable audio player, which is a Blackberry business phone, natively supports both FLAC and OGG files. Who knew?
OK, a follow-up question: I'm still learning about all the commandline options etc. available with FLAC. Right now, I'm planning to use -8 (the strongest compression available), because I don't care how long the music takes to compress; I'd rather compress it as tightly as possible.
But, I don't want to compress it so much that some players have trouble playing it. Is it possible to compress a FLAC so tightly that a system has trouble streaming it?
This post has been edited by BFG: Nov 14 2012, 22:07
Porcus
post Nov 16 2012, 10:19
QUOTE (BFG @ Nov 14 2012, 23:05) *
FLAC needs approximately the same resources to decode a -8 stream as a -5. So if you use the official encoder, and stay away from the --lax switch, you should be fine. (Except some devices have been reported not to conform, although off the top of my head I don't remember which, and a brief web search does not indicate it is any Blueberry.)
BFG
post Nov 16 2012, 19:58
QUOTE (Porcus @ Nov 16 2012, 03:19) *
Yep, I've had absolutely no problems - other than some brief static/jitters at the start of playthrough--on my Blackberry so far with -8 compression. (I even added -p on top of it, and am considering adding -r 7 or -r 8.) Decode time has been < 2 seconds per song. I can definitely live with that.
- BFG   Any reasons NOT to use FLAC?   Nov 13 2012, 22:45
- - pdq   By all means skip the intermediate wav file and go...   Nov 13 2012, 22:51
|- - garym   +1 on dbpoweramp. Excellent for ripping and metada...   Nov 13 2012, 23:00
- - BFG   Thanks for the tip on dbpoweramp; I've never l...   Nov 13 2012, 23:05
|- - garym   QUOTE (BFG @ Nov 13 2012, 16:05) Thanks f...   Nov 13 2012, 23:07
|- - Porcus   QUOTE (BFG @ Nov 14 2012, 00:05) Thanks f...   Nov 15 2012, 01:19
- - eahm   Mentioning free ones, foobar2000 and CueTools/CueR...   Nov 14 2012, 00:28
- - JunkieXL   I used EAC and REACT to rip to FLAC and LAME mp3s ...   Nov 14 2012, 00:49
|- - BFG   QUOTE (JunkieXL @ Nov 13 2012, 17:49) I u...   Nov 14 2012, 03:48
- - rohangc   REACT2 is a plug-in for EAC that allows you to sim...   Nov 14 2012, 04:43
- - BFG   Heh, -1 to myself for not checking the wiki first....   Nov 14 2012, 05:53
- - greynol   Probably the most common method was not explicity ...   Nov 14 2012, 16:12
- - FreaqyFrequency   http://freac.org is an excellent tool, and is also...   Nov 14 2012, 16:42
|- - BFG   Another reason to switch from MP3 to FLAC: it turn...   Nov 14 2012, 22:05
|- - garym   QUOTE (BFG @ Nov 14 2012, 15:05) Another ...   Nov 14 2012, 22:10
||- - garym   seems odd to use FLAC on a blackberry. Maybe creat...   Nov 14 2012, 22:23
|- - Porcus   QUOTE (BFG @ Nov 14 2012, 23:05) But, I d...   Nov 16 2012, 10:19
|- - BFG   QUOTE (Porcus @ Nov 16 2012, 03:19) FLAC ...   Nov 16 2012, 19:58
- - FreaqyFrequency   The difference in encode/decode time and the absol...   Nov 14 2012, 22:27
|- - BFG   QUOTE (garym @ Nov 14 2012, 15:23)Stuff Y...   Nov 14 2012, 22:47
|- - Soap   QUOTE (FreaqyFrequency @ Nov 14 2012, 17...   Nov 14 2012, 22:51
|- - FreaqyFrequency   QUOTE (Soap @ Nov 14 2012, 17:51) Do you ...   Nov 14 2012, 23:10
|- - Nick.C   QUOTE (Soap @ Nov 14 2012, 22:51) Now Roc...   Nov 15 2012, 00:15
- - yourlord   Again, FLAC encoding time is basically irrelevant....   Nov 14 2012, 23:42
- - BFG   OK, I've finally settled on ripping directly t...   Nov 15 2012, 05:59
|- - skamp   QUOTE (BFG @ Nov 15 2012, 05:59) (1) Is t...   Nov 15 2012, 10:30
|- - Oby   QUOTE (skamp @ Nov 15 2012, 10:30) QUOTE ...   Nov 19 2012, 17:00
|- - BFG   Thanks for the tips; those links proved to be extr...   Nov 21 2012, 05:48
- - probedb   1. FLAC supports Vorbis tags so put what you want ...   Nov 15 2012, 10:01
|- - greynol   QUOTE (probedb @ Nov 15 2012, 01:01) I gu...   Nov 15 2012, 15:35
||- - garym   re: embedding artwork. One of the things I like ab...   Nov 15 2012, 15:39
|- - DonP   QUOTE (probedb @ Nov 15 2012, 05:01) 2. I...   Nov 15 2012, 16:05
- - greynol   The post you quoted already says that.   Nov 15 2012, 16:26
- - ron spencer   Don't forget, TAS says FLAC is bad   Nov 16 2012, 01:57
- - greynol   Which errors are those?   Nov 21 2012, 06:36
- - BFG   QUOTE (greynol @ Nov 20 2012, 23:36) Whic...   Nov 21 2012, 07:02
RSS Lo-Fi Version Time is now: 30th January 2015 - 06:11
