What is the compression percentage of your FLAC library?
JJZolx
post Sep 22 2012, 03:32
I've always been curious about the average compression rate across my whole FLAC library.
My library is just shy of 36,000 files, with a makeup of about 40% rock, 40% jazz, and the remainder a mixture of bluegrass, country, classical, folk, rap, electronic, etc. It's all encoded at the default -5 level, and the tagging consists of basic text fields, with no embedded images. I compared the total file sizes in bytes to the calculated expanded music size.
It worked out to 41.9% compression on the entire library.
Total FLAC files size: 925.092 GB (993,310,377,824 bytes)
Total uncompressed size: 1580.926 GB (1,708,243,555,030 bytes)
Ratio: 0.581
Compression: 41.9%
A_Man_Eating_Duc...
post Sep 26 2012, 07:05
mine is
                GB            MB             B               Compression
WAV            293.36    300,400.54    314,992,792,464.00    100.00%
FLAC -0        212.42    217,521.94    228,088,285,396.00     72.41%
FLAC -1        207.16    212,131.17    222,435,657,072.00     70.62%
FLAC -2        206.64    211,595.27    221,873,717,728.00     70.44%
FLAC -3        202.06    206,911.12    216,962,038,256.00     68.88%
FLAC -4        196.14    200,851.75    210,608,326,464.00     66.86%
FLAC -5        195.73    200,430.36    210,166,468,830.00     66.72%
FLAC -6        195.72    200,421.93    210,157,620,477.00     66.72%
FLAC -7        195.47    200,160.16    209,883,137,584.00     66.63%
FLAC -8        195.06    199,746.01    209,448,876,032.00     66.49%
Mainly rock music
I'm doing a lossless encoder compression test at the moment with FLAC, ALAC, Wavpack, LA, Monkeys Audio, Optimfrog, Shorten, Takc and TTA. It's taking forever to complete but i'll start a new thread with the results smile.gif
Porcus
post Sep 26 2012, 19:10
QUOTE (shakey_snake @ Sep 26 2012, 07:21) *
Tool : reference libFLAC 1.2.1 20070917 (99.0%); reference libFLAC 1.1.3 20061120 (0.7%); reference libFLAC 1.1.2 20050205 (0.1%)
Sidenote: I have a quite narrow window for displaying properties, so I got so tired at having to scroll over the “reference libFLAC” entries in order to read the LAME's, that I re-encoded my 1.1.*'s. Took a couple of days (copying backup, converting and bit-verifying ... I don't trust the --force) and likely gave room for another 50 Cent of music, pun intended.
QUOTE (A_Man_Eating_Duck @ Sep 26 2012, 08:05) *
Is it environment-friendly, balancing the energy use against your having to skip a step in the upgrade cycle waiting for the the job to finish, or did you have to set aside one computer for this task? wink.gif
- JJZolx   What is the compression percentage of your FLAC library?   Sep 22 2012, 03:32
- - Porcus   All encoded with -8, figures reported by foobar200...   Sep 22 2012, 10:56
- - JJZolx   So only 35% and 38.6%, respectively. Interesting.   Sep 22 2012, 14:59
- - xnor   I limited results to: %codec% IS flac AND %__bitsp...   Sep 22 2012, 15:42
- - JJZolx   Man, that's only 30.3%. A sample size of thre...   Sep 22 2012, 17:09
- - [JAZ]   you didn't calculate Porcus's values corre...   Sep 22 2012, 18:38
|- - JJZolx   Thanks. The 614 kbps calculation was wrong, but as...   Sep 22 2012, 19:03
- - xnor   The files I selected above have a total duration o...   Sep 22 2012, 19:09
- - [JAZ]   What is wrong is the assumtion that kilobits per s...   Sep 22 2012, 19:11
- - xnor   Afaik kbit/s means kilo bits per second = 10^3 bit...   Sep 22 2012, 19:15
- - Porcus   As long as the denominator of 1411.2 k has the sam...   Sep 23 2012, 13:48
- - Remedial Sound   FWIW my lossless library is "only" 3,800...   Sep 23 2012, 19:50
- - shakey_snake   CODEDuration : 1wk 6d 18:13:27.801 ...   Sep 26 2012, 06:21
- - A_Man_Eating_Duck   mine is CODE GB MB B Compression WAV...   Sep 26 2012, 07:05
|- - Porcus   QUOTE (shakey_snake @ Sep 26 2012, 07:21)...   Sep 26 2012, 19:10
- - Kohlrabi   I only have FLAC -8 files, and filtering via ...   Sep 26 2012, 08:09
- - A_Man_Eating_Duck   Ha The encode script i'm running is only che...   Sep 27 2012, 23:56
- - tuffy   Not counting the metadata blocks, it works out to:...   Sep 28 2012, 14:33
|- - godrick   QUOTE (tuffy @ Sep 28 2012, 15:33) Not co...   Oct 6 2012, 22:58
|- - tuffy   QUOTE (godrick @ Oct 6 2012, 16:58) Tuffy...   Oct 7 2012, 02:52
|- - godrick   QUOTE (tuffy @ Oct 7 2012, 03:52) QUOTE (...   Oct 10 2012, 00:08
|- - tuffy   QUOTE (godrick @ Oct 9 2012, 18:08) To ch...   Oct 10 2012, 14:21
- - imre_herceg   My library is about 95% Classical music. Average ...   Oct 6 2012, 15:35
- - SigHunter   my FLAC library has an average of 930 kbps which m...   Oct 12 2012, 12:14
- - godrick   tuffy, thank you for posting the script - it works...   Oct 14 2012, 14:21
RSS Lo-Fi Version Time is now: 3rd March 2015 - 18:38
