Time stretching/pitch shifting without DSP, possible or not?
bennetng
post Sep 18 2012, 10:47
I mean time stretching without changing pitch and pitch shifting without changing speed.
I ask this because my friend recently purchased a turntable (Stanton ST150) and it has time stretch function.
http://www.stantondj.com/pdf/products/turn...t150_manual.pdf
The manual says
Note: This turntable has separate analog and digital circuits. If you are
looking for a purely analog signal, use the Phono output. For access to
the Key correction feature use the Line output or S/P DIF output.
Note: Key lock and Digital output
processing is only available when the LINE
output is used.
So from my common sense and English level (not my native language), the line out is in fact converted from digital. But my friend insisted on thinking that the processing is done in analog domain and said if EQ can be done in analog domain, why time stretching/ pitch shifting can't?
What is your opinion?
mzil
post Sep 18 2012, 16:43
It is possible to do analog pitch shifting although I doubt any TT on the market does.
Arnold B. Kruege...
post Sep 20 2012, 19:11
QUOTE (mzil @ Sep 18 2012, 11:43) *
Time stretch/compress without pitch changing can be done using a special tape playback device. Its all mechanical. It uses one of the techniques that is used today, only implemented in the analog domain.
Basically, you chop the music up into snippets, and then string the snippets back together either some duplicated (time stretch) or all somewhat overlapped (time compress) while doing something like cross-fades to make the snippets sound like there are smooth transitions between them.
In the analog version, the snippets are obtained from the source tape using tape heads on a fast-spinning drum.
I suspect that the bucket-brigade implementations did something similar, using the bucket-brigade in place of the tape.
- bennetng   Time stretching/pitch shifting without DSP   Sep 18 2012, 10:47
- - dumdidum   this is def done digitally. the point is, many DJ...   Sep 18 2012, 11:01
- - bennetng   QUOTE but people are still fully convinced that th...   Sep 18 2012, 14:14
|- - dumdidum   QUOTE (bennetng @ Sep 18 2012, 15:14) QUO...   Sep 18 2012, 15:52
|- - greynol   QUOTE (bennetng @ Sep 18 2012, 06:14) QUO...   Sep 18 2012, 18:15
|- - bennetng   QUOTE (greynol @ Sep 19 2012, 01:15) QUOT...   Sep 18 2012, 18:26
|- - greynol   QUOTE (bennetng @ Sep 18 2012, 10:26) Ple...   Sep 18 2012, 18:37
- - mzil   It is possible to do analog pitch shifting althoug...   Sep 18 2012, 16:43
|- - pdq   QUOTE (mzil @ Sep 18 2012, 11:43) It is p...   Sep 18 2012, 17:26
||- - benski   QUOTE (pdq @ Sep 18 2012, 12:26) QUOTE (m...   Sep 18 2012, 17:49
||- - pdq   QUOTE (benski @ Sep 18 2012, 12:49) There...   Sep 18 2012, 17:56
|- - Arnold B. Krueger   QUOTE (mzil @ Sep 18 2012, 11:43) It is p...   Sep 20 2012, 19:11
- - bennetng   So are there any dedicated analog machines doing t...   Sep 18 2012, 17:06
- - dumdidum   QUOTE (pdq @ Sep 18 2012, 18:26) QUOTE (m...   Sep 18 2012, 17:42
|- - benski   QUOTE (dumdidum @ Sep 18 2012, 12:42) QUO...   Sep 18 2012, 17:50
|- - mzil   QUOTE (benski @ Sep 18 2012, 12:50) QUOTE...   Sep 18 2012, 18:57
- - John_Siau   I seem to recall that there were analog frequency-...   Sep 18 2012, 19:36
- - mzil   A 1968 example of the tape based "Electro Rat...   Sep 18 2012, 19:44
- - John_Siau   Here is a link to an old BBD data sheet from 1975....   Sep 18 2012, 19:47
- - bennetng   Thanks for the explanations. Then I guess the anal...   Sep 18 2012, 19:59
- - krabapple   On a two recent remixes by Steve Wilson (one the 1...   Sep 19 2012, 17:30
|- - bennetng   Most samplers/romplers support this kind of pitch ...   Sep 19 2012, 17:55
|- - mzil   QUOTE (krabapple @ Sep 19 2012, 12:30) It...   Sep 19 2012, 18:30
- - greynol   I don't think pitch correction which also chan...   Sep 19 2012, 18:46
|- - krabapple   QUOTE (greynol @ Sep 19 2012, 13:46) I do...   Sep 19 2012, 20:40
- - greynol   From what I understand of Wilson, he's not exa...   Sep 19 2012, 21:46
|- - krabapple   QUOTE (greynol @ Sep 19 2012, 16:46) From...   Sep 20 2012, 00:03
- - krabapple   so, just for giggles, using Audition 1.0 's ...   Sep 27 2012, 00:09
RSS Lo-Fi Version Time is now: 30th January 2015 - 18:01
