Automatically launch at Windows startup: "dll missing" error, was: "Window 8"
gufau
post Nov 7 2012, 10:17
I just installed windows 8 on my HCPC.
Foobar works very well on this new bone.
I have a problem to "launch" foobar automatically at windows startup.
If I put a shortcut in the strat menu, it does not start.
If I put the. Exe, I receive an error message with "dll" missing.
If I go through the "planner spots", it does not start.
An idea?
Replies (1 - 9)
Case
post Nov 7 2012, 11:53
Group: Developer (Donating)
You need to put shortcut to foobar2000 in %appdata%\Microsoft\Windows\Start Menu\Programs\Startup. Or you could make a scheduled task that starts it after logon. Or you could add entry to registry under HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run.
Autostarting to work requires that you haven't modified foobar2000 compatibility settings to run it as admin.
gufau
post Nov 7 2012, 12:41
Thank' for answer,
In my post I have do as you say ... the shortcut or the scheduled task, without result.
So, I have not tried with the registry key, I'll see...it's dont work no more.
gufau
post Nov 9 2012, 11:09
Hi, nobody else for help ?
Case
post Nov 9 2012, 17:13
Is the problem that you need to open Desktop before foobar2000 is started? You can circumvent that with Start Menu replacement tools, such as Stardock's Start8.
gufau
post Nov 9 2012, 19:45
No, the problem is not there, I think.
I have already installed Start8 and then I have a media center (Jriver) that, he will start automatically.
gufau
post Nov 13 2012, 15:02
Update today of zlib1.dll but always the same problem...
Case
post Nov 13 2012, 21:30
I can assure you that foobar2000 does not have problems starting automatically. You cannot move or copy just foobar2000.exe outside of the installation directory, all files are required in their proper locations. Only copy or move a shortcut to foobar2000 into the Startup folder. And verify that nothing is ticked in the Compatibility tab of the file properties.
gufau
post Nov 13 2012, 21:54
Thank's for answer,
I tried everything and verified that there is nothing checked in of compatibility tab.
It still does not start.
gufau
post Nov 13 2012, 21:59
I just made the manipulation on seven and there, no problem, foobar starts well at startup.
This seems to be a problem with Windows 8.
RSS Lo-Fi Version Time is now: 25th January 2015 - 05:32
