The Future of FLAC
spoon
post Aug 31 2012, 17:26
dBpowerAMP developer
Group: Developer (Donating)
From January 2012 FLAC is being maintained by Erik de Castro Lopo under the auspices of the Xiph.org Foundation.
Taken from
https://github.com/crrodriguez/flac
...but I guess this guy does not have the access to flac.soureforge.net
From an Email I sent off to Eric,
Mr Spoon wrote:
> We have been trying to find what has happened to Josh for quite a while
He's fine, just not working on FLAC anymore.
> now, we came across https://github.com/crrodriguez/flac which suggests =
> you have taken over FLAC management? is this correct?
Yes it is.
> have you taken over flac.sf.net also?
We are in the process of moving the web pages to:
http://xiph.rog/flac/
Once that is done, we will ask Josh to set up a HTTP redirect on the
flac.sf.net web site.
Erik
So it seems Josh is no longer working on FLAC, I am concerned that merging into xiph might not be best for FLACs future...(it is nothing personal against xiph), FLAC has a window of opportunity to become the defacto lossless codec, but without strong management it will not (and in 4 years everything will be in Apple lossless, or some such)
I propose that a team from HA is put together and then propose to xiph that such a team take over FLACs stewardship. If you are interested put your name forward, and if the team is strong, we can propose.
This post has been edited by spoon: Aug 31 2012, 21:50
Spoon http://www.dbpoweramp.com
Wombat
post Aug 31 2012, 22:09
Strangely the flac development stopped around the same time it became widely supported in hardware mediaplayers like the Squeezebox line.
I wonder if it simply needed to much effort with these already and Mr. Coalson simply felt he spends to much time.
There are several other minor things that come to my mind.
Much flac is sold as hires music while there isn´t even a Replaygain implementation for the higher sampling rates included in metaflac.
Also over time i often did read problems with the way flac integrates into the Windows OS. People have problems with metadata in
Explorer or the standard flac frontend doesn´t work at all.
Over time there also were some efforts to optimize the use of modern resources like a very impressing Open-CL implementation or a multi-threaded built.
It would really be nice to get all these things together somehow and make a simple to use package.
Me as Hydrogen pinhead has no problem to make all these features usable to me but for some average user it is most likely already to annoying.
ALAC is in itunes, needs no additional effort if someone uses it and its TAGs are already recognized in every OS AFAIK.
With 24bit audio you can listen to silence much louder
- spoon   The Future of FLAC   Aug 31 2012, 17:26
- - yourlord   Is there a reason to question Eric's stewardsh...   Aug 31 2012, 18:15
|- - mudlord   QUOTE (yourlord @ Aug 31 2012, 12:15) Is ...   Sep 1 2012, 09:31
|- - BFG   I find this thread to be a fascinating look into a...   Nov 21 2012, 00:21
|- - tuffy   QUOTE (BFG @ Nov 20 2012, 18:21) So here...   Nov 21 2012, 01:37
||- - Porcus   QUOTE (tuffy @ Nov 21 2012, 01:37) Howeve...   Nov 21 2012, 02:13
||- - BFG   QUOTE (Porcus @ Nov 20 2012, 19:13) Shoul...   Nov 21 2012, 05:46
||- - Dynamic   QUOTE (BFG @ Nov 21 2012, 04:46) But yes,...   Nov 22 2012, 12:06
|- - eahm   QUOTE (BFG @ Nov 20 2012, 16:21) I find t...   Nov 21 2012, 02:06
- - spoon   If it has been under Xiph umbrella for some time, ...   Aug 31 2012, 18:59
- - xTobix   QUOTE (spoon @ Aug 31 2012, 17:26) QUOTE ...   Aug 31 2012, 19:33
|- - greynol   QUOTE (xTobix @ Aug 31 2012, 11:33) I am ...   Aug 31 2012, 19:52
- - Kohlrabi   QUOTE (spoon @ Aug 31 2012, 18:26) https:...   Aug 31 2012, 19:39
|- - xTobix   Thanks Kohlrabi, QUOTE (Kohlrabi @ Aug 31 20...   Aug 31 2012, 20:15
|- - db1989   QUOTE (xTobix @ Aug 31 2012, 20:15) @grey...   Aug 31 2012, 22:04
|- - xTobix   QUOTE (db1989 @ Aug 31 2012, 22:04) QUOTE...   Aug 31 2012, 22:16
- - yourlord   From a code base perspective I'm not sure what...   Aug 31 2012, 20:26
- - spoon   Got it in one yourlord (I think what is really nee...   Aug 31 2012, 21:11
- - sshd   FLAC needs >2G support   Aug 31 2012, 21:16
- - IgorC   AFAIK the future Xiph's format Ghost will supp...   Aug 31 2012, 21:30
- - westgroveg   I'm curious as to how you 'push' a aud...   Aug 31 2012, 21:51
- - spoon   Everybody knows somebody...contacts can be found -...   Aug 31 2012, 22:02
- - Wombat   Strangely the flac development stopped around the ...   Aug 31 2012, 22:09
- - yourlord   QUOTE (IgorC @ Aug 31 2012, 16:30) AFAIK ...   Aug 31 2012, 22:14
|- - xiphmont   QUOTE (yourlord @ Aug 31 2012, 17:14) QUO...   Sep 1 2012, 11:18
- - krafty   I was also wondering what happened to the FLAC pro...   Aug 31 2012, 23:43
|- - Dario   QUOTE (krafty @ Sep 1 2012, 00:43) (Stran...   Sep 1 2012, 00:03
- - kwanbis   More or less, they reached a point of maturity. Bu...   Sep 1 2012, 02:01
- - godrick   It seems impossible to tell what xiph's goals ...   Sep 1 2012, 03:21
|- - jensend   Most of this thread is extremely bizarre. Reading ...   Sep 1 2012, 07:11
- - spoon   @Jensend - flac does not hugely need massive devel...   Sep 1 2012, 09:21
|- - maikmerten   QUOTE (spoon @ Sep 1 2012, 09:21) @Jensen...   Sep 1 2012, 10:37
- - kjoonlee   So volunteer for work. Not that hard, I should thi...   Sep 1 2012, 09:29
- - smok3   it is open source right? So no need to ask questi...   Sep 1 2012, 10:28
- - AliceWonder   The only problem I have with flac under Xiph stewa...   Sep 2 2012, 10:57
|- - maikmerten   QUOTE (AliceWonder @ Sep 2 2012, 10:57) T...   Sep 3 2012, 09:05
|- - AliceWonder   QUOTE QUOTE (maikmerten @ Sep 3 2012, 01...   Sep 3 2012, 11:48
- - mudlord   As I said, not gonna happen when the current maint...   Sep 2 2012, 13:21
|- - saratoga   QUOTE (mudlord @ Sep 2 2012, 08:21) As I ...   Sep 2 2012, 15:57
- - Nick.C   Support for 16-bit float samples would be nice too...   Sep 2 2012, 13:27
- - mudlord   I hardly doubt it this has anything to do with ide...   Sep 3 2012, 00:09
|- - godrick   QUOTE (mudlord @ Sep 3 2012, 00:09) I har...   Sep 3 2012, 02:52
|- - saratoga   QUOTE (mudlord @ Sep 2 2012, 19:09) I har...   Sep 6 2012, 06:30
|- - 73ChargerFan   QUOTE (mudlord @ Sep 2 2012, 16:09) I har...   Oct 21 2012, 00:11
- - markanini   Maybe it's an aside but I see flac as having u...   Sep 3 2012, 01:44
|- - maikmerten   QUOTE (markanini @ Sep 3 2012, 01:44) Yet...   Sep 3 2012, 08:53
|- - GeSomeone   QUOTE (markanini @ Sep 3 2012, 02:44) Yet...   Oct 20 2012, 18:21
- - kornchild2002   QUOTE (spoon @ Aug 31 2012, 10:26) So it ...   Sep 3 2012, 04:30
|- - AliceWonder   QUOTE (kornchild2002 @ Sep 2 2012, 20:30)...   Sep 3 2012, 07:17
- - Porcus   Keep calm now. A “hostile takeover” -- or anything...   Sep 3 2012, 08:59
|- - db1989   QUOTE (Porcus @ Sep 3 2012, 08:59) Keep c...   Sep 3 2012, 10:58
- - CoyoteSmith   Flac's biggest issue IMO is broad knowledge fr...   Sep 6 2012, 03:06
- - mudlord   Not productive? I call it being completely realist...   Sep 6 2012, 06:58
- - Azevedo   Such a downturn for the economy, such a downturn f...   Oct 20 2012, 14:58
- - Wombat   QUOTE (GeSomeone @ Oct 20 2012, 19:21) Ot...   Oct 20 2012, 18:36
- - spoon   Eric had assured me he would reply addressing some...   Oct 20 2012, 19:04
- - Brand   QUOTE (maikmerten @ Sep 1 2012, 11:37) On...   Oct 21 2012, 09:42
- - lameboy   I think Xiph should push to make FLAC an ISO-stand...   Oct 23 2012, 08:05
- - LithosZA   QUOTE I think Xiph should push to make FLAC an ISO...   Oct 23 2012, 08:17
|- - lameboy   QUOTE (LithosZA @ Oct 23 2012, 09:17) QUO...   Oct 23 2012, 09:40
- - eahm   QUOTE (sshd @ Aug 31 2012, 13:16) FLAC ne...   Nov 20 2012, 05:29
- - shadowking   Oh this nonsense has been debunked before. Wavpack...   Nov 20 2012, 06:14
|- - eahm   QUOTE (shadowking @ Nov 19 2012, 22:14) O...   Nov 20 2012, 06:24
- - shadowking   How exactly is a wavpack user gonna end up with a ...   Nov 20 2012, 06:29
|- - Porcus   QUOTE (shadowking @ Nov 20 2012, 06:29) H...   Nov 20 2012, 09:31
- - greensdrive   QUOTE (eahm @ Nov 19 2012, 22:29) You cou...   Nov 20 2012, 06:49
- - nu774   I don't get it. Container formats like WAV, AI...   Nov 20 2012, 07:00
- - 2Bdecided   Some of this is pure naivety. lossyFLAC exists Th...   Nov 20 2012, 11:44
- - IgorC   FLAC is a great format. But given that the market...   Nov 20 2012, 16:54
- - Nick.C   Class 10 64GB µSDHC card in phone, FLAC to phone i...   Nov 20 2012, 19:54
|- - IgorC   QUOTE (Nick.C @ Nov 20 2012, 15:54) Class...   Nov 21 2012, 03:52
- - pdq   I keep a collection of 8 GB cards ($4 each) a...   Nov 20 2012, 20:11
- - yourlord   I use FLAC as my playable local network archive. I...   Nov 20 2012, 22:01
- - greynol   You might try and see how TAK does on them.   Nov 21 2012, 06:34
- - jkauff   I have a new iPhone 5, my first Apple device. My a...   Nov 22 2012, 16:08
- - greynol   Are you prepared to substantiate either of those s...   Nov 22 2012, 16:36
|- - jkauff   QUOTE (greynol @ Nov 22 2012, 16:36) Are ...   Nov 22 2012, 22:29
- - skamp   QUOTE (jkauff @ Nov 22 2012, 16:08) IMO, ...   Nov 23 2012, 00:48
|- - jkauff   QUOTE (skamp @ Nov 23 2012, 00:48) Those ...   Nov 23 2012, 08:07
- - greynol   It's too bad this topic had to take tangential...   Nov 23 2012, 16:37
- - Axon   If the future of FLAC is really in question, why h...   Nov 25 2012, 07:17
- - spoon   The fact that Eric has (up until now) ignored the ...   Nov 25 2012, 20:49
- - BFG   This kind of makes me wonder if Justin Ruggles (th...   Nov 25 2012, 21:36
|- - Justin Ruggles   QUOTE (BFG @ Nov 25 2012, 16:36) This kin...   Nov 26 2012, 18:51
|- - BFG   QUOTE (Justin Ruggles @ Nov 26 2012, 11:5...   Nov 26 2012, 21:30
- - notinasia   I think code development and networking can be sep...   Mar 4 2013, 12:09
- - notinasia   So I search for FLAC on facebook before all this h...   Mar 4 2013, 13:13
RSS Lo-Fi Version Time is now: 28th April 2015 - 02:40
