Audio from vinyl (24 / 96-192 khz). Converting/downsampling?
Taishou
post Aug 27 2012, 03:01
Hi again
I have several digitized vinyls in FLAC, at 24 bit, 96-192 khz. Is it worth all that sample rate? I was thinking of making CD quality (16/44.1) FLACs or even mp3 320. I doubt I'll ever in my life spend more than, idk, 200 usd in headphones, so the over-quality looks a waste. What do you say? I'm far from an audiophile and I feel pretty happy with mp3 320 (I can't even tell from FLAC).
Anyway, I need to re-encode that at least for my mobile devices. Should I have any special care when converting? I use fre:ac (LAME 3.99.5). Should I just set 44.1 khz when encoding there and done? Or should I downsample with another tool and then encode? I just tried encoding something setting 44.1 in LAME and the result sounds the same as the original 24/192 (with my crappy headphones at least).
The same goes for FLAC or ogg (I tend to use the latter for my DAP). Just setting the sample rate when encoding is enough or is it better to do it with another program? (I doubt, but I wouldn't like regretting later because I made a crappy conversion).
(maybe this should go in the "vinyl" forum, but my concern is more with those high sample rates and downsampling, regardless the source)
Taishou
post Aug 28 2012, 05:40
QUOTE (splice @ Aug 27 2012, 17:37) *
QUOTE (Taishou @ Aug 26 2012, 23:25) *
... Anyway, I just checked other FLACs I have that are supposedly 24 bit, but in Audacity show up as 32 floating point. Foobar says 24, as it should be. ...
The bit depth shown by Audacity is the default format that it converts input to and uses internally. If you want to keep it in 24 bit, for example you're just editing (cutting / pasting) and not doing any math (EQ, level changing etc), you can change the default using "Preferences --> Quality --> Default Sample Format".
Indeed. Everything, even mp3, it takes at 32 bits. Thanks for the tip/
QUOTE (jensend @ Aug 27 2012, 20:09) *
If you're already using SoX, no reason to not use it for bit depth conversion too.
sox in.wav -b 16 out.wav rate 48k
should do the job quite nicely. It will use triangular pdf dither by default; since the LP noise floor is so much higher than that of 16-bit it may not really matter whether you dither or not, but it won't do any harm. Don't bother with noise-shaped dithers.
I was using the SoX plugin in foobar, but that's limited to re-sampling. I'll use the "stand-alone" SoX with that command.
After checking with Replay Gain in foobar all tracks of the LPs are above ~4.30db (that being the lowest value) and the peak or something (a number that appeared beside that, I don't have foobar here to check) was always around 0.99 and 0.95.
Btw, I wonder why so many ppl (almost everyone it seems) rips their vinyls at 24/96... Maybe keep the 24 bits for editing, but why such a high frequency is so wide-spread? From what I see and you told me it's more than clear it's practically useless.
This post has been edited by Taishou: Aug 28 2012, 05:55
jensend
post Aug 28 2012, 17:34
QUOTE (Taishou @ Aug 27 2012, 22:40) *
Good. To expand a little on what Porcus said about this meaning you really will get 16 bits: as long as your signal peaks above 0.5 of full scale i.e. above -6dB SPL (sound pressure level), you're making use of the most significant bit and therefore getting the dynamic range and noise floor of a 16-bit recording, while if e.g. your signal was always below 1/16 of full scale i.e. below -24dB SPL, the first four bits of every sample would be zero so you'd only be effectively using 12 bits.
It's just part of the same group confusion that is common among all sorts of audiophiles (not just those dealing with vinyl). There is, however, a real reason why people started making equipment that could record at higher sampling rates in the first place, and that story may help you understand how the confusion among audiophiles started.
Whenever you run many kinds of filters on a signal, to avoid aliasing, pre-echo, and other problems you need a "transition band" between the highest frequencies you are trying to faithfully preserve and the Nyquist frequency (1/2 your sample rate). When the transition band is narrower, the filter has to be more complicated and wait until it's seen more of the signal before it outputs anything (there's kind of a heisenberg type frequency*time inequality here).
For digital offline processing and editing this doesn't really matter so much any more- computers are powerful enough these days to run very complicated filters (like the sinc filters that make SoX's VHQ resampling work) reasonably fast, so we can use very narrow transition bands. But complicated analog filters can be noisy and/or expensive, and if you're doing effects and mixing real-time in the studio, having to wait to look at more of the signal means you're introducing more delay, which may be unacceptable. So for analog and/or real-time use, a transition band from 20kHz to 24kHz, ~1/4 of an octave, may be too narrow, meaning that you can get better results by recording at sampling rates above 48kHz. If you sample at 96kHz, you have a nice wide ~1 1/4 octave transition band from 20kHz to 48kHz, and can therefore use lots of fast, simple filters without introducing artifacts in any of the audible frequencies.
Because recording at 96kHz could in these circumstances lead to a better end result, misguided audiophiles started thinking that a) they wanted to have the original non-downsampled master and b) more kHz is always better.
This post has been edited by jensend: Aug 28 2012, 18:05
- Taishou   Audio from vinyl (24 / 96-192 khz). Converting/downsampling?   Aug 27 2012, 03:01
- - Porcus   QUOTE (Taishou @ Aug 27 2012, 04:01) I ha...   Aug 27 2012, 06:16
- - Taishou   I see... Thinking about it I'll stay with FLA...   Aug 27 2012, 06:57
- - Taishou   Sorry for the double post, I can't see an ...   Aug 27 2012, 08:25
|- - Porcus   Go 44.1 or 48, as those are the well-supported sam...   Aug 27 2012, 10:14
||- - db1989   QUOTE (Porcus @ Aug 27 2012, 10:14) [Oh ....   Aug 27 2012, 14:38
|- - splice   QUOTE (Taishou @ Aug 26 2012, 23:25) ... ...   Aug 27 2012, 21:37
- - jensend   Try the FAQ for good info and advice. Also this pa...   Aug 27 2012, 16:45
|- - benski   QUOTE (jensend @ Aug 27 2012, 11:45) The ...   Aug 28 2012, 18:37
|- - Woodinville   QUOTE (benski @ Aug 28 2012, 10:37) QUOTE...   Aug 29 2012, 03:27
|- - krabapple   QUOTE (Woodinville @ Aug 28 2012, 22:27) ...   Aug 31 2012, 14:08
- - jensend   Oh, BTW: resampling in multiple stages is unlikely...   Aug 27 2012, 17:06
- - Taishou   Great answers, thanks. I just read the links you p...   Aug 27 2012, 20:56
- - jensend   If you're already using SoX, no reason to not ...   Aug 28 2012, 00:09
- - Taishou   QUOTE (splice @ Aug 27 2012, 17:37) QUOTE...   Aug 28 2012, 05:40
|- - Porcus   QUOTE (Taishou @ Aug 28 2012, 06:40) Afte...   Aug 28 2012, 07:42
|- - jensend   QUOTE (Taishou @ Aug 27 2012, 22:40) Afte...   Aug 28 2012, 17:34
- - db1989   Itís a result of one of audioís many compound myth...   Aug 28 2012, 07:09
- - Woodinville   There is some use to that over-20kHz stuff, though...   Aug 28 2012, 08:16
- - Arnold B. Krueger   QUOTE (Taishou @ Aug 26 2012, 22:01) I ha...   Aug 28 2012, 12:40
- - greynol   We had the same inconvenient point raised about th...   Aug 28 2012, 20:32
- - Taishou   Thanks for all your input, it's really great ...   Aug 29 2012, 02:48
|- - Porcus   QUOTE (Taishou @ Aug 29 2012, 03:48) Shou...   Aug 29 2012, 15:05
|- - jensend   QUOTE (Taishou @ Aug 28 2012, 23:47) If i...   Aug 29 2012, 15:13
- - Taishou   If it matters of something, the files with clippin...   Aug 29 2012, 06:47
- - Porcus   But ... if the peak measures to 0.999, and the res...   Aug 29 2012, 20:43
- - pdq   The resampling produced samples that were beyond +...   Aug 29 2012, 21:02
- - Taishou   Well, I decided to leave it as it is. I tried the...   Aug 29 2012, 23:30
- - greynol   Re. compression: I've seen worse. At the end ...   Aug 29 2012, 23:41
- - Taishou   Indeed. And it's the same on the source, so it...   Aug 29 2012, 23:51
|- - Porcus   QUOTE (Taishou @ Aug 30 2012, 00:51) it w...   Aug 30 2012, 07:35
- - greynol   Could it be due to possible inter-sample overs occ...   Aug 30 2012, 02:51
- - greynol   Off-topic discussion on the SNR or MP3 has been sp...   Aug 31 2012, 19:48
RSS Lo-Fi Version Time is now: 29th January 2015 - 17:48
