Discussion of v1.1.15’s changes to handling of rating field in ID3v2, [posts #6–13 split from final release thread]
someone8
post Sep 15 2012, 14:02
Previously, I always used a rating scheme which also incorporates one decimal place (mostly .5). But after the recent rating tag change
QUOTE (db1989 @ Sep 15 2012, 12:45) *
■ ID3v2: “rating” tags now compatible with Windows Media Player (beta 2).
, my old habit can't be realized anymore, as only the number without the decimal places is saved (to assure WMP compatibility). However, if write a "6" (or any higher number) in the rating tag with foobar, it is saved but will never be compatible with WMP. So can the developers please enable the possibility to save floating numbers again, and only write WMP compatible rating tags, if the written rating is [1 2 3 4 5]? This would help me a lot, because I wouldn't have to modify my whole music library to use a custom rating tag or switching to a [1 2 3 ... 10] (from a [1.0 1.5 2.0 2.5 ... 5]) rating.
Thanks in advance!
neothe0ne
post Sep 15 2012, 22:31
I think a nice compromise would be having an advanced option to toggle what the Rating tag is saved to. (So that we can turn off the WMP compatibility)
- someone8   Discussion of v1.1.15’s changes to handling of rating field in ID3v2   Sep 15 2012, 14:02
- - q-stankovic   Why don't you use just another tag? Instead...   Sep 15 2012, 16:38
- - someone8   As I already said, this would be an option but qui...   Sep 15 2012, 17:39
- - MDMA   It's not an effort to apply it to the whole li...   Sep 15 2012, 17:42
- - someone8   OK, thanks. I will do that. But still, strange beh...   Sep 15 2012, 18:24
- - shakey_snake   QUOTE Did anyone stop to consider the possibility ...   Sep 15 2012, 19:46
- - BenB   I don't think foobar writing a POPM frame belo...   Sep 15 2012, 21:01
- - neothe0ne   I think a nice compromise would be having an advan...   Sep 15 2012, 22:31
|- - shakey_snake   QUOTE (BenB @ Sep 15 2012, 16:01) I don...   Sep 15 2012, 23:20
|- - BenB   QUOTE (shakey_snake @ Sep 15 2012, 17:20)...   Sep 16 2012, 00:59
|- - shakey_snake   QUOTE (BenB @ Sep 15 2012, 19:59) I'm...   Sep 17 2012, 13:47
- - q-stankovic   If the aim is just to avoid the same tag in two di...   Sep 16 2012, 00:52
- - EpicForever   QUOTE (q-stankovic @ Sep 16 2012, 00...   Sep 16 2012, 21:00
- - db1989   QUOTE (BenB @ Sep 15 2012, 19:32) QUOTE (...   Sep 17 2012, 12:32
- - Defrance   I'd like to explain the issue this implementat...   Sep 25 2012, 07:04
- - Emerelle   +1 for the suggestion to make TXXX rating tags an ...   Sep 27 2012, 11:11
|- - shakey_snake   QUOTE (Emerelle @ Sep 27 2012, 06:11) +1 ...   Sep 27 2012, 13:50
- - Emerelle   Exactly, not wmp. Any other software I tried so fa...   Sep 27 2012, 15:25
- - Defrance   Other than a few bytes of space per file, what is ...   Sep 27 2012, 20:34
|- - trelain   QUOTE (Defrance @ Sep 27 2012, 14:34) Oth...   Oct 8 2012, 04:33
- - trelain   Couple of corrections after more research. On a ...   Oct 8 2012, 20:35
|- - shakey_snake   QUOTE (trelain @ Oct 8 2012, 15:35) Coupl...   Oct 8 2012, 22:47
- - Sandrine   I am not sure I understand all the implications of...   Oct 19 2012, 14:26
- - BenB   foobar 1.1.16 beta 1 has been released and the fol...   Oct 20 2012, 18:20
|- - trelain   QUOTE (BenB @ Oct 20 2012, 12:20) foobar ...   Oct 22 2012, 23:02
- - Sandrine   The question remains - which to choose? ... see po...   Oct 20 2012, 20:59
- - BenB   It's a matter of preference/necessity. If you...   Oct 20 2012, 22:35
- - roc   +1, I'm sure that would help out a lot of peop...   Nov 6 2012, 01:53
|- - shakey_snake   QUOTE (roc @ Nov 5 2012, 19:53) Questions...   Nov 6 2012, 04:53
- - trelain   You are seeing a different interpretive "spre...   Nov 6 2012, 13:23
- - roc   Thanks for the additional info shakey_snake, trela...   Nov 6 2012, 16:17
RSS Lo-Fi Version Time is now: 18th April 2015 - 18:44
