Opus is now RFC6716, version 1.0.1 released!
xiphmont
post Sep 11 2012, 20:19
Xiph.org
"Mozilla and the Xiph.Org Foundation are pleased to announce the Internet Engineering Task Force (IETF) has standardized Opus as RFC 6716. Opus is the first state-of-the-art, fully Free and Open audio codec ratified by a major standards organization."
Full announcement at xiph.org/press/2012/rfc-6716
Yay!
This post has been edited by Frank Bicking: Sep 11 2012, 20:46
Reason for edit: Fixed URL.
Anakunda
post Oct 1 2012, 10:45
I've got this wish if some developer could write a directshow filter for opus...I find this ideal codec and bitrates for secondary tracks (commentary and similar)....
http://www.xiph.org/dshow/
What is the higest input bit depth?
This post has been edited by Anakunda: Oct 1 2012, 10:49
lvqcl
post Oct 1 2012, 15:30
QUOTE (Anakunda @ Oct 1 2012, 13:45) *
foobar2000 already has built-in preset for Opus.
Yakov
post Oct 10 2012, 23:11
QUOTE (lvqcl @ Oct 1 2012, 15:30) *
When encoding with Opus in foobar2000, what is the default export sampling rate? opusenc.exe defaults to 48 KHz so I assume it uses this. If the input is 24-bit 96 KHz is that would I'd end up with? How would I change bit depth and sampling rates in foobar?
saratoga
post Oct 11 2012, 02:27
QUOTE (Yakov @ Oct 10 2012, 18:11) *
It should use whatever sample rate you feed it. IIRC opusenc does this as well.
Yakov
post Oct 11 2012, 04:28
[/quote]
[/quote]
Really? I don't think that 3mb was 24-bit 96 KHz. Is there a way to find out what an opus file is, in terms of bit rate, bit depth, sampling rate, etc.?
Aw, I messed up the quoting didn't I? How do I not do that?
This post has been edited by Yakov: Oct 11 2012, 04:29
NullC
post Nov 28 2012, 19:54
QUOTE (Yakov @ Oct 10 2012, 20:28) *
An opusfile doesn't have a single bitrate (though you can get an average from opusinfo), nor does it have a depth, or a sampling rate (Unless you want to be pedantic and call the frame rate a sample rateó but that can be anywhere from 16 to 400hz and change on the fly). The header used in oggopus stores the 'input' sampling rate so a file decode tool can preserve the rate to avoid surprising people, but there is no record of the input depth (since none of the other lossy tools bother perserving it I didn't think there was a surprise concern there).
- xiphmont   Opus is now RFC6716, version 1.0.1 released!   Sep 11 2012, 20:19
- - bawjaws   https://hacks.mozilla.org/2012/09/its-opus-...code...   Sep 11 2012, 20:32
- - eahm   Great news! The 0.1.5 binary is 1.0.1 RC3, wh...   Sep 11 2012, 21:05
- - IgorC   Congratulations, Guys, Great job! QUOTE (e...   Sep 11 2012, 21:25
|- - eahm   QUOTE (IgorC @ Sep 11 2012, 13:25) QUOTE ...   Sep 11 2012, 21:57
|- - Steve Forte Rio   QUOTE (eahm @ Sep 11 2012, 18:57) QUOTE (...   Sep 12 2012, 15:37
|- - Dynamic   QUOTE (Steve Forte Rio @ Sep 12 2012, 15...   Sep 12 2012, 17:49
|- - zhitch   QUOTE (Steve Forte Rio @ Sep 12 2012, 10...   Oct 10 2012, 16:32
- - yourlord   Congrats and great work guys!   Sep 11 2012, 22:54
- - jensend   PARTY TIME!   Sep 11 2012, 23:14
- - benski   Is storage in the Ogg container format intended to...   Sep 12 2012, 00:08
|- - Dynamic   QUOTE (benski @ Sep 12 2012, 00:08) Is st...   Sep 12 2012, 00:47
||- - iwod   QUOTE (Dynamic @ Sep 12 2012, 00:47) QUOT...   Sep 12 2012, 15:35
||- - Dynamic   QUOTE (iwod @ Sep 12 2012, 15:35) Ogg and...   Sep 12 2012, 16:50
|- - jensend   QUOTE (benski @ Sep 11 2012, 17:08) Is st...   Sep 12 2012, 04:41
- - hlloyge   Well, it would be nice if Apple adopts it for iTun...   Sep 12 2012, 10:12
|- - Yakov   QUOTE (hlloyge @ Sep 12 2012, 10:12) Well...   Oct 10 2012, 23:06
- - mamboman   Congratulations to the developers - Opus is a real...   Sep 12 2012, 10:56
|- - bandpass   QUOTE (mamboman @ Sep 12 2012, 10:56) My ...   Sep 12 2012, 13:40
- - CoRoNe   If I understand correctly, these are the problems ...   Sep 12 2012, 17:53
|- - 2012   QUOTE (CoRoNe @ Sep 12 2012, 17:53) If I ...   Sep 12 2012, 18:52
|- - Dynamic   QUOTE (CoRoNe @ Sep 12 2012, 17:53) If I ...   Sep 15 2012, 16:48
|- - NullC   QUOTE (Dynamic @ Sep 15 2012, 07:48) I be...   Sep 16 2012, 03:14
|- - Dynamic   Thanks for the information & correction, NullC...   Sep 17 2012, 17:01
- - Speckmade   I guess this is the time and place for the big ...   Sep 12 2012, 18:53
- - eahm   I just noticed, the homepage of Opus says "Bi...   Sep 13 2012, 03:35
- - m45t3r   QUOTE (eahm @ Sep 12 2012, 23:35) I just ...   Sep 13 2012, 04:30
|- - eahm   QUOTE (m45t3r @ Sep 12 2012, 20:30) QUOTE...   Sep 13 2012, 04:39
- - viktor   Those who'd like to see Opus being supported o...   Sep 15 2012, 12:01
- - eahm   I don't know how long ago they started but Abs...   Sep 18 2012, 19:07
|- - maikmerten   QUOTE (eahm @ Sep 18 2012, 19:07) I don...   Sep 21 2012, 09:10
|- - Dynamic   QUOTE (maikmerten @ Sep 21 2012, 09:10) I...   Sep 22 2012, 22:56
- - eahm   Are they going to release the 1.0.1 binaries for W...   Sep 20 2012, 19:27
- - yourlord   I have to admit I was a little stunned by the bitr...   Sep 21 2012, 16:38
- - m45t3r   QUOTE (Dynamic @ Sep 22 2012, 18:56) QUOT...   Sep 22 2012, 23:34
|- - IgorC   AAC-ELD uses a low delay modifications of SBR (LD ...   Sep 23 2012, 01:06
- - naturfreak   There is also a commercial competitor named AAC-EL...   Sep 22 2012, 23:54
- - eahm   I think they did read my email, they took off 128k...   Sep 26 2012, 00:42
|- - Dynamic   QUOTE (eahm @ Sep 26 2012, 00:42) I think...   Sep 26 2012, 20:27
|- - lvqcl   QUOTE (Dynamic @ Sep 26 2012, 23:27) Both...   Sep 26 2012, 20:51
||- - Dynamic   Thanks. Had been getting unsupported format or cor...   Sep 26 2012, 22:49
||- - IgorC   QUOTE (lvqcl @ Sep 26 2012, 16:51) QUOTE ...   Sep 30 2012, 16:32
|- - Dynamic   QUOTE (Dynamic @ Sep 26 2012, 20:27) BTW,...   Oct 2 2012, 12:02
|- - maikmerten   QUOTE (Dynamic @ Oct 2 2012, 11:02) I fou...   Oct 2 2012, 12:30
- - Anakunda   Hi all Today foobar2k released the free encoder...   Sep 30 2012, 11:51
|- - lvqcl   QUOTE (Anakunda @ Sep 30 2012, 14:51) Tod...   Sep 30 2012, 11:55
|- - IgorC   QUOTE (Anakunda @ Sep 30 2012, 07:51) As ...   Sep 30 2012, 17:13
|- - Anakunda   I tried to compile 64bit version of the encoder ...   Sep 30 2012, 18:02
|- - twist3d   [quote name='Anakunda' date='Sep 30 20...   Oct 2 2012, 15:14
|- - Anakunda   QUOTE (twist3d @ Oct 2 2012, 16:14) Just ...   Oct 2 2012, 15:22
- - Anakunda   Is there a binary of Opus Tools using libopus 1.0....   Sep 30 2012, 12:14
|- - Emre   QUOTE (Anakunda @ Sep 30 2012, 14:14) Is ...   Sep 30 2012, 16:32
|- - eahm   QUOTE (Emre @ Sep 30 2012, 08:32) QUOTE (...   Sep 30 2012, 16:38
|- - Emre   QUOTE (eahm @ Sep 30 2012, 18:38) QUOTE (...   Sep 30 2012, 19:05
- - [JAZ]   @Anakunda: Opus is designed with realtime communi...   Sep 30 2012, 13:05
- - eahm   [JAZ], What are you talking about? QUOTE (Anakund...   Sep 30 2012, 16:25
|- - [JAZ]   QUOTE (eahm @ Sep 30 2012, 17:25) [JAZ], ...   Sep 30 2012, 16:49
- - Anakunda   Thank U for the updated encoder   Sep 30 2012, 16:42
- - IgorC   (unconstrained) VBR is a default mode. --bitrate ...   Sep 30 2012, 18:11
- - eahm   I can't tell precisely with this build because...   Sep 30 2012, 21:03
- - lvqcl   0.1.5 is the version of Opus_Tools (opusenc, opusd...   Sep 30 2012, 22:19
- - Anakunda   I've got this wish if some developer could wri...   Oct 1 2012, 10:45
|- - nu774   QUOTE (Anakunda @ Oct 1 2012, 18:45) I...   Oct 1 2012, 14:20
|- - lvqcl   QUOTE (Anakunda @ Oct 1 2012, 13:45) What...   Oct 1 2012, 15:30
||- - Yakov   QUOTE (lvqcl @ Oct 1 2012, 15:30) QUOTE (...   Oct 10 2012, 23:11
||- - saratoga   QUOTE (Yakov @ Oct 10 2012, 18:11) QUOTE ...   Oct 11 2012, 02:27
||- - Yakov   When encoding with Opus in foobar2000, what is the...   Oct 11 2012, 04:28
||- - saratoga   QUOTE (Yakov @ Oct 10 2012, 23:28) Really...   Oct 11 2012, 04:59
|||- - Dynamic   QUOTE (saratoga @ Oct 11 2012, 04:59) Edi...   Oct 11 2012, 17:44
|||- - Garf   QUOTE (Dynamic @ Oct 11 2012, 17:44) I do...   Dec 7 2012, 12:29
|||- - Dynamic   QUOTE (Garf @ Dec 7 2012, 11:29) QUOTE (D...   Dec 7 2012, 23:00
||- - NullC   QUOTE (Yakov @ Oct 10 2012, 20:28) Really...   Nov 28 2012, 19:54
|- - Dynamic   Anakunda, from your screenshot, you're asking ...   Oct 1 2012, 18:01
- - IgorC   The highest input bit depth is 32 bits for Opus.   Oct 1 2012, 17:52
|- - 2012   QUOTE (IgorC @ Oct 1 2012, 17:52) The hig...   Oct 2 2012, 01:40
- - lvqcl   Also, --vbr and --comp 10 are the default settings...   Oct 1 2012, 18:09
- - lvqcl   Interesting, but foobar2000 sends either 8, 16, 24...   Oct 2 2012, 04:16
- - eahm   RareWares added an SSE optimized 1.0.1 build as we...   Oct 10 2012, 17:29
- - CoRoNe   My god! opusinfo.exe - 63488b (non-SSE), 55961...   Oct 10 2012, 20:07
|- - Anakunda   QUOTE (CoRoNe @ Oct 10 2012, 21:07) My go...   Oct 10 2012, 20:11
- - Anakunda   It looks like libOpus 1.0.2 was released: QUOTE ...   Dec 7 2012, 07:52
- - eahm   opusenc file.wav: and with foobar2000:   Dec 7 2012, 08:58
- - Seren   Also getting ^this^   Dec 7 2012, 10:35
- - Anakunda   You are right eahm, seren. there's missing dll...   Dec 7 2012, 10:58
|- - Seren   QUOTE (Anakunda @ Dec 7 2012, 17:58) You ...   Dec 7 2012, 12:00
- - Anakunda   I apologize for the inconvenience, it as built wit...   Dec 7 2012, 12:06
|- - Garf   QUOTE (Anakunda @ Dec 7 2012, 12:06) I ap...   Dec 7 2012, 12:34
|- - Seren   QUOTE (Anakunda @ Dec 7 2012, 19:06) I ap...   Dec 7 2012, 13:38
|- - Gainless   QUOTE (Anakunda @ Dec 7 2012, 12:06) I ap...   Dec 7 2012, 17:28
|- - lvqcl   QUOTE (Gainless @ Dec 7 2012, 20:28) ...   Dec 7 2012, 18:32
|- - Anakunda   QUOTE (lvqcl @ Dec 7 2012, 18:32) Probabl...   Dec 7 2012, 18:39
|- - Gainless   QUOTE (Anakunda @ Dec 7 2012, 18:39) QUOT...   Dec 7 2012, 19:37
|- - eahm   QUOTE (Gainless @ Dec 7 2012, 11:37) Well...   Dec 7 2012, 20:27
- - eahm   Anakunda, the last one works thank you.   Dec 7 2012, 17:56
- - DOS386   QUOTE (xiphmont @ Sep 11 2012, 13:19) ...   Dec 20 2012, 10:44
- - Anakunda   Here is a new opus library version 1.1 alpha annou...   Dec 23 2012, 01:53
- - saratoga   QUOTE (Anakunda @ Dec 22 2012, 20:53) The...   Dec 23 2012, 02:03
|- - Anakunda   QUOTE (saratoga @ Dec 23 2012, 02:03) QUO...   Dec 23 2012, 02:09
|- - Speckmade   QUOTE (Anakunda @ Dec 23 2012, 03:09) So ...   Dec 28 2012, 13:08
- - Seren   QUOTE (Anakunda @ Dec 23 2012, 08:53) Ple...   Dec 23 2012, 03:22
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 4th June 2015 - 00:49
