enhanced aac+ to aac lc
wind
post Nov 2 2012, 09:53
Hi, everyone, has there anybody used enhanced aac+ code(TS 26.410) to encode/decode only aac lc ,without sbr?
I modified the encoder of the enhanced aac+, ,there is no sbr, then when the decoder decode the new .3gp file ,no sbr is decoded, but the outout sample rate is 1/2 downsampled, because aac lc works at 1/2 sample rate, the sbr works at original sample rate, and in the decoder ,it is sbr make it become to original sample rate, but now there is no sbr.
Does anyone know how to make the sample rate of decoder output same as the original input file sample rate, i tried to modify the encoder to encode at original sample rate,but there will be no sound, and if i use 1/2 sample rate .3gp & modify the decoder to change the sample rate and frame size, the sound will sound strange...
or
is that ok if i upsample the new decoder output file (1/2 sample rate ) through matlab?
Thanks in advance.
This post has been edited by wind: Nov 2 2012, 10:29
Dynamic
post Nov 7 2012, 23:00
So that's an interleave function?
Why do you need to interleave mono data? You should only need to interleave multiple channels. Are you perhaps forcing it to interleave mono data as if it were stereo, thus ending up with a stereo file of half the duration, perhaps?
wind
post Nov 8 2012, 13:31
QUOTE (Dynamic @ Nov 7 2012, 23:00) *
the original input file to the encoder is also mono file , there is nothing about stereo.
acturally i don‘t know why it does the interleave, the number of channels change from 1 to 2 after running the ' interleaveSamples' and if i comment out this 'interleaveSamples'. there will be no sound.
From the standard i know i can't encode/decode in mono mode if the bitrate is <=44kbps, so i tried 96kbps.
/* interleave time samples */
interleaveSamples(&TimeDataFloat[0],&TimeDataFloat[frameSize],pTimeDataPcm,frameSize,&numChannels);
static void
interleaveSamples(float *pTimeCh0,
float *pTimeCh1,
short *pTimeOut,
int frameSize,
int *channels)
int i;
for (i=0; i<frameSize; i++)
*pTimeOut++ = (short) *pTimeCh0++;
if(*channels == 2) {
*pTimeOut++ = (short) *pTimeCh1++;
else {
*pTimeOut = *(pTimeOut-1);
*pTimeOut++;
*channels = 2;
RSS Lo-Fi Version Time is now: 26th April 2015 - 21:48
