Flaws in recent Opus codec?
145dBSPL
post Oct 13 2012, 11:53
Hi everybody,
this is my first post here, even if i read this forum for a quite long time already.
Recently i did some testing on the Opus codec an found a strange behaviour.
I encoded a file with the official 0.1.5 binaries and had a look the frequency response.
Knowing that judging quality with this is useless, i discovered a ~1000Hz /-3dB drop
around 16 kHz which is not present e.g. in Ogg encoded files.
This lead me to encode/decode a linear sweep for comparison and this finally showed
a really messed up response for the Opus encoded sweep in the HF region.
I am not quite sure if it is encoder or decoder related.
For decoding i used the official opusdec and the foobar built-in one.
Opus music sample:
Oggvorbis music sample:
Opus linear sweep:
Oggvorbis linear sweep:
What do you think? Could someone try to replicate or has this been
noticed already?
Thank you.
Cheers!
romor
post Oct 16 2012, 14:40
I noticed similar, maybe same "issue" which I guess it's just opus temperament feature
With any bitrate method,
- at 128 kbps, if I downmix opus file to mono (overlap channels), around 16 kHz there is visible boundary region (maybe related to OP observation)
- at 96 kbps larger low density strip is visible in ~ 12-16 kHz range:
- at 80 kbps there are two large strips
etc
I tested with both opusdec file (44.1k) and opus decoded from foobar (48k).
This "signature" was present on all (10) test files in larger/smaller amount then in example screenshot
scripts: http://goo.gl/M1qVLQ
RSS Lo-Fi Version Time is now: 2nd June 2015 - 16:50
