Can I use the speakers with this amplifier?, Speakers from broken Micro Hi-Fi System
larswes
post Oct 19 2012, 17:12
My Philips MCM7 amplifier is broken (bought it 5-6 years ago).
But i think the speakers from the system is still ok.
I consider to buy a new amplifier for the speakers and i found this compact design Dynavoice D-amp.
Do you think this could be a good combination, for music and tv or other source?
From the MCM7 specs:
• Output Power [of my broken amplifier]:
2 x 50 watts RMS, 100 watts total power
• Main speakers [still ok]:
3-Way Bass Reflex
6 ohm impedance
6.5" aluminium con woofer, 2" Tweeter
Dynavoice D-amp
Specifications:
Nominal Power Output (Left & Right Channel (4Ω): 25W + 25W
Nominal Load Impedance (8Ω): 15W + 15W
Main channel: 4Ω - 8Ω
Input Sensitivity: 300 mV
Overload source emf: ≥2V
Frequency Response: 20 Hz – 20 kHz
THD: ≤1%
S/N: ≥95dB
Channel separating degree: ≥70dB
More info about the Dynavoice (sorry only in swedish): http://www.dynavoice.se/dynavoice-d-amp/63/
This post has been edited by larswes: Oct 19 2012, 17:12
Fedot L
post Oct 20 2012, 00:00
QUOTE (larswes @ Oct 19 2012, 17:12) *
I consider to buy a new amplifier for the speakers…
“• Output Power [of my broken amplifier]:
3-Way Bass Reflex
6 ohm impedance
6.5" aluminium con woofer, 2" Tweeter”
…i found this compact design Dynavoice D-amp.
“Specifications:
THD: ≤1%
S/N: ≥95dB
Channel separating degree: ≥70dB”?
These Dynavoice D-amp Specifications are from the:
http://translate.google.com/translate?js=y...history_state0=
And
http://www.tradera.com/12-v-forstarkare-mi...70613_166584511
is another amplifier.
And
“* Specifikationer:
* Output Power: 180W + 180W
* RMS Power Output: 30W
* Peak Maximum Power Output (PMPO): 180W
* Input Power: 12V 6A DC”
How can an amplifier fed by a “12V 6A DC” (i.e. 72 VA) power supply, be “Output Power: 180W + 180W” (360 W!)?
“* Min. THD: <0.005%”
“Min. THD: <0.005%” is an absurdity as an amp’s THD characteristic. Then MAX THD may be 10%, or more?..
And between THD “≤1%” and “<0.005%” (200 times difference between two very similar devices), do you believe it’s realist? Which of the two may be real?
Why do you wish to buy a 13 V amplifier? Or I’ve misunderstood something? A 13 V amplifier for a home system?
With “THD: ≤1%”? To me, strange for a modern transistor amp.
Why not to buy one of well-known ≈50 W/channel 220 V 50 Hz integrated amplifiers, with a remote control and developed features? And 100 times better THD… There are very moderately priced ones rating 0,01-0,02% THD 20…20000 Hz on the market…
larswes
post Oct 21 2012, 08:49
QUOTE (Fedot L @ Oct 20 2012, 01:00) *
As I said "now i know more" and that was what I was after when i posted here. I will try to find something not to expensive to replace the Philips amp.
QUOTE (Fedot L)
So far i've not found any amp with these spec within my budget. But i found a piece with RMS 2 * 25 W / 220 V that maybe can be ok?
RSS Lo-Fi Version Time is now: 28th May 2015 - 08:30
