Smallest File / Mostly Transparent Encoder?, Have not been keeping up..
funkyblue
post Nov 13 2012, 03:34
Hello All
I have not been keeping with the latest goings on in the last few years.
Is these a consensus on an audio format vs file size that is mostly transparent?
I have always used V2 with LAME. (I still remember the --r3mix option!)
Currently I encoded a bunch of stuff with -V4 for portable usage and it has been great.
Is there any other file formats or options that give the smallest file size that is mostly transparent?
I know mostly transparent is not a scientific analysis but I am unsure if there is a happy medium now?
Thanks in advance.
IgorC
post Nov 13 2012, 04:55
There is a search function in the top-right corner. I bet You will find a lot of useful information in this forum.
This post has been edited by IgorC: Nov 13 2012, 04:58
http://listening-test.coresv.net/results.htm
BFG
post Nov 13 2012, 05:06
For transparency and portability, it's still tough to beat LAME and MP3. I find -V4.5 -q0 (~160kbps) to be fine for portable players, though to be on the safer side I usually -V0 everything.
You may also want to check out halb27's LAME variant. It increases the accuracy requirements for tough-to-encode sections. Of course that can dramatically raise the bitrate too.
This post has been edited by BFG: Nov 13 2012, 05:08
- funkyblue   Smallest File / Mostly Transparent Encoder?   Nov 13 2012, 03:34
- - saratoga   For portable use, probably -V5 in lame would be fi...   Nov 13 2012, 03:42
|- - funkyblue   QUOTE (saratoga @ Nov 13 2012, 11:42) For...   Nov 13 2012, 04:20
|- - saratoga   QUOTE (funkyblue @ Nov 12 2012, 23:20) QU...   Nov 13 2012, 06:39
- - IgorC   There is a search function in the top-right corner...   Nov 13 2012, 04:55
|- - BFG   For transparency and portability, it's still t...   Nov 13 2012, 05:06
|- - funkyblue   QUOTE (IgorC @ Nov 13 2012, 12:55) There ...   Nov 13 2012, 05:47
- - eahm   I can even suggest you AAC True VBR q36 (~95kbps) ...   Nov 13 2012, 06:38
- - Anakunda   Check hardware specs of the target player and if i...   Nov 13 2012, 08:06
|- - Nessuno   Why don't take a different approach to this ma...   Nov 13 2012, 09:26
- - Porcus   Is this for keeping your only copy, or is it for t...   Nov 13 2012, 09:23
|- - funkyblue   QUOTE (Porcus @ Nov 13 2012, 17:23) Is th...   Nov 13 2012, 10:09
- - shadowking   IMO, MP3 takes the crown . Others may be better t...   Nov 13 2012, 11:07
|- - funkyblue   QUOTE (shadowking @ Nov 13 2012, 19:07) I...   Nov 13 2012, 12:18
- - skamp   Opus at ~128 kbps is also pretty good (I couldn...   Nov 13 2012, 11:20
- - punkrockdude   I hope the developer on DeaDBeeF changes his mind ...   Nov 13 2012, 12:16
- - Brand   Based on my own limited testing, I'd say the l...   Nov 13 2012, 12:57
- - yourlord   Do some test encodes of OGG Vorbis or AAC targetin...   Nov 13 2012, 14:21
- - IgorC   A personal listening test of AAC and MP3. http://d...   Nov 13 2012, 15:07
- - funkyblue   OK Thanks IgorC I did take a look at the listenin...   Nov 13 2012, 15:23
- - pdq   Just a thought, for less than $40 you can get...   Nov 13 2012, 15:44
- - funkyblue   Yeah I could get another MP3 player, but I am only...   Nov 13 2012, 15:57
- - funkyblue   So I have managed to get this to work: qaac.exe i...   Nov 13 2012, 16:13
|- - IgorC   QUOTE (funkyblue @ Nov 13 2012, 12:13) -V...   Nov 13 2012, 16:48
|- - eahm   QUOTE (funkyblue @ Nov 13 2012, 08:13) So...   Nov 13 2012, 19:02
|- - funkyblue   QUOTE (eahm @ Nov 14 2012, 04:02) QUOTE (...   Nov 21 2012, 05:20
|- - eahm   QUOTE (funkyblue @ Nov 20 2012, 21:20) QU...   Nov 21 2012, 06:18
- - Brand   For the FhG AAC encoder see here. The encoder .exe...   Nov 13 2012, 16:17
- - greensdrive   check QAAC's wiki, https://github.com/nu774/qa...   Nov 13 2012, 16:20
|- - funkyblue   QUOTE (greensdrive @ Nov 14 2012, 00:20) ...   Nov 13 2012, 16:24
- - funkyblue   Is there a somewhat consensus that FhG is better t...   Nov 13 2012, 16:21
|- - Brand   QUOTE (funkyblue @ Nov 13 2012, 17:21) Is...   Nov 13 2012, 16:51
|- - eahm   QUOTE (funkyblue @ Nov 13 2012, 08:21) Is...   Nov 14 2012, 19:07
- - greensdrive   my foobar2000 command line for approximately 128 k...   Nov 13 2012, 16:44
- - funkyblue   QUOTE (greensdrive @ Nov 14 2012, 00:44) ...   Nov 13 2012, 16:53
- - funkyblue   I am truly shocked at the quality of 96kbits! ...   Nov 13 2012, 17:28
- - yourlord   What kind of phone? All Android phones will play O...   Nov 13 2012, 18:12
- - pdq   QUOTE (funkyblue @ Nov 13 2012, 06:18) I ...   Nov 13 2012, 18:33
- - funkyblue   I could ABX 112kbits. Could not ABX files in Lame ...   Nov 14 2012, 15:18
|- - IgorC   QUOTE (funkyblue @ Nov 14 2012, 11:18) I ...   Nov 14 2012, 16:37
- - pdq   It appears that funkyblue is only using ABX to dis...   Nov 14 2012, 16:52
- - IgorC   It's not that simple and linear. The conditi...   Nov 14 2012, 17:06
|- - funkyblue   QUOTE (IgorC @ Nov 15 2012, 01:06) It...   Nov 15 2012, 01:49
- - Brand   But wasn't the only AAC comparison done at ~96...   Nov 14 2012, 19:32
- - eahm   AAC achieve transparency at around 128kbps, obviou...   Nov 14 2012, 20:54
- - IgorC   I'm glad You are open mind. Here is a guid...   Nov 15 2012, 15:10
RSS Lo-Fi Version Time is now: 19th April 2015 - 15:41
