Detecting whether a 24-bit file has been upconverted from 16-bit?
vincefalks
post Nov 6 2012, 05:50
I downloaded a FLAC album from online web store and it appears that the files I've downloaded are 24-bit. it's not a hd web store like hdtracks, it's generally a CD 16-bit 44.1kHz store with either FLAC or MP3 to choose from in its offerings.
I'm wondering whether the 24-bit files are real and were supplied as 24-bit from the label and they just didn't label it correctly on the download page, or whether there was an encoding error or just somehow it made its way from 16-bit files to 24-bit FLACs.
Is there a way I can definitively tell or analyze it (looking at spectral maybe) to see if it's been upconverted? Are there certain algorithms and 'good jobs' that can be done to make its 16->24 upconversion undetectable?
happy to upload a sample if it helps.
thanks
vince
Arnold B. Kruege...
post Nov 9 2012, 16:01
QUOTE (vincefalks @ Nov 5 2012, 23:50) *
Many of the actual upconversions are going to be pretty hard to determine by simple means. For example it is pretty well known that about half of all so-called HD tracks started out as analog tapes or non-CD digital recordings that either came from or passed through the analog domain during the transcription process.
Catching only the clerical errors and obvious transcription errors is only a partial solution.
- vincefalks   Detecting whether a 24-bit file has been upconverted from 16-bit?   Nov 6 2012, 05:50
- - nu774   Try something like the following to see if wasted ...   Nov 6 2012, 06:31
|- - skamp   QUOTE (nu774 @ Nov 6 2012, 06:31) Try som...   Nov 6 2012, 12:06
|- - julf   QUOTE (skamp @ Nov 6 2012, 12:06) I used ...   Nov 8 2012, 16:33
|- - Sparktank   QUOTE (nu774 @ Nov 6 2012, 06:31) CODEfla...   Apr 13 2013, 01:47
- - bandpass   QUOTE (vincefalks @ Nov 6 2012, 04:50) Ar...   Nov 6 2012, 09:11
- - spoon   >Are there certain algorithms and 'good job...   Nov 6 2012, 11:47
- - nu774   BTW, I think just a slight gain scaling from the o...   Nov 6 2012, 12:31
- - greynol   You can add noise or simply use Audacity which can...   Nov 6 2012, 12:42
- - 2Bdecided   There's no way of knowing for sure. Unlike low...   Nov 6 2012, 12:45
- - vincefalks   Thanks guys (and yeah thanks greynol for pointing ...   Nov 6 2012, 16:29
|- - skamp   QUOTE (vincefalks @ Nov 6 2012, 16:29) Th...   Nov 6 2012, 17:40
|- - vincefalks   QUOTE (skamp @ Nov 6 2012, 17:40) QUOTE (...   Nov 6 2012, 18:44
||- - skamp   QUOTE (vincefalks @ Nov 6 2012, 18:44) it...   Nov 6 2012, 18:58
||- - Porcus   QUOTE (vincefalks @ Nov 6 2012, 19:44) it...   Nov 8 2012, 17:33
|- - Destroid   Interesting discussion. I hope the market does not...   Nov 6 2012, 23:21
|- - Porcus   QUOTE (Destroid @ Nov 7 2012, 00:21) I ho...   Nov 8 2012, 17:38
- - greynol   Don't blame flac.exe. It will not take 16-bit...   Nov 6 2012, 17:23
|- - vincefalks   QUOTE (greynol @ Nov 6 2012, 17:23) Don...   Nov 6 2012, 17:47
- - greynol   6dB of gain was applied to the master with no furt...   Nov 6 2012, 17:42
- - greynol   You would really have to go out of your way to do ...   Nov 6 2012, 17:59
- - 2Bdecided   An even smarter analysis can figure out which 24-b...   Nov 8 2012, 17:16
- - pdq   Let's not forget that a file that was up-conve...   Nov 8 2012, 18:27
|- - 2Bdecided   QUOTE (pdq @ Nov 8 2012, 18:27) Let's...   Nov 9 2012, 10:33
|- - julf   QUOTE (pdq @ Nov 8 2012, 18:27) Let's...   Nov 9 2012, 13:39
- - pdq   ...and it makes sense that if the tracks had been ...   Nov 9 2012, 15:11
- - Arnold B. Krueger   QUOTE (vincefalks @ Nov 5 2012, 23:50) I ...   Nov 9 2012, 16:01
- - skamp   Maybe Greynol can help?   Apr 13 2013, 07:41
- - Case   Here's a quick Windows .cmd script trying to d...   Apr 13 2013, 09:39
|- - Sparktank   QUOTE (Case @ Apr 13 2013, 01:39) Here...   Apr 13 2013, 09:59
- - Case   It's meant to be used from command prompt when...   Apr 13 2013, 10:11
- - mjb2006   Thanks for the .cmd version. I suggest modifying ...   Apr 13 2013, 10:40
- - Arnold B. Krueger   QUOTE (vincefalks @ Nov 6 2012, 00:50) I ...   Apr 13 2013, 16:12
|- - skamp   QUOTE (Arnold B. Krueger @ Apr 13 2013, 17...   Apr 13 2013, 17:28
- - greynol   I don't see the point in adding dither when in...   Apr 13 2013, 16:18
|- - Arnold B. Krueger   QUOTE (greynol @ Apr 13 2013, 11:18) I do...   Apr 13 2013, 22:22
|- - Kees de Visser   QUOTE (Arnold B. Krueger @ Apr 13 2013, 22...   Apr 14 2013, 15:23
- - BearcatSandor   Anyone know how to adjust Skamp's script to wo...   Apr 14 2013, 01:00
- - MikeFord   How would this technique rate a file consisting of...   Apr 16 2013, 21:11
- - Sparktank   Regarding the Windows fbits.cmd, I lost the versio...   Dec 20 2014, 05:04
- - Sparktank   Anyone?? I can't even get the original one to ...   Jan 15 2015, 08:39
- - mjb2006   It's not clear what you're asking for. You...   Jan 15 2015, 10:37
- - Case   Batch files require some special care when dealing...   Jan 15 2015, 12:26
RSS Lo-Fi Version Time is now: 30th January 2015 - 05:12
