Pops and clicks using official ASIO in Windows 8 with foobar, but no p, Please add more priority options
PelPix
post Sep 22 2012, 06:01
Microsoft seems to have written a new scheduler for handling tasks better in 8, and it works, but the priority settings now mean different things, and anything below the redesigned "Realtime" setting means it's handled in a way that is not suitable for audio playback on some ASIO drivers, so it pops at every latency. The easiest solution is to add ALL of the priority options to the ASIO component instead of just having a tickbox for "high priority."
This post has been edited by PelPix: Sep 22 2012, 06:12
Replies (1 - 14)
PelPix
post Oct 5 2012, 23:04
Windows 8 users, if you're experiencing pops, try the fix for yourself!
Open Task Manager and set the ASIO host's priority to real-time. Problem solved!
fuflo
post Oct 5 2012, 23:54
are you using native asio drivers or asio4all? personally, with tascam us-144mkII i had/have no issues with asio at all ( native driver ) on win8.
PelPix
post Oct 19 2012, 03:52
QUOTE (fuflo @ Oct 5 2012, 18:54) *
Native. Setting priority to "Realtime" universally fixes them, and has caused no instability in 10 continuous hours of use (so faR).
neograniceni
post Nov 15 2012, 21:43
Would be really nice if such an option to set asio host priority to realtime would be implemented in some future release.
This post has been edited by neograniceni: Nov 15 2012, 21:45
neograniceni
post Nov 16 2012, 14:50
QUOTE (PelPix @ Oct 5 2012, 23:04) *
Well, the problem is that foobar closes/reopens ASIO host every time you start to play song, or when the song is paused/stopped, and it's priority is reset to normal or high which is not enough to work without problems under Win8. So I made a little tray tool to detect and set/keep ASIOhost32.exe or ASIOhost64.exe priority to realtime. Will test it today, and if everything would work I'll share it here.
neograniceni
post Nov 16 2012, 17:53
Well, here it is. It works OK for me using foobar 1.1.16, ASIO 2.1.2, Asus Xonar ST with Unixonar driver 1.64 and Windows 8 Pro x64. You can put this to your startup if you want. You can download it from here. Disclaimer: use it on your own responsibility.
Edit: just found there could be multiple asiohosts opened at the same time in foobar. e.g. if you open asio properties from settings while playing music through asio out, or vice versa. Only the first (oldest) asiohost process will be set to realtime priority. I have no intention to deal with that 'coz messing with the ASIO settings while playing music is not something we should be doing anyway. Hope foobar will get an option to set ASIO host realtime priority in some future release, so this tool would become unnecessary.
This post has been edited by neograniceni: Nov 16 2012, 18:29
neograniceni
post Nov 24 2012, 21:10
BTW be sure to run it as an administrator (give admin privileges to the shortcut or .exe file) !
neograniceni
post Feb 23 2013, 19:28
Version 1.1. update: no longer need to run as administrator, now runs through Windows UAC. Link is the same as above.
tato
post Sep 8 2013, 06:33
QUOTE (neograniceni @ Nov 15 2012, 21:43) *
This is just to report that I experienced that ASIO host real time priority is crucial for ASIO Lynx driver running in win 7.
Even in a system where latency looks not to be an issue.
Infact, I was looking for a workaround for my Lynx two B card (thanks for the nice piece of software).
I strongly encourage to implement real time priority choice in foobar ASIO tab.
As far as I checked in my system (Athlon 64x2 3600+) it does not affect stability.
neograniceni
post Nov 30 2013, 15:15
Seems the problem no longer exists in Win 8.1. foobar 1.2.9, Asus Xonar ST with latest Asus driver, not a single pop/skip since Win8 -> Win8.1 upgrade.
neograniceni
post Dec 1 2013, 15:26
QUOTE (neograniceni @ Nov 30 2013, 15:15) *
Huh, the problem is back unsure.gif .
Propheticus
post Dec 1 2013, 16:47
Check your anti-virus/firewall settings. Some cause high DPC latencies on network interfaces when surfing the web and even more so when torrrenting. This causes the system to be unable to process audio/low latency tasks properly. When you encounter this issue a next time use LatencyMon to see if/which drivers are causing the high DPC latency. In my case Avast Internet Security's Firewall caused ndis.sys (network driver interface) latency to spike. Malwarebytes Anti-Malware's Malicious website blocking feature does as well.
My 'solution' (more like a workaround) was uninstalling the Avast firewall and revert to using Windows 8.1's built in firewall and disabling the malicious website blocking* in MBAM.
Also, the Asus drivers are pretty awful. Try these: http://maxedtech.com/asus-xonar-unified-drivers/
*; Have got features like this already anyway in Chrome itself and via OpenDNS web filtering and Avast browser plugin.
This post has been edited by Propheticus: Dec 1 2013, 16:51
lucian.pescaru
post Dec 4 2014, 15:47
QUOTE (neograniceni @ Nov 15 2012, 22:43) *
I subscribe, I'm using an ASUS STX and clicks & pops but dissapears when asio host is set to realtime priority instead of high.
Juha
post Dec 6 2014, 23:40
Post #15
QUOTE (PelPix @ Sep 22 2012, 08:01) *
Which latency buffer are you talking about ... ASIO I/O buffer or foobar2k playback buffer?
If you set the ASIO I/O buffer to say 50ms does it still give issues (on foobar2k you get the ASIO dialog opened by double clicking the ASIO device name in ASIO drivers list box) ? If it does then have you ever checked if your system is working well for audio streaming? (use tools: http://www.thesycon.de/deu/latency_check.shtml or http://www.resplendence.com/latencymon)
RSS Lo-Fi Version Time is now: 28th March 2015 - 17:13
