> Upload forum rules
lossyWAV 1.3.0 source translated to C++ from Delphi
tycho
post Aug 26 2012, 22:02
Here is the first public preview of the source translation of lossyWAV 1.3.0 to C++. It is not finished, but the main work is done.
- vc10_err.txt list the current compiler output in Visual Studio C++ 2010.
- A number of built-in Delphi functions are not yet converted. Most are trivial, but Write() involves some work.
Please note, I know very little of how the code actually works, I basically translated it line by line, and did minor optimizations.
Developers can look over the code and compare with the Delphi source. I have tried to take into account a number of C++'s quirks, e.g.:
- integer / integer -> integer (not floating point, but if one operand is float, it returns float)
- unsigned int (opr) signed int -> unsigned int
- & is bitwise-and, && is boolean-and, likewise with or: |, ||
- c++ base 0 arrays, versus base X in delphi. (range_array class in nSupport.h emulates that)
Optimizations:
* var = var opr value --> var opr= value;
* var = var + 1 --> ++ var;
* and a few more
I added file nSupport.h that has a few Delphi emulation functions and classes. The shared global variables are only declared in the header file. I've not defined them in the cpp files yet.
Attached File(s)
tycho
post Aug 27 2012, 23:19
Thank you guys. I already did IntToStr() and Copy(), but the rest goes straight in. Actually, I simply replaced directly Copy() with substr() and did the -1 adjustment. I've defined variables in cpp files, and implemented Bit_Scan_Left() and ..Right(). Both GCC and Visual Studio have intrinsic functions for these, and they are now used. There is a C-implementation for other compilers/HW as well. /add: I've also done Val()
I think the stdint.h thing is a minor problem, only the int32_t and int64_t are used. Most important now is to get it working on ONE compiler, then it's a simple matter to port it to others (older etc).
The WAV-reading files could possibly be used, although I hope it's is easier to implement the rest of the Delphi IO functions that are missing. These are roughly:
AssignFile
BlockRead
BlockWrite
Close
CloseFile
DirectoryExists
Eof
FileGetAttr
FileMode
FilePos
FileSetAttr
Reset
Rewrite
Seek
Others:
Build
DateTimeToString
Format
Now
Like I said before, many of these can be replaced with a single correponding c++ stdlib function, others need small wrappers.
This post has been edited by tycho: Aug 27 2012, 23:50
RSS Lo-Fi Version Time is now: 19th April 2015 - 20:59
