converting FLAC to MP3 with "all" the tags, currently looking for TDRL and UFID
HansBKK
post Sep 3 2012, 09:28
I'm mostly using Picard and MP3Tag for my tagging needs, then using FB2K to handle the FLAC to MP3 conversion.
(apologies if such a question should be in FLAC, I'm guessing here)
I want to automate the conversion of my VorbisComment tag RELEASETIME to ID3's TDRL, and MUSICBRAINZ_TRACKID to ID3's UFID:http://musicbrainz.org.
If this isn't possible with FB2K, then I guess I'm looking for a different free tool (in either/both senses) for handling such conversion, carrying over as many as possible of the tags over - coverart, maybe even lyrics would be nice but not that important at this point.
I'm noticing that I have to change quite a few of MP3Tag's default mappings in order to get the ID3 tags converted properly (e.g. CONTENT GROUP rather than CONTENTGROUP, COMPILATION, TORY, all the SORT ones. . .)
And ideally not just the one-time tag transfer when encoding, but even updating the ID3 tags when the source FLAC fields are edited later on, but I realize that's most likely a bit of a pipe dream.
slks
post Sep 10 2012, 06:58
I think foobar2000 can do this with its Masstagger. In some versions the masstagger came included by default, in other versions it needs to be installed as a plug-in.
In the version I'm using (1.1), with masstagger installed, I can right-click a group of files in the playlist, select "Tagging", and then "Manage scripts".
If I understand you right, the action you want to perform is "Copy values between fields", for example copying the RELEASETIME field to the TDRL field.
You might end up with both fields afterwards, but you can simply delete the one you don't need anymore.
What I do with all the audio tech? This: http://last.fm/user/sls
RSS Lo-Fi Version Time is now: 23rd May 2015 - 11:47
