Into which bit should noise be added in order to dither 32bit file to
amiti
post Oct 6 2012, 22:54
When adding noise to audio data in order to dither it into lower bit depth, should the noise be added to higher bit than the desired outcome bit depth? For example when 24bit data is meant to be dithered into 16 bit , the white noise should be added between the 17th to the 24th bits of the original file?
I saw this plugin for foobar : foo_dsp_noise. With this plugin foobar can add TPDF noise up into the 24th bit but not higher. Does this mean it is usable only for dithering to 16bit and not to 24bit output?
amiti
post Oct 8 2012, 14:04
You should start counting from the least-significant-bit (lsb), i.e. bit 0. Therefore dither would be applied at the the eighth bit.
Nick , so you are saying that dither noise should be added at the 17th bit(if counting from the msb side)? Theoretically then , when dithering from 32bit to 24 bits (although some would consider it useless) noise should be added from the 25th bit (when counting from most significant bit side)?
RSS Lo-Fi Version Time is now: 5th May 2015 - 14:40
