Looking for at 120+GB FLAC Player, dimensions L<=6 W<=3 D<=.5
Jonathan217
post Oct 15 2012, 16:10
Before we get started, I've Googled it.
I have a music library that expands at the rate of about one cd every month. I encode all of my music as FLAC files and then lock my little plastic discs away for safe keeping.
I had a Rockboxed iPod with a 60GB drive in it, but I have long since outgrown it. I could have expanded the Hard Drive, but I am looking for something with native FLAC support and better hardware.
I don't mind discontinued devices being listed, but I would like to see what is currently out there too. I'd say the player should provide a minimum of 3 hours of play time on a single charge, 8 would be 'cherry.'
I need to be able to put music on it with out proprietary transfer software.
The player will be plugged into a pair of ATH M50s and will be listened to by someone who puts his hands over his ears when a track from iTunes is played.
A good bonus would be support for 96khz/24bit files, but I'm not holding my breath.
Lastly, I'm looking at spending less than $200USD. If it is a little over budget and meet the aforementioned requirements perfectly, I'd still like to know about it.
Thanks in advance for your time.
Soap
post Oct 19 2012, 14:29
QUOTE (Jonathan217 @ Oct 15 2012, 11:10) *
I am looking for something with native FLAC support...
What is the difference between native FLAC support and Rockbox FLAC support in your mind?
... and better hardware.
Help me understand what the problem with the iPod 5th generation's hardware is and I can better help you.
This post has been edited by Soap: Oct 19 2012, 14:29
Creature of habit.
Jonathan217
post Oct 26 2012, 16:49
QUOTE (Soap @ Oct 19 2012, 22:29) *
The difference in support is based on information I gleaned from Rockbox that pointed out there was a lot of extra work the iPod had to do to decode the FLAC files.
As far as the hardware is concerned, that is based of unverified information that the quality of the audio components in the iPod is mediocre compared to something made by Cowon, for instance.
saratoga
post Oct 26 2012, 17:20
QUOTE (Jonathan217 @ Oct 26 2012, 11:49) *
What do you mean? Why would rockbox have to do "a lot of extra work"? FLAC is a very efficient format . . .
No, the Classic in particular is probably better then anything Cowon makes. Or at least good enough that you shouldn't care about the difference between it and the alternatives.
FWIW, I'd get the Classic and either use ALAC in the apple firmware, or use Rockbox + FLAC.
db1989
post Oct 26 2012, 18:28
QUOTE (saratoga @ Oct 26 2012, 17:20) *
In any case, this site is not for unverified information, particularly about subjective audio quality.
QUOTE (Jonathan217 @ Oct 15 2012, 16:10) *
This is definitely overkill. Whilst I might not have been as adamant as yourlord, I was inclined to agree somewhat, under the impression that you presumably have at least one master copy of your library; in that case, it would make little sense to carry around another if you do not have to (unless of course you want to use that as a backup copy, but we all have some idea of what hard disks can be like). The reason that it makes little sense is that portable usage makes the listener even less likely to encounter artefacts or other perceptual degradation than would listening at home.
But in terms of questionable logic, it makes infinitely less sense to want to preserve a portable copy in a resolution that humans are physiologically incapable of appreciating, even were they to be card-carrying ‹bermensch in a hermeneutically sealed listening chamber.
This post has been edited by db1989: Oct 26 2012, 18:28
- Jonathan217   Looking for at 120+GB FLAC Player, dimensions L<=6 W<=3 D<=.5   Oct 15 2012, 16:10
- - hlloyge   Wasn't there iPod with 160 GB drive? something...   Oct 15 2012, 16:24
- - Arnold B. Krueger   QUOTE (Jonathan217 @ Oct 15 2012, 11:10) ...   Oct 15 2012, 17:20
- - eamon123   The sansa clip might be what you're looking fo...   Oct 18 2012, 14:15
|- - Arnold B. Krueger   QUOTE (eamon123 @ Oct 18 2012, 09:15) The...   Oct 18 2012, 14:37
- - skamp   Put rockbox on a used iPod Classic (160 GB). Much ...   Oct 18 2012, 17:51
- - eahm   Even better if you like lossless, 240GB iPod Class...   Oct 18 2012, 17:54
- - yourlord   I know it's not what you want to hear, but hon...   Oct 18 2012, 21:39
|- - eahm   QUOTE (yourlord @ Oct 18 2012, 13:39) It...   Oct 19 2012, 01:31
- - yourlord   Sorry, I let my love of freedom bias me.. The qual...   Oct 19 2012, 03:01
- - Soap   QUOTE (Jonathan217 @ Oct 15 2012, 11:10) ...   Oct 19 2012, 14:29
|- - J.Philippe   QUOTE (Soap @ Oct 19 2012, 09:29) QUOTE (...   Oct 19 2012, 18:26
|- - Jonathan217   QUOTE (Soap @ Oct 19 2012, 22:29) QUOTE (...   Oct 26 2012, 16:49
|- - saratoga   QUOTE (Jonathan217 @ Oct 26 2012, 11:49) ...   Oct 26 2012, 17:20
|- - db1989   QUOTE (saratoga @ Oct 26 2012, 17:20) QUO...   Oct 26 2012, 18:28
- - Jonathan217   QUOTE (hlloyge @ Oct 16 2012, 00:24) Wasn...   Oct 26 2012, 16:51
- - yourlord   Still, it doesn't make sense. Ipod classic 16...   Oct 26 2012, 18:02
- - greynol   How many 192kbps files can you get on an iPod clas...   Oct 26 2012, 18:20
|- - yourlord   QUOTE (greynol @ Oct 26 2012, 13:20) How ...   Oct 26 2012, 18:39
- - greynol   Can you still use the Classic as a portable hard d...   Oct 26 2012, 18:43
|- - saratoga   QUOTE (greynol @ Oct 26 2012, 13:43) Can ...   Oct 26 2012, 18:57
- - skamp   Yes, you have to tick a checkbox in iTunes, which ...   Oct 26 2012, 18:49
|- - db1989   QUOTE (skamp @ Oct 26 2012, 18:49) Yes, y...   Oct 26 2012, 23:06
- - greynol   So it still behaves like the older iPods and not l...   Oct 26 2012, 19:06
RSS Lo-Fi Version Time is now: 29th July 2015 - 11:31
