SNR of MP3, Split from Topic ID #96702
benski
post Aug 28 2012, 18:37
Winamp Developer
QUOTE (jensend @ Aug 27 2012, 11:45) *
The LP noise floor is rather high- maybe -70dB under very good conditions. 12-bit sampling (RMS noise floor of -72dB) would be sufficient for LP use as long as your levels are right (peak signal above -6dB). (12-bit sampling was used for DV but hasn't seen any other widespread use).
The SNR of an MP3 is around 25-30dB. Does this mean that I only need to decode them to 6-bit PCM to capture all the details?
I am curious if anyone has ever done a detailed analysis of an LP's SNR in different frequency bands.
This post has been edited by benski: Aug 28 2012, 19:07
pdq
post Aug 28 2012, 20:20
QUOTE (benski @ Aug 28 2012, 13:37) *
I don't know why you say that. The dynamic range of mp3 is obviously much greater than 30 dB.
I would be more inclined to describe mp3's deviation from the original as distortion rather than noise, because it is quite capable of rendering very quiet passages with very little added noise.
Alexey Lukin
post Aug 30 2012, 20:42
I still think that the best way to measure mp3 noise is to do a subtraction test.
Arnold B. Kruege...
post Aug 31 2012, 20:07
QUOTE (Alexey Lukin @ Aug 30 2012, 15:42) *
I can't think of a worse general way to measure anything than subtraction tests, because they frequently conflate a myriad of differences into one signal.
Woodinville
post Dec 30 2012, 03:47
QUOTE (Arnold B. Krueger @ Aug 31 2012, 11:07) *
Since MP3 has no phase shift or frequency shaping to speak of, delay-compensated direct difference is exactly the right way to measure SNR.
In fact, it's ALWAYS the right way to measure SNR, which is formally mathematically defined as
SNR = sum( (x*x))/sum( (x-y)^2)
So Arny, you're right that it makes little sense in perceptual terms, which is why I say in my talks "SNR is mostly useless for perceptual purposes". None the less, SNR is the relevant question when asking "bits of resolution", courtesy of Mr. Shannon.
J. D. (jj) Johnston
RSS Lo-Fi Version Time is now: 30th May 2015 - 14:25
