Command-Line Decoder Wrapper, New official component
Peter
post Oct 11 2012, 10:01
foobar2000 developer
Group: Admin
Summary
This component allows you to comfortably play or convert any audio format with a standalone command-line decoder available, including various exotic formats that do not have native foobar2000 decoder components.
Check the documentation link below for more details.
Links
Home page
Documentation
Have fun.
EpicForever
post Feb 2 2013, 18:28
I'm not sure weather this issue is caused by foo_input_exe or foo_dsp_effect so I post it in both threads, maybe authors will find what can be wrong.
My DSP chain looks like this: Skip Silence - > convert 5.1 to stereo -> convert mono to stereo -> playback rate shift. Playback Rate Shift requires 2ch signal. So used DSP effects provide such signal.
When I play 6ch FLAC encoded from DVD-A everything works OK. Signal is downmixed and I can use PRS actively or just unused, but present in chain. But when I play audio from video files and I use foo_input_exe to wrap signal decompressed by FFMPEG.exe from that files, then 6ch audio decoded from .VOB file generates error: "Unrecoverable playback error: Illegal number of channels". It means that Playback Rate Shift gets 6ch audio instead of 2ch - like "convert 5.1 to stereo" wasn't working or something like this... Why? What can I do to avoid this error in such playback configuration?
- Peter   Command-Line Decoder Wrapper   Oct 11 2012, 10:01
- - Peter   Attached: configuration file (work-in-progress), t...   Oct 11 2012, 10:10
- - CoRoNe   Thanks a lot. No problems playing LA-files. BUT, I...   Oct 11 2012, 20:15
- - Peter   New version out, misbehavior on space in exe file ...   Oct 11 2012, 21:58
- - Anakunda   Hi! Thank you for versatile decoder. Curious ...   Oct 12 2012, 13:31
- - Rollin   Thanks for this component! Is it possible to...   Oct 12 2012, 17:50
|- - Peter   QUOTE (Rollin @ Oct 12 2012, 18:50) Is it...   Oct 12 2012, 21:20
|- - Rollin   QUOTE (Peter @ Oct 13 2012, 00:20) MP4 fi...   Oct 13 2012, 15:47
- - Peter   Split.   Nov 9 2012, 10:31
- - romor   I wanted to provide example for decoding two files...   Jan 16 2013, 03:53
- - EpicForever   I'm not sure weather this issue is caused by f...   Feb 2 2013, 18:28
|- - Rollin   The reason is ffmpeg. Not foo_input_exe, not foo_d...   Feb 2 2013, 18:53
- - EpicForever   Hm... I thought that it goes like this: 1. foobar...   Feb 2 2013, 20:24
- - lvqcl   Looks like "Convert 5.1 to stereo" plugi...   Feb 2 2013, 20:50
- - EpicForever   Hm... Maybe ffmpeg uses that "wrong" cha...   Feb 2 2013, 23:53
- - CoRoNe   EpicForever: Although Rollin's suggestion work...   Feb 3 2013, 12:29
- - Peter   Channel order handling in downmix DSP changed in f...   Feb 3 2013, 13:28
- - EpicForever   Peter - thank you for permanent (I hope )workarou...   Feb 3 2013, 13:39
- - mariner   Good morning: I have problems with packMP3 files ...   Jul 20 2014, 01:29
- - lvqcl   Try decode command: CODEpackMP3.exe -   Jul 20 2014, 09:39
- - Case   mariner, you need to create a simple wrapper batch...   Jul 20 2014, 18:14
|- - mariner   QUOTE (Case @ Jul 20 2014, 18:14) mariner...   Jul 21 2014, 02:56
- - Skif_off   How can I use folder foobar2000/encoders for decod...   Nov 8 2014, 12:33
- - Skif_off   I put ffmpeg.exe next to foobar2000.exe and it...   Nov 30 2014, 16:29
RSS Lo-Fi Version Time is now: 28th August 2015 - 14:20
