New iTunes, new CoreAudioToolbox.dll, iTunes 10.7.0.21, CoreAudioToolbox.dll 7.9.8.1
eahm
post Sep 12 2012, 21:02
iTunes 10.7.0.21, CoreAudioToolbox.dll 7.9.8.1. Waiting for some expert to tell what's new.
Pink Floyd - The Dark Side of The Moon -V63 with 7.9.7.9 = 43.2MB, avg. bitrate 139 Kbps / -V63 with 7.9.8.1 = 42.6MB, avg. bitrate 137 Kbps
Pink Floyd - Wish You Were Here -V63 with 7.9.7.9 = 43.2MB, avg. bitrate 135 Kbps / -V63 with 7.9.8.1 = 41.7MB, avg. bitrate 130 Kbps
This post has been edited by eahm: Sep 12 2012, 21:16
eahm
post Sep 13 2012, 06:19
Thank you for the update.
Did anything change in terms of quality for AAC? I'm asking because the avg. bitrate for True VBR is lower and even the size is.
This post has been edited by eahm: Sep 13 2012, 06:34
- eahm   New iTunes, new CoreAudioToolbox.dll   Sep 12 2012, 21:02
- - eahm   1406 -V63 songs + covers = 7.9.7.9 5.48GB / 7.9.8....   Sep 12 2012, 22:26
- - kornchild2002   According to Apple, today's update was only in...   Sep 12 2012, 23:48
- - eahm   Right after I've reconverted everything I was ...   Sep 13 2012, 00:17
- - nu774   Released qaac 1.41 now. There was a format change...   Sep 13 2012, 06:00
- - eahm   Thank you for the update. Did anything change in ...   Sep 13 2012, 06:19
|- - nu774   QUOTE (eahm @ Sep 13 2012, 14:19) Did any...   Sep 13 2012, 07:07
- - Anakunda   I reencoded an album earlier encoded with CoreAudi...   Sep 13 2012, 20:31
|- - dhromed   QUOTE (Anakunda @ Sep 13 2012, 21:31) Any...   Sep 13 2012, 22:34
- - mixminus1   The lowpass frequency appears to be the same - bey...   Sep 13 2012, 20:40
- - eahm   Bit-Comparing two files made with 7.9.7.9 and 7.9....   Sep 14 2012, 00:17
- - kornchild2002   I don't think much can be said other than the ...   Sep 14 2012, 00:28
|- - RobertoDomenico   QUOTE (kornchild2002 @ Sep 14 2012, 00:28...   Sep 20 2012, 02:02
- - neothe0ne   TVBR 91 appears to have no difference between qaac...   Sep 14 2012, 06:58
- - eahm   neothe0ne, you may want to research how qaac works...   Sep 14 2012, 07:32
|- - neothe0ne   QUOTE (eahm @ Sep 14 2012, 02:32) neothe0...   Sep 14 2012, 09:06
|- - eahm   QUOTE (neothe0ne @ Sep 14 2012, 01:06) QU...   Sep 14 2012, 09:29
|- - neothe0ne   QUOTE (eahm @ Sep 14 2012, 04:29) QUOTE (...   Sep 14 2012, 15:09
- - Anakunda   If I understand good then audio data is related to...   Sep 14 2012, 07:41
- - eahm   neothe0ne, my last reply to this discussion. I wa...   Sep 14 2012, 17:32
- - IgorC   Eahm. Can You try to do some blind tests and post ...   Sep 14 2012, 18:16
- - eahm   IgorC, I can try but I promise you right now I wil...   Sep 14 2012, 20:57
- - Mix3dmessagez   I don't know if this means anything, but I con...   Sep 19 2012, 23:01
- - eahm   I would very much like to ditch Apple over Fraunho...   Sep 20 2012, 00:32
- - Mix3dmessagez   I've went back and re-encoded other albums. A...   Sep 20 2012, 03:25
|- - eahm   Mix3dmessagez, did you by chance read the first po...   Sep 20 2012, 03:32
|- - Mix3dmessagez   QUOTE (eahm @ Sep 19 2012, 22:32) Mix3dme...   Sep 20 2012, 04:18
- - Anakunda   So. Can anybody blind listening any differences be...   Sep 20 2012, 07:48
|- - eahm   QUOTE (Anakunda @ Sep 19 2012, 23:48) So....   Sep 20 2012, 17:25
- - nu774   I noticed two major differences so far: 3ch(C+L+R)...   Oct 30 2012, 04:46
- - eahm   Thanks for the info. Can Apple (or even qaac) con...   Oct 30 2012, 05:34
|- - nu774   If it is available, you can probably use "afc...   Oct 30 2012, 07:08
- - eahm   New iTunes 11.0.2.25. CoreAudioToolbox.dll is the ...   Feb 20 2013, 18:04
- - zqae   The file CoreAudioToolbox.dll is different between...   Apr 20 2013, 11:24
|- - Anakunda   QUOTE (zqae @ Apr 20 2013, 12:24) The fil...   Apr 20 2013, 14:20
- - eahm   iTunes 11.1.1.11 has 7.9.8.3. Nothing changed agai...   Oct 4 2013, 17:09
- - eahm   Can a mod please remove the Topic Description so w...   Oct 4 2013, 18:47
- - greynol   First come up with something compliant with TOS #6...   Oct 4 2013, 19:04
|- - eahm   QUOTE (greynol @ Oct 4 2013, 11:04) First...   Oct 4 2013, 19:44
- - eahm   New iTunes (11.1.2.31) has CoreAudioToolbox.dll 7....   Oct 24 2013, 05:42
- - IgorC   Apple AAC encoder was already mature since 2005. ...   Oct 24 2013, 14:59
- - eahm   Last change was in April 2013, I don't know if...   Oct 24 2013, 16:08
- - testyou   I appreciate the reporting, since I would test a n...   Oct 24 2013, 18:25
- - eahm   New iTunes 11.1.3.8 still 7.9.8.3. Nothing changed...   Nov 6 2013, 18:34
- - drSeehas   QuickTime 7.7.4 has CoreAudioToolbox.dll 7.9.8.3.   Dec 28 2013, 22:16
- - moob2014   New iTunes 11.1.4 and new CoreAudioToolbox.dll 7.9...   Jan 23 2014, 00:56
- - lock67ca   Odd, I just downloaded new iTunes. Same version nu...   Jan 23 2014, 01:15
|- - moob2014   QUOTE (lock67ca @ Jan 23 2014, 02:15) Odd...   Jan 23 2014, 01:38
- - azaqiel   I guess I got the best of both worlds. iTunes ...   Jan 23 2014, 02:06
|- - moob2014   QUOTE (azaqiel @ Jan 23 2014, 02:06) I gu...   Jan 23 2014, 02:07
- - azaqiel   I checked the properties of the file first, then c...   Jan 23 2014, 02:25
|- - moob2014   QUOTE (azaqiel @ Jan 23 2014, 03:25) I ch...   Jan 23 2014, 02:33
|- - eahm   QUOTE (moob2014 @ Jan 22 2014, 18:33) yes...   Jan 23 2014, 02:59
|- - moob2014   QUOTE (eahm @ Jan 23 2014, 03:59) QUOTE (...   Jan 23 2014, 03:12
- - eahm   Probably just Windows icons cache? Is the new file...   Jan 23 2014, 03:14
|- - moob2014   QUOTE (eahm @ Jan 23 2014, 03:14) Probabl...   Jan 23 2014, 03:32
|- - eahm   You have the wrong iTunes setup. Check the versio...   Jan 23 2014, 03:37
|- - moob2014   QUOTE (eahm @ Jan 23 2014, 04:37) You hav...   Jan 23 2014, 03:48
- - eahm   moob2014, don't know what to say, you are doin...   Jan 23 2014, 03:53
|- - moob2014   QUOTE (eahm @ Jan 23 2014, 03:53) moob201...   Jan 23 2014, 04:15
- - eahm   The one you shared on zippyshare is 7.9.8.5. It...   Jan 23 2014, 04:20
|- - moob2014   QUOTE (eahm @ Jan 23 2014, 04:20) The one...   Jan 23 2014, 04:23
- - eahm   We are OT, File and Product version, of the one yo...   Jan 23 2014, 04:31
|- - moob2014   QUOTE (eahm @ Jan 23 2014, 05:31) We are ...   Jan 23 2014, 04:34
- - nu774   They just don't properly update version resour...   Jan 23 2014, 04:33
|- - moob2014   QUOTE (nu774 @ Jan 23 2014, 05:33) They j...   Jan 23 2014, 04:37
|- - eahm   I'm not sure he meant that exactly, since the ...   Jan 23 2014, 04:43
||- - moob2014   QUOTE (eahm @ Jan 23 2014, 05:43) I'm...   Jan 23 2014, 04:51
|- - nu774   QUOTE (moob2014 @ Jan 23 2014, 12:37) So ...   Jan 23 2014, 04:51
|- - moob2014   QUOTE (nu774 @ Jan 23 2014, 05:51) QUOTE ...   Jan 23 2014, 04:55
- - Anakunda   I think this version problem is neglible since Cor...   Jan 24 2014, 10:22
- - AiZ   Hello, @nu774 I found that your latest (v. 4) mak...   Jan 24 2014, 17:06
|- - nu774   QUOTE (AiZ @ Jan 25 2014, 01:06) @nu774 I...   Jan 24 2014, 17:57
|- - AiZ   Well, QUOTE (nu774 @ Jan 24 2014, 18:57) ...   Jan 24 2014, 20:54
- - AiZ   Hello, Script is perfectly working at work after ...   Jan 27 2014, 13:37
|- - nu774   QUOTE (AiZ @ Jan 27 2014, 21:37) Script i...   Jan 27 2014, 13:51
- - eahm   New iTunes 11.1.5.5, CoreAudioToolbox 7.9.8.5. Not...   Feb 26 2014, 22:06
- - drSeehas   There is also a new QuickTime 7.7.5.   Feb 26 2014, 22:54
|- - eahm   QUOTE (drSeehas @ Feb 26 2014, 14:54) The...   Feb 26 2014, 23:15
- - lvqcl   I downloaded QT 7.75.80.95 and it contains CoreAud...   Feb 26 2014, 23:45
|- - eahm   QUOTE (lvqcl @ Feb 26 2014, 15:45) I down...   Feb 27 2014, 01:33
- - eahm   New iTunes 11.2.0.114, CoreAudioToolbox.dll 7.9.8....   May 15 2014, 19:33
- - Anakunda   Apples AAC developement is ended, time to move to ...   May 15 2014, 21:32
|- - eahm   QUOTE (Anakunda @ May 15 2014, 13:32) App...   May 15 2014, 23:12
- - eahm   New iTunes 11.2.0.115, CoreAudioToolbox.dll 7.9.8....   May 20 2014, 16:17
- - eahm   New iTunes 11.2.2.3, CoreAudioToolbox.dll 7.9.8.5....   May 28 2014, 23:41
- - Anakunda   The good news is that iTunes 11.3 brings new CoreA...   Jul 10 2014, 16:22
- - eahm   Thanks Anakunda and yes, the CoreAudioToolbox 7.9....   Jul 10 2014, 17:09
- - eahm   New iTunes 11.3.1.2, CoreAudioToolbox 7.9.8.6. Not...   Aug 8 2014, 06:06
- - Aleron Ives   Does anybody even know why Apple keeps releasing n...   Aug 8 2014, 08:24
|- - Sparktank   QUOTE (Aleron Ives @ Aug 8 2014, 00:24) D...   Aug 8 2014, 10:01
- - eahm   Apple keeps updating iTunes, I only report changes...   Aug 8 2014, 08:41
|- - Aleron Ives   QUOTE (eahm @ Aug 8 2014, 00:41) I only r...   Aug 8 2014, 10:33
|- - Seren   QUOTE (Aleron Ives @ Aug 8 2014, 17:33) Q...   Aug 10 2014, 12:16
- - eahm   New iTunes 12.0.1.26, CoreAudioToolbox.dll 7.9.9.3...   Oct 17 2014, 07:14
- - Anakunda   CoreAudioToolbox.dll 7.9.9.3., no difference on ou...   Oct 17 2014, 07:34
- - eahm   iTunes 12.1.1.4, CoreAudioToolbox.dll 7.9.9.6   Feb 19 2015, 02:56
- - eahm   iTunes 12.1.2.27, CoreAudioToolbox.dll 7.9.9.6   Apr 10 2015, 17:15
- - decollated   Just to clarify for myself, is it correct that the...   Apr 13 2015, 23:46
- - Aleron Ives   That sounds about right. I started using qaac at C...   Apr 14 2015, 05:27
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 3rd June 2015 - 17:04
