WASAPI output component version 3.0 final, 2013-03-09: v3.2.3
db1989
post Sep 2 2012, 23:43
Version 3.2.3:
WASAPI output support
By: Peter
Adds Windows Audio Session API exclusive mode output support, allowing bit-exact output and muting all other sounds. Windows Vista SP1 or newer required.
3.2 version highlights:
• Different default hardware buffer size for event mode - known to work better with specific soundcards.
• Different detection of stream formats supported by the device - should improve compatibility with certain SPDIF receivers.
3.2.1 version highlights:
• Fixed a crash bug from version 3.2.
3.2.2 version highlights:
* Compatibility improvements - removed the advanced preferences switch; the correct behavior is now determined automatically.
3.2.3 version highlights:
* Fixed 3.2.3 regression that made certain channel layouts not work.
Download: use the link on that page, as it is dynamically generated
Documentation: http://wiki.hydrogenaudio.org/index.php?ti.../foo_out_wasapi
[original post below]
In case it generates a lot of discussion as its pre-releases did, I think it may be best that we try to keep things in one thread. Worth a try, anyway! wink.gif
2012-09-02
The long-awaited update of the WASAPI output component has been released.
Component page
By: Peter
3.0 version highlights:
* Faster volume control
* 32bit integer mode if 32bit floating-point is not supported by the device
* Operates in two different modes, regular and event-driven - the latter seems to be more compatible with USB devices, but not supported by some other devices.
* Separate process sandbox for improved stability.
Current version
3.0, released on 2012-09-02
Links
Download
Documentation
This post has been edited by db1989: Mar 12 2013, 10:15
A_Man_Eating_Duc...
post Nov 13 2012, 08:05
What soundcard are you using?
hkwong
post Nov 13 2012, 12:55
QUOTE (A_Man_Eating_Duck @ Nov 13 2012, 08:05) *
0404 usb in win7 64bit
- db1989   WASAPI output component version 3.0 final   Sep 2 2012, 23:43
- - SoNic67   Thanks! I am using it now and I cannot find an...   Sep 3 2012, 00:54
- - jologsmaster   Thanks for this.   Sep 5 2012, 13:19
- - monstrum   Thanks ! Using "Event mode" on HRT M...   Sep 8 2012, 14:13
- - Porcus   Is the WASAPI component supposed to work with Repl...   Sep 9 2012, 11:59
|- - Porcus   QUOTE (Porcus @ Sep 9 2012, 12:59) Is the...   Sep 14 2012, 00:41
- - felimz   I am getting a possible bug when performing the fo...   Sep 9 2012, 21:21
- - miyagi1   Event mode sounds great. I didn't think there ...   Sep 10 2012, 01:47
- - db1989   Can you qualify that claim according to #8 of the ...   Sep 10 2012, 02:37
- - WarZard-X   Should I use push mode or event mode for an onboar...   Sep 22 2012, 18:33
|- - lumi   im having issues with foobar 1.1.15 and wasapi 3 w...   Sep 26 2012, 00:18
|- - Kohlrabi   QUOTE (lumi @ Sep 26 2012, 01:18) its a r...   Sep 26 2012, 08:21
|- - lumi   QUOTE (Kohlrabi @ Sep 26 2012, 07:21) QUO...   Sep 26 2012, 14:57
- - Xin-Hong   It seems there is a little cosmetic problem: WASAP...   Sep 30 2012, 18:15
- - hkwong   I have this bug also. When foobar is playing a son...   Oct 2 2012, 18:01
- - Peter   If you cannot stop the process, it's stuck in ...   Oct 2 2012, 21:08
|- - hkwong   QUOTE (Peter @ Oct 2 2012, 21:08) If you ...   Oct 4 2012, 17:32
|- - luigidox   QUOTE (hkwong @ Oct 4 2012, 17:32) QUOTE ...   Oct 9 2012, 08:37
|- - hkwong   QUOTE (luigidox @ Oct 9 2012, 08:37) QUOT...   Oct 10 2012, 17:23
- - e2012   I can report after a few days usage that the new v...   Oct 2 2012, 21:36
- - Bojamijams   Same issue as above. Cannot play files anymore wi...   Oct 2 2012, 22:54
- - A_Man_Eating_Duck   what USB Dac are you using?   Oct 3 2012, 03:47
- - Bojamijams   Anedio D1. However its fed by a USB-to-COAX digit...   Oct 4 2012, 02:02
- - Anakunda   Maybe I have overlooked something but actually nei...   Oct 5 2012, 07:11
- - Peter   Sounds like your soundcard does not support 88200H...   Oct 5 2012, 08:22
- - luigidox   I'm considering to upgrade to mytek 192 DSD DA...   Oct 9 2012, 08:40
- - rix81   thanks for great work! can I ask for feature ...   Oct 14 2012, 09:01
- - eamon123   Unrecoverable playback error: Unsupported stream f...   Oct 17 2012, 03:45
|- - A_Man_Eating_Duck   QUOTE (eamon123 @ Oct 17 2012, 15:45) Unr...   Oct 17 2012, 06:40
|- - eamon123   Cheers, I figured it had one built in like in the ...   Oct 17 2012, 09:30
- - Dynamic   The standard fb2k resampler, by default, won't...   Oct 17 2012, 15:37
- - hkwong   I have recently got a problem. There are some song...   Nov 13 2012, 03:17
- - A_Man_Eating_Duck   What soundcard are you using?   Nov 13 2012, 08:05
|- - hkwong   QUOTE (A_Man_Eating_Duck @ Nov 13 2012, 08...   Nov 13 2012, 12:55
- - TomKure   Hi. I'm also having trouble with this version ...   Nov 15 2012, 13:40
|- - lumi   following on from my earlier post i tried it on a...   Nov 23 2012, 23:21
- - war59312   Hi, Any chance on getting WASAPI working with DFX...   Nov 25 2012, 21:04
|- - GeSomeone   Wasapi output version 3.1 was released * Fixed pla...   Dec 16 2012, 01:00
- - SoNic67   QUOTE (hkwong @ Oct 4 2012, 12:32) My sys...   Dec 16 2012, 02:16
- - TomKure   The playback is getting stuck with the Emu 0404 us...   Dec 17 2012, 13:06
- - Peter   New version: 3.2 beta 1 (beta link removed) Chan...   Jan 29 2013, 14:15
- - jaro1   Thank you very much for an update, Peter.   Jan 31 2013, 16:11
- - jkauff   Thanks, Peter. This now works with my M-Audio Audi...   Feb 6 2013, 13:32
- - Peter   Thanks for letting me know. The new version will b...   Feb 6 2013, 13:34
- - Peter   New version up. No changes from the beta.   Feb 7 2013, 14:46
|- - SoNic67   QUOTE (Peter @ Feb 7 2013, 08:46) New ver...   Feb 11 2013, 01:39
- - db1989   Peter is free to edit my OP if he prefers to it th...   Feb 11 2013, 01:56
- - metal_duc   Last version works here with a MOTU 896 mkIII but ...   Feb 12 2013, 09:50
- - Peter   If you're getting this error, Windows thinks y...   Feb 12 2013, 12:50
- - alter4   Hello! Today I updated wasapi to 3.2.1 and got...   Feb 12 2013, 21:42
|- - metal_duc   QUOTE (alter4 @ Feb 12 2013, 21:42) Hello...   Feb 12 2013, 21:59
|- - alter4   QUOTE (metal_duc @ Feb 12 2013, 23:59) QU...   Feb 12 2013, 22:07
|- - metal_duc   [/quote] (...) but I assume this is a bug in wasa...   Feb 12 2013, 22:17
|- - reetoora   This goes for me too, though I have different soun...   Feb 15 2013, 20:47
- - maxim_fr   I have the "Unrecoverable playback error: Uns...   Feb 23 2013, 19:10
- - db1989   I’m not preventing anyone from doing that for you,...   Feb 23 2013, 20:12
- - maxim_fr   No problem - I would be happy to provide any infor...   Feb 23 2013, 21:57
- - Sandrine   Just tried 3.2.2 - it's no good. Whereas befor...   Mar 9 2013, 18:11
- - Case   Here's the previous version until a fix is ava...   Mar 9 2013, 19:07
- - Peter   Bug hopefully fixed in 3.2.3. Thanks for the quick...   Mar 9 2013, 20:56
- - Sandrine   Confirmed to work. Thanks for the quick update.   Mar 10 2013, 12:55
- - Gianni   Hi, first of all thanks for this component. I woul...   Mar 10 2013, 22:14
- - Alexa   what is "bit-exact output" and how is it...   Mar 10 2013, 23:38
|- - db1989   It just bypasses Windows’ mixer and other potentia...   Mar 10 2013, 23:45
- - SoNic67   Thank you Peter.   Mar 12 2013, 01:17
- - Propheticus   An heads up: After updating Foobar2k to version 1....   Mar 19 2013, 00:58
- - bilemke   First things first, Peter, love this plugin. So mu...   Mar 19 2013, 03:47
|- - db1989   QUOTE (bilemke @ Mar 19 2013, 02:47) can...   Mar 19 2013, 13:47
|- - bilemke   QUOTE (db1989 @ Mar 19 2013, 13:47) QUOTE...   Mar 20 2013, 02:28
- - meDveD.spb   If remove old foo_out_wasapi.dll.cfg - no crashes,...   Mar 19 2013, 04:01
- - Peter   Sounds like new SSE code for 24-bit audio handling...   Mar 19 2013, 11:03
|- - Propheticus   QUOTE (Peter @ Mar 19 2013, 11:03) Sounds...   Mar 19 2013, 14:02
- - aprofromindia   Can we have Default WASAPI Event mode (like JRiver...   May 21 2013, 22:56
- - maxim_fr   Hello. Is it possible to redirect output to Direc...   May 22 2013, 15:40
|- - MrMonkey   QUOTE (maxim_fr @ May 22 2013, 10:40) It ...   May 22 2013, 15:49
|- - maxim_fr   QUOTE (MrMonkey @ May 22 2013, 16:49) ......   May 22 2013, 20:11
- - Meeko   Hey, I don't post here much, but I thought I...   Jun 22 2013, 13:12
|- - maxim_fr   QUOTE (Meeko @ Jun 22 2013, 14:12) Any wa...   Jun 22 2013, 13:23
- - Meeko   Just missed that post I guess! Oops! Well...   Jun 23 2013, 02:20
- - DragonQ   QUOTE (rix81 @ Oct 14 2012, 08:01) thanks...   Jul 27 2013, 15:35
- - rnddude   I was going to start a new thread, but this one mi...   Jul 27 2013, 23:36
- - bitp   Windows 8 x64, Realtek High Definition Audio on bo...   Aug 23 2013, 22:16
|- - bitp   QUOTE (bitp @ Aug 23 2013, 16:16) Windows...   Sep 12 2013, 03:33
- - RavenGT   I'm using WASAPI 3.2.3, FB2K 1.2.9 and SoX Res...   Sep 6 2013, 03:35
- - Mardel   I downloaded this version (3.2.3, released on 2013...   Sep 12 2013, 19:36
- - db1989   Did you install the component using the proper met...   Sep 12 2013, 22:34
|- - Mardel   QUOTE (db1989 @ Sep 12 2013, 23:34) Did y...   Sep 12 2013, 23:35
- - db1989   Yeah, that should be the right way. I was just che...   Sep 12 2013, 23:59
|- - Mardel   QUOTE (db1989 @ Sep 13 2013, 00:59) Yeah,...   Sep 13 2013, 18:40
- - danny.d   Works great with a M2Tech Hiface USB to SPDIF int...   Oct 29 2013, 09:41
- - HTA   i tried WASAPI for the first time today, connectin...   Oct 31 2013, 16:02
- - db1989   Did you verify that subjective impression with an ...   Nov 7 2013, 20:21
- - wraaaa   I'd like to request the addition of fade-in/fa...   Jan 13 2014, 20:19
|- - Propheticus   Something like foo_dsp_crossfader might work. Have...   Jan 13 2014, 22:59
|- - wraaaa   QUOTE (Propheticus @ Jan 13 2014, 15:59) ...   Jan 14 2014, 15:58
- - misha0209   hi, @db1989 any chance you could implement DSD ove...   Jan 24 2014, 06:33
- - eahm   Why AIMP3's WASAPI is not exclusive and foobar...   Feb 18 2014, 06:22
- - misha0209   hello again, i asked the moderator who started t...   Feb 19 2014, 15:07
|- - Porcus   QUOTE (misha0209 @ Feb 19 2014, 15:07) he...   Feb 19 2014, 20:17
- - WarZard-X   Maybe a bug? I'm using a 24-bit codec (VT2021)...   Mar 3 2014, 11:20
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 2nd March 2015 - 05:08
