Opus is now RFC6716, version 1.0.1 released!
xiphmont
post Sep 11 2012, 20:19
Xiph.org
"Mozilla and the Xiph.Org Foundation are pleased to announce the Internet Engineering Task Force (IETF) has standardized Opus as RFC 6716. Opus is the first state-of-the-art, fully Free and Open audio codec ratified by a major standards organization."
Full announcement at xiph.org/press/2012/rfc-6716
Yay!
This post has been edited by Frank Bicking: Sep 11 2012, 20:46
Reason for edit: Fixed URL.
eahm
post Sep 18 2012, 19:07
I don't know how long ago they started but Absolute Radio streams in Opus (Trial):
http://www.absoluteradio.co.uk/listen/labs.html#opus
I wish they had 48kbps and 64kbps instead of 128kbps though. I'll email them.
maikmerten
post Sep 21 2012, 09:10
QUOTE (eahm @ Sep 18 2012, 19:07) *
Also: the ar24 stream reports
Encoded with libopus 1.0.1-rc2
ENCODER=opusenc from opus-tools 0.1.4
I would assume they may get better results with one of the experimental psychoacoustic tunings discussed here.
Dynamic
post Sep 22 2012, 22:56
QUOTE (maikmerten @ Sep 21 2012, 09:10) *
If they were to use 48 to 64 kbps (or maybe 80 to 96 kbps), possibly the experimental psy tunings would help, as I believe they're focused on the CELT mode, and the full-range bass would also be welcome.
It seems likely that 128 kbps is going to be pretty excellent / near transparent in either mode and hard to distinguish between main or experimental branch in normal listening.
The 24 kbps stream (Super Wideband at 24 kHz sampling rate, I think) is below the level where CELT dominates (I think most of the experimental psychoacoustic tunings have been developed for the CELT layer) and instead I believe Opus always uses Hybrid mode with SILK encoding the signal up to 8kHz and CELT encoding the spectrum between 8-12 kHz, I believe, so I don't expect there would be much difference between main and experimental there either.
I guess the modes chosen are based on use-cases. Unlikely to include a PSTN modem, but maybe includes cellular streaming to mobile devices at sporadic and variable rates of GPRS, which is often about 28 kbps in rural areas of the UK on some networks.
Absolute Radio labs' 128kbps Opus stream sounds excellent but at times the 24 kbps Opus was really lacking in bass, I believe - I compared to their AAC+SBR 24kbps stream. On the other hand, at times Opus sounded like it had less high-frequency harshness than the AAC+SBR version but also at times it had less HF sparkle due to its presumably 12kHz lowpass. For a speech-oriented encoder setting, Opus24 is very music-friendly. I'd probably pick the AAC+SBR at 24kbps, but the artificial-sounding nature of it might grate with me eventually and I might choose Opus instead. I know there's an adaptable HF filter in the SILK layer, so presumably its effect will vary with the audio source.
It would be lovely if bass could be preserved by Opus when music is detected at 24 kbps without losing too much fidelity due to the bits used there.
As Opus is defined by the decoder, which seems to simply add the SILK and CELT decodes, I'm not sure if there might be scope in hybrid mode to choose to use CELT to encode the area below the high-pass filter that removes non-speech background noise from the SILK layer but might be amenable to encoding using longish blocks.
- xiphmont   Opus is now RFC6716, version 1.0.1 released!   Sep 11 2012, 20:19
- - bawjaws   https://hacks.mozilla.org/2012/09/its-opus-...code...   Sep 11 2012, 20:32
- - eahm   Great news! The 0.1.5 binary is 1.0.1 RC3, wh...   Sep 11 2012, 21:05
- - IgorC   Congratulations, Guys, Great job! QUOTE (e...   Sep 11 2012, 21:25
|- - eahm   QUOTE (IgorC @ Sep 11 2012, 13:25) QUOTE ...   Sep 11 2012, 21:57
|- - Steve Forte Rio   QUOTE (eahm @ Sep 11 2012, 18:57) QUOTE (...   Sep 12 2012, 15:37
|- - Dynamic   QUOTE (Steve Forte Rio @ Sep 12 2012, 15...   Sep 12 2012, 17:49
|- - zhitch   QUOTE (Steve Forte Rio @ Sep 12 2012, 10...   Oct 10 2012, 16:32
- - yourlord   Congrats and great work guys!   Sep 11 2012, 22:54
- - jensend   PARTY TIME!   Sep 11 2012, 23:14
- - benski   Is storage in the Ogg container format intended to...   Sep 12 2012, 00:08
|- - Dynamic   QUOTE (benski @ Sep 12 2012, 00:08) Is st...   Sep 12 2012, 00:47
||- - iwod   QUOTE (Dynamic @ Sep 12 2012, 00:47) QUOT...   Sep 12 2012, 15:35
||- - Dynamic   QUOTE (iwod @ Sep 12 2012, 15:35) Ogg and...   Sep 12 2012, 16:50
|- - jensend   QUOTE (benski @ Sep 11 2012, 17:08) Is st...   Sep 12 2012, 04:41
- - hlloyge   Well, it would be nice if Apple adopts it for iTun...   Sep 12 2012, 10:12
|- - Yakov   QUOTE (hlloyge @ Sep 12 2012, 10:12) Well...   Oct 10 2012, 23:06
- - mamboman   Congratulations to the developers - Opus is a real...   Sep 12 2012, 10:56
|- - bandpass   QUOTE (mamboman @ Sep 12 2012, 10:56) My ...   Sep 12 2012, 13:40
- - CoRoNe   If I understand correctly, these are the problems ...   Sep 12 2012, 17:53
|- - 2012   QUOTE (CoRoNe @ Sep 12 2012, 17:53) If I ...   Sep 12 2012, 18:52
|- - Dynamic   QUOTE (CoRoNe @ Sep 12 2012, 17:53) If I ...   Sep 15 2012, 16:48
|- - NullC   QUOTE (Dynamic @ Sep 15 2012, 07:48) I be...   Sep 16 2012, 03:14
|- - Dynamic   Thanks for the information & correction, NullC...   Sep 17 2012, 17:01
- - Speckmade   I guess this is the time and place for the big ...   Sep 12 2012, 18:53
- - eahm   I just noticed, the homepage of Opus says "Bi...   Sep 13 2012, 03:35
- - m45t3r   QUOTE (eahm @ Sep 12 2012, 23:35) I just ...   Sep 13 2012, 04:30
|- - eahm   QUOTE (m45t3r @ Sep 12 2012, 20:30) QUOTE...   Sep 13 2012, 04:39
- - viktor   Those who'd like to see Opus being supported o...   Sep 15 2012, 12:01
- - eahm   I don't know how long ago they started but Abs...   Sep 18 2012, 19:07
|- - maikmerten   QUOTE (eahm @ Sep 18 2012, 19:07) I don...   Sep 21 2012, 09:10
|- - Dynamic   QUOTE (maikmerten @ Sep 21 2012, 09:10) I...   Sep 22 2012, 22:56
- - eahm   Are they going to release the 1.0.1 binaries for W...   Sep 20 2012, 19:27
- - yourlord   I have to admit I was a little stunned by the bitr...   Sep 21 2012, 16:38
- - m45t3r   QUOTE (Dynamic @ Sep 22 2012, 18:56) QUOT...   Sep 22 2012, 23:34
|- - IgorC   AAC-ELD uses a low delay modifications of SBR (LD ...   Sep 23 2012, 01:06
- - naturfreak   There is also a commercial competitor named AAC-EL...   Sep 22 2012, 23:54
- - eahm   I think they did read my email, they took off 128k...   Sep 26 2012, 00:42
|- - Dynamic   QUOTE (eahm @ Sep 26 2012, 00:42) I think...   Sep 26 2012, 20:27
|- - lvqcl   QUOTE (Dynamic @ Sep 26 2012, 23:27) Both...   Sep 26 2012, 20:51
||- - Dynamic   Thanks. Had been getting unsupported format or cor...   Sep 26 2012, 22:49
||- - IgorC   QUOTE (lvqcl @ Sep 26 2012, 16:51) QUOTE ...   Sep 30 2012, 16:32
|- - Dynamic   QUOTE (Dynamic @ Sep 26 2012, 20:27) BTW,...   Oct 2 2012, 12:02
|- - maikmerten   QUOTE (Dynamic @ Oct 2 2012, 11:02) I fou...   Oct 2 2012, 12:30
- - Anakunda   Hi all Today foobar2k released the free encoder...   Sep 30 2012, 11:51
|- - lvqcl   QUOTE (Anakunda @ Sep 30 2012, 14:51) Tod...   Sep 30 2012, 11:55
|- - IgorC   QUOTE (Anakunda @ Sep 30 2012, 07:51) As ...   Sep 30 2012, 17:13
|- - Anakunda   I tried to compile 64bit version of the encoder ...   Sep 30 2012, 18:02
|- - twist3d   [quote name='Anakunda' date='Sep 30 20...   Oct 2 2012, 15:14
|- - Anakunda   QUOTE (twist3d @ Oct 2 2012, 16:14) Just ...   Oct 2 2012, 15:22
- - Anakunda   Is there a binary of Opus Tools using libopus 1.0....   Sep 30 2012, 12:14
|- - Emre   QUOTE (Anakunda @ Sep 30 2012, 14:14) Is ...   Sep 30 2012, 16:32
|- - eahm   QUOTE (Emre @ Sep 30 2012, 08:32) QUOTE (...   Sep 30 2012, 16:38
|- - Emre   QUOTE (eahm @ Sep 30 2012, 18:38) QUOTE (...   Sep 30 2012, 19:05
- - [JAZ]   @Anakunda: Opus is designed with realtime communi...   Sep 30 2012, 13:05
- - eahm   [JAZ], What are you talking about? QUOTE (Anakund...   Sep 30 2012, 16:25
|- - [JAZ]   QUOTE (eahm @ Sep 30 2012, 17:25) [JAZ], ...   Sep 30 2012, 16:49
- - Anakunda   Thank U for the updated encoder   Sep 30 2012, 16:42
- - IgorC   (unconstrained) VBR is a default mode. --bitrate ...   Sep 30 2012, 18:11
- - eahm   I can't tell precisely with this build because...   Sep 30 2012, 21:03
- - lvqcl   0.1.5 is the version of Opus_Tools (opusenc, opusd...   Sep 30 2012, 22:19
- - Anakunda   I've got this wish if some developer could wri...   Oct 1 2012, 10:45
|- - nu774   QUOTE (Anakunda @ Oct 1 2012, 18:45) I...   Oct 1 2012, 14:20
|- - lvqcl   QUOTE (Anakunda @ Oct 1 2012, 13:45) What...   Oct 1 2012, 15:30
||- - Yakov   QUOTE (lvqcl @ Oct 1 2012, 15:30) QUOTE (...   Oct 10 2012, 23:11
||- - saratoga   QUOTE (Yakov @ Oct 10 2012, 18:11) QUOTE ...   Oct 11 2012, 02:27
||- - Yakov   When encoding with Opus in foobar2000, what is the...   Oct 11 2012, 04:28
||- - saratoga   QUOTE (Yakov @ Oct 10 2012, 23:28) Really...   Oct 11 2012, 04:59
|||- - Dynamic   QUOTE (saratoga @ Oct 11 2012, 04:59) Edi...   Oct 11 2012, 17:44
|||- - Garf   QUOTE (Dynamic @ Oct 11 2012, 17:44) I do...   Dec 7 2012, 12:29
|||- - Dynamic   QUOTE (Garf @ Dec 7 2012, 11:29) QUOTE (D...   Dec 7 2012, 23:00
||- - NullC   QUOTE (Yakov @ Oct 10 2012, 20:28) Really...   Nov 28 2012, 19:54
|- - Dynamic   Anakunda, from your screenshot, you're asking ...   Oct 1 2012, 18:01
- - IgorC   The highest input bit depth is 32 bits for Opus.   Oct 1 2012, 17:52
|- - 2012   QUOTE (IgorC @ Oct 1 2012, 17:52) The hig...   Oct 2 2012, 01:40
- - lvqcl   Also, --vbr and --comp 10 are the default settings...   Oct 1 2012, 18:09
- - lvqcl   Interesting, but foobar2000 sends either 8, 16, 24...   Oct 2 2012, 04:16
- - eahm   RareWares added an SSE optimized 1.0.1 build as we...   Oct 10 2012, 17:29
- - CoRoNe   My god! opusinfo.exe - 63488b (non-SSE), 55961...   Oct 10 2012, 20:07
|- - Anakunda   QUOTE (CoRoNe @ Oct 10 2012, 21:07) My go...   Oct 10 2012, 20:11
- - Anakunda   It looks like libOpus 1.0.2 was released: QUOTE ...   Dec 7 2012, 07:52
- - eahm   opusenc file.wav: and with foobar2000:   Dec 7 2012, 08:58
- - Seren   Also getting ^this^   Dec 7 2012, 10:35
- - Anakunda   You are right eahm, seren. there's missing dll...   Dec 7 2012, 10:58
|- - Seren   QUOTE (Anakunda @ Dec 7 2012, 17:58) You ...   Dec 7 2012, 12:00
- - Anakunda   I apologize for the inconvenience, it as built wit...   Dec 7 2012, 12:06
|- - Garf   QUOTE (Anakunda @ Dec 7 2012, 12:06) I ap...   Dec 7 2012, 12:34
|- - Seren   QUOTE (Anakunda @ Dec 7 2012, 19:06) I ap...   Dec 7 2012, 13:38
|- - Gainless   QUOTE (Anakunda @ Dec 7 2012, 12:06) I ap...   Dec 7 2012, 17:28
|- - lvqcl   QUOTE (Gainless @ Dec 7 2012, 20:28) ...   Dec 7 2012, 18:32
|- - Anakunda   QUOTE (lvqcl @ Dec 7 2012, 18:32) Probabl...   Dec 7 2012, 18:39
|- - Gainless   QUOTE (Anakunda @ Dec 7 2012, 18:39) QUOT...   Dec 7 2012, 19:37
|- - eahm   QUOTE (Gainless @ Dec 7 2012, 11:37) Well...   Dec 7 2012, 20:27
- - eahm   Anakunda, the last one works thank you.   Dec 7 2012, 17:56
- - DOS386   QUOTE (xiphmont @ Sep 11 2012, 13:19) ...   Dec 20 2012, 10:44
- - Anakunda   Here is a new opus library version 1.1 alpha annou...   Dec 23 2012, 01:53
- - saratoga   QUOTE (Anakunda @ Dec 22 2012, 20:53) The...   Dec 23 2012, 02:03
|- - Anakunda   QUOTE (saratoga @ Dec 23 2012, 02:03) QUO...   Dec 23 2012, 02:09
|- - Speckmade   QUOTE (Anakunda @ Dec 23 2012, 03:09) So ...   Dec 28 2012, 13:08
- - Seren   QUOTE (Anakunda @ Dec 23 2012, 08:53) Ple...   Dec 23 2012, 03:22
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 6th March 2015 - 19:01
