Command-Line Decoder Wrapper, New official component
Peter
post Oct 11 2012, 10:01
foobar2000 developer
Group: Admin
Summary
This component allows you to comfortably play or convert any audio format with a standalone command-line decoder available, including various exotic formats that do not have native foobar2000 decoder components.
Check the documentation link below for more details.
Links
Home page
Documentation
Have fun.
Rollin
post Oct 12 2012, 17:50
Is it possible to add option to write mp4 tags?
QUOTE (Anakunda @ Oct 12 2012, 16:31) *
The command line for non-piped decoding is eac3to %s %d this i'm afraid however generates a HUGE temp file in the source folder (expectingly 10-20gb in size) which also takes quite a long time before playbak start depending on the drive throughput. I want to avoid this and rather play via pipe ie. no temp wav files creating ....any thoughts..............
I have no problems using eac3to.exe %s stdout.wav for dtshd 24/96 playback.
Peter
post Oct 12 2012, 21:20
Group: Admin
QUOTE (Rollin @ Oct 12 2012, 18:50) *
If there's a scenario where that makes sense (MP4 files that are not decoded by the native MP4 handler - what file type exactly?), sure why not.
Rollin
post Oct 13 2012, 15:47
QUOTE (Peter @ Oct 13 2012, 00:20) *
MPEG-4 ALS in MP4 container.
This post has been edited by Rollin: Oct 13 2012, 15:48
- Peter   Command-Line Decoder Wrapper   Oct 11 2012, 10:01
- - Peter   Attached: configuration file (work-in-progress), t...   Oct 11 2012, 10:10
- - CoRoNe   Thanks a lot. No problems playing LA-files. BUT, I...   Oct 11 2012, 20:15
- - Peter   New version out, misbehavior on space in exe file ...   Oct 11 2012, 21:58
- - Anakunda   Hi! Thank you for versatile decoder. Curious ...   Oct 12 2012, 13:31
- - Rollin   Thanks for this component! Is it possible to...   Oct 12 2012, 17:50
|- - Peter   QUOTE (Rollin @ Oct 12 2012, 18:50) Is it...   Oct 12 2012, 21:20
|- - Rollin   QUOTE (Peter @ Oct 13 2012, 00:20) MP4 fi...   Oct 13 2012, 15:47
- - Peter   Split.   Nov 9 2012, 10:31
- - romor   I wanted to provide example for decoding two files...   Jan 16 2013, 03:53
- - EpicForever   I'm not sure weather this issue is caused by f...   Feb 2 2013, 18:28
|- - Rollin   The reason is ffmpeg. Not foo_input_exe, not foo_d...   Feb 2 2013, 18:53
- - EpicForever   Hm... I thought that it goes like this: 1. foobar...   Feb 2 2013, 20:24
- - lvqcl   Looks like "Convert 5.1 to stereo" plugi...   Feb 2 2013, 20:50
- - EpicForever   Hm... Maybe ffmpeg uses that "wrong" cha...   Feb 2 2013, 23:53
- - CoRoNe   EpicForever: Although Rollin's suggestion work...   Feb 3 2013, 12:29
- - Peter   Channel order handling in downmix DSP changed in f...   Feb 3 2013, 13:28
- - EpicForever   Peter - thank you for permanent (I hope )workarou...   Feb 3 2013, 13:39
- - mariner   Good morning: I have problems with packMP3 files ...   Jul 20 2014, 01:29
- - lvqcl   Try decode command: CODEpackMP3.exe -   Jul 20 2014, 09:39
- - Case   mariner, you need to create a simple wrapper batch...   Jul 20 2014, 18:14
|- - mariner   QUOTE (Case @ Jul 20 2014, 18:14) mariner...   Jul 21 2014, 02:56
- - Skif_off   How can I use folder foobar2000/encoders for decod...   Nov 8 2014, 12:33
- - Skif_off   I put ffmpeg.exe next to foobar2000.exe and it...   Nov 30 2014, 16:29
RSS Lo-Fi Version Time is now: 26th January 2015 - 14:41
