Need Clarification on TOS8
kstuart
post Sep 27 2012, 02:05
8. All members that put forth a statement concerning subjective sound quality, must -- to the best of their ability -- provide objective support for their claims. Acceptable means of support are double blind listening tests (ABX or ABC/HR) demonstrating that the member can discern a difference perceptually, together with a test sample to allow others to reproduce their findings. Graphs, non-blind listening tests, waveform difference comparisons, and so on, are not acceptable means of providing support.
I've read some of the linked discussion on TOS8 as well.
All of it covers objective vs subjective.
What IMHO needs clarification is the first phrase:
" All members that put forth a statement concerning subjective sound quality... "
Can a mod or admin clarify - in an official way - "put forth a statement" ?
For example, if I were to post "Joe Blow, the editor of AudiophileGuys magazine, says that the new Megabuck 9000 amplifier sounds better than any other amplifier", technically that would violate TOS8 - even though that Joe said that, is a fact that is easily substantiated by a reference to AudiophileGuys magazine web site. The statement is what someone said, not actually making a claim about audio.
Clearly, that is not the intent of TOS8. Rather it seems to me that the intent is with regards statements like "flac files always sound better than 320k MP3s" which would then need the substantiation required by TOS8.
Okay, then here is where the clarification is needed.
If I were to state in a post " In my setup, using ASIO output seems to sound better than WASAPI output. " - is that a violation of TOS8 ?
The discussion that TOS8 links to, suggests that TOS8 is designed to prevent statements of sound quality "fact" - as opposed to statements of personal observations. In other words, "ASIO always sounds better than WASAPI" is a TOS8 violation, while " In my setup, using ASIO output seems to sound better than WASAPI output " is just reporting an observation - and NOT an assertion of audio fact.
Am I correct, and is that how you would differentiate ?
This post has been edited by kstuart: Sep 27 2012, 02:12
Wyld Stallyn
post Apr 4 2013, 15:46
My OpenOffice copy isn't able to open the provided document.
I don't really understand what you are saying. Are you talking about influences of HRTF and uh, I forgot the term for this, uhm, the influence of the room? tongue.gif
That seems to me to be completely irrelevant for showing a difference between two signals though. If both signals have been recorded under the exactly same circumstances, if there is any noteworthy difference in the waveform then that should mean that there is a notable difference caused by the different component or settings, no matter how much that signal gets distorted by physics. If physical effects would cause a difference of +5 dB at a certain frequency in one circumstance and -8 in the other, would not the very same differences be applied to the altered signal on top of the alteration, making the alteration still equally perceptable (if it is in the realm of perceptability at all of course, we could argue that no claims for this can earnestly be made below a certain point that is not relevant to the average listener, who is the one going to be influenced into purchasing the product after all) due to the preserved difference in both circumstances? This should be the case, otherwise even ABX testing in a specific circumstance could not provide the slightest hint of orientation for different circumstances either, and it'd probably mean that there are no general physical patterns to rely upon, which is evidently not the case.
Or is it the case that other factors are influenced that are not representable with a waveform? Wouldn't just providing the relevant measurements satisfy our needs then? If need be maybe all sorts of measurements that can possibly be made, even if that seems like a logistical nightmare to me where I'd rather conduct an ABX test. Of course, what I would prefer to do for my nerves' sake is not the matter here.
This post has been edited by Wyld Stallyn: Apr 4 2013, 15:48
Porcus
post Apr 4 2013, 16:02
I really don't understand what you are saying either, so I might have misinterpreted:
QUOTE (Wyld Stallyn @ Apr 4 2013, 16:46) *
If what you are suggesting is the following:
- Suppose that two operations A and B transforming signal #0 into signals #a and #1b are such that #a and #b are not audibly distinguishable
- If the same transformation C is applied to both the latter, resulting in #ac and #bc, then since #a and #b were transparent, so will #ac and #bc also be
... then you are certainly wrong. (Counterargument: make an EQ or a volume change; scale it up so that the alteration and the negative one are both inaudible, but one is very close to; then #a is #0 plus a delta, and #b is #0 minus the same. Now let C be the reverse operation of one of them. Operation C will amplify one transformation and annihilate the other.)
- kstuart   Need Clarification on TOS8   Sep 27 2012, 02:05
- - pdq   My unofficial response is that even a statement of...   Sep 27 2012, 10:55
|- - greynol   QUOTE (pdq @ Sep 27 2012, 02:55) Also, I ...   Sep 27 2012, 17:16
- - Canar   QUOTE (kstuart @ Sep 26 2012, 18:05) In o...   Sep 27 2012, 14:58
|- - Porcus   QUOTE (Canar @ Sep 27 2012, 15:58) Show u...   Sep 27 2012, 17:18
- - greynol   ...and it is done over and over again. You make a...   Sep 27 2012, 17:57
|- - kstuart   QUOTE (greynol @ Sep 27 2012, 09:57) Ever...   Sep 27 2012, 19:00
||- - fuflo   QUOTE (kstuart @ Sep 27 2012, 21:00) So, ...   Sep 27 2012, 19:36
|||- - Porcus   QUOTE (fuflo @ Sep 27 2012, 20:36) QUOTE ...   Sep 27 2012, 19:53
||- - greynol   QUOTE (kstuart @ Sep 27 2012, 11:00) The ...   Sep 27 2012, 20:02
|- - Porcus   QUOTE (greynol @ Sep 27 2012, 18:57) Ever...   Sep 27 2012, 19:50
|- - greynol   QUOTE (Porcus @ Sep 27 2012, 11:50) But y...   Sep 27 2012, 20:00
- - Canar   QUOTE (kstuart @ Sep 26 2012, 18:05) ...   Sep 27 2012, 22:52
|- - kstuart   QUOTE (Canar @ Sep 27 2012, 14:52) QUOTE ...   Sep 27 2012, 23:33
|- - greynol   QUOTE (kstuart @ Sep 27 2012, 15:33) User...   Sep 28 2012, 01:36
|- - Porcus   QUOTE (kstuart @ Sep 28 2012, 00:33) User...   Sep 28 2012, 07:46
|- - skamp   QUOTE (kstuart @ Sep 28 2012, 00:33) User...   Sep 28 2012, 09:56
- - [JAZ]   I think we all understand what the rule is meant t...   Sep 28 2012, 19:36
|- - Porcus   QUOTE ([JAZ] @ Sep 28 2012, 20:36...   Sep 29 2012, 11:17
|- - kstuart   No matter what word you use, people divide themsel...   Nov 8 2012, 19:05
- - greynol   As far as forum policy is concerned this is nonsen...   Nov 8 2012, 19:16
- - Garf   The idea of TOS8 is to make a simplified explanati...   Nov 12 2012, 21:28
|- - kstuart   QUOTE (Garf @ Nov 12 2012, 13:28) The phi...   Nov 12 2012, 22:19
|- - Porcus   QUOTE (kstuart @ Nov 12 2012, 23:19) Huma...   Nov 12 2012, 22:59
|- - Garf   QUOTE (kstuart @ Nov 12 2012, 22:19) QUOT...   Nov 12 2012, 23:05
- - Wyld Stallyn   I would like to ask something regarding TOS8 too. ...   Apr 4 2013, 15:01
- - 2Bdecided   Some audible differences are invisible, some inaud...   Apr 4 2013, 15:25
|- - dhromed   QUOTE (2Bdecided @ Apr 4 2013, 16:25) Som...   Apr 5 2013, 09:14
- - Wyld Stallyn   My OpenOffice copy isn't able to open the prov...   Apr 4 2013, 15:46
|- - Porcus   I really don't understand what you are saying ...   Apr 4 2013, 16:02
- - Wyld Stallyn   This may seem a bit dumb, but I actually didn...   Apr 4 2013, 16:30
- - greynol   We don't hear with our eyes. /enddiscussion   Apr 4 2013, 16:32
|- - Wyld Stallyn   QUOTE (greynol @ Apr 4 2013, 17:32) We do...   Apr 4 2013, 16:46
|- - greynol   QUOTE (Wyld Stallyn @ Apr 4 2013, 08:46) ...   Apr 4 2013, 18:01
|- - Wyld Stallyn   QUOTE (greynol @ Apr 4 2013, 19:01) QUOTE...   Apr 4 2013, 18:54
- - 2Bdecided   First read and understand this... http://en.wikipe...   Apr 4 2013, 16:43
- - pdq   My interpretation of TOS #8 is this: If a claim i...   Apr 4 2013, 18:03
- - greynol   It has been sufficiently well laid out in countles...   Apr 4 2013, 19:03
- - Mach-X   I myself have wondered how this applies to stateme...   Apr 6 2013, 01:25
- - Mach-X   Otoh, tos8 is fairly simple. Even established fact...   Apr 6 2013, 01:32
RSS Lo-Fi Version Time is now: 31st August 2015 - 06:24
