LAME 3.100 alpha testing
IgorC
post Nov 8 2012, 03:29
New build of LAME 3.100 alpha is available on http://www.rarewares.org/mp3-lame-bundle.php
Changelog
Dynamic
post Nov 8 2012, 17:17
Yes, I should have made it clear that I was really just using that not Final 3.99.5y version just to investigate whether the short-block high bitrate approach would be enough to fix or improve the frequency resolution problem or whether some of it might well be outside the short blocks themselves (I believe the more recent versions of halb27's LAME extension also modify long-block behaviour, so I chose the old version that leaves them alone).
It wasn't supposed to be a like-for-like comparison of comparable bitrates but an enquiry into what part of the problem was in the short blocks. I'm confident that -V5+ improves it, so if I have enough time, I may try to find out what's required to make it transparent, if transparency is even possible with harpsichord sounds like this (and from my past reading I think that transient smearing at least might be somewhere that MP3 can't quite provide transparency).
It may well be that also the marginal masking decisions made by the -V5 thresholds (as opposed to -V3 or -V2 where they tend to be tuned to ensure quite robust transparency, with just a few exceptions) are allowing too much inaccuracy in quantization during the long blocks as well, which might be why the wavering goes on a little after the short blocks for the transient should have finished, and that these issues could be solved by going to a higher quality setting (lower -V number), while the short blocks might require the + mode in addition to continue to settle quickly on the accurate tone frequency).
For general encoding with high robustness against transient+tonal problems, I'd certainly recommend people look into halb27's latest versions in the lame 3.99.5z functional extension thread.
- IgorC   LAME 3.100 alpha testing   Nov 8 2012, 03:29
- - IgorC   As of bitrate for current alpha 2 it's (3.99....   Nov 8 2012, 03:59
|- - Dynamic   QUOTE (IgorC @ Nov 8 2012, 02:59) So I tr...   Nov 8 2012, 16:09
- - halb27   I tested 3.100a2 at the -V2 quality level for lead...   Nov 8 2012, 11:40
|- - lameboy   How is the LAME header written in 3.100? (I'm ...   Nov 8 2012, 15:36
- - IgorC   halb27, Before anything. Does 3.100 -V2 comparabl...   Nov 8 2012, 15:33
|- - halb27   QUOTE (IgorC @ Nov 8 2012, 16:33) ... Doe...   Nov 8 2012, 16:07
|- - IgorC   QUOTE (halb27 @ Nov 8 2012, 12:07) Averag...   Nov 8 2012, 17:11
- - halb27   For a fair comparison (in terms of average bitrate...   Nov 8 2012, 16:29
- - Dynamic   Yes, I should have made it clear that I was really...   Nov 8 2012, 17:17
- - Porcus   IgorC: 190 vs 195 is oranges vs elephants ... seri...   Nov 8 2012, 17:23
|- - IgorC   QUOTE (Porcus @ Nov 8 2012, 13:23) IgorC:...   Nov 8 2012, 18:07
|- - halb27   QUOTE (IgorC @ Nov 8 2012, 18:07) Who gua...   Nov 8 2012, 18:20
|- - IgorC   QUOTE (halb27 @ Nov 8 2012, 14:20) A 5 kb...   Nov 8 2012, 18:50
- - halb27   Average bitrate for my test set using -V5: 3.98.4:...   Nov 8 2012, 17:27
- - halb27   I finished my -V2 listening test with herding_call...   Nov 8 2012, 17:56
- - IgorC   QUOTE (halb27 @ Nov 8 2012, 13:27) Averag...   Nov 8 2012, 17:59
- - halb27   I tested 3.100a2 -V0 for the samples that were not...   Nov 8 2012, 18:40
- - halb27   OK, so the -V5 quality improvement of this sample ...   Nov 8 2012, 19:32
- - IgorC   if 5 kbps doesn't matter then try 3.99.5 V1.9 ...   Nov 8 2012, 20:52
- - halb27   3.99.5 -V1.85 yields an average bitrate of 195 kbp...   Nov 8 2012, 21:16
- - IgorC   Thank You for understanding, halb27. MPEG tests ...   Nov 8 2012, 22:07
- - shadowking   As long as problematic samples benefit then slight...   Nov 9 2012, 02:37
|- - IgorC   QUOTE (shadowking @ Nov 8 2012, 22:37) As...   Nov 9 2012, 03:09
- - shadowking   As i can tell the recent encoders are using mega-b...   Nov 9 2012, 04:13
|- - BFG   Personally, I'm less concerned about bitrate a...   Nov 9 2012, 07:05
- - halb27   So what we've learnt is: - For an exact compa...   Nov 9 2012, 07:49
|- - saratoga   QUOTE (halb27 @ Nov 9 2012, 02:49) - Espe...   Nov 9 2012, 22:58
|- - BFG   QUOTE (saratoga @ Nov 9 2012, 15:58) I wo...   Nov 9 2012, 23:32
- - Gainless   Another sample, pre-echos on the kicks with -V 2 (...   Nov 9 2012, 20:49
- - halb27   ??? IMO a selection of tracks should be used which...   Nov 10 2012, 11:16
- - Kamedo2   I'm considering a listening test of this new L...   Dec 2 2012, 07:50
|- - Gainless   QUOTE (Kamedo2 @ Dec 2 2012, 07:50) I...   Dec 2 2012, 12:05
- - IgorC   Kamedo2, Performing a full test with an early al...   Dec 2 2012, 13:53
|- - Kamedo2   QUOTE (IgorC @ Dec 2 2012, 21:53) Perform...   Dec 2 2012, 15:40
- - Kamedo2   A small a priori test of LAME 3.100a2. 3.100VBR V3...   Dec 8 2012, 19:02
|- - IgorC   QUOTE (Kamedo2 @ Dec 8 2012, 15:02) Maybe...   Dec 9 2012, 17:41
|- - Kamedo2   QUOTE (IgorC @ Dec 10 2012, 01:41) Can I ...   Dec 9 2012, 18:43
- - halb27   Wow! This looks great! So despite its alph...   Dec 8 2012, 22:03
- - IgorC   Welcome to our world. Today You clearly hear t...   Dec 9 2012, 19:09
|- - Kamedo2   QUOTE (IgorC @ Dec 10 2012, 03:09) Today ...   Dec 9 2012, 20:17
|- - Kamedo2   QUOTE (Kamedo2 @ Dec 10 2012, 04:17) Yes,...   Dec 11 2012, 15:43
- - goa pride   lame 3.100 alpha don't write parameters to tag...   Jul 25 2013, 21:07
- - polemon   Where can I download the current sources? http://...   Aug 27 2013, 07:11
|- - halb27   QUOTE (polemon @ Aug 27 2013, 08:11) Wher...   Aug 27 2013, 07:56
|- - goa pride   more than a year has passed have found flaws? I do...   Dec 31 2013, 18:56
- - Francksoy-Wizzu   Could anyone help me succeding using the current b...   Apr 23 2014, 13:20
- - polemon   Has there been any work done lately to LAME? It...   Jan 1 2015, 07:02
- - LedHed8   QUOTE (polemon @ Jan 1 2015, 00:02) Has t...   Jan 1 2015, 07:37
RSS Lo-Fi Version Time is now: 2nd July 2015 - 06:33
