> Upload forum rules
lossyWAV 1.3.0 source translated to C++ from Delphi
tycho
post Aug 26 2012, 22:02
Here is the first public preview of the source translation of lossyWAV 1.3.0 to C++. It is not finished, but the main work is done.
- vc10_err.txt list the current compiler output in Visual Studio C++ 2010.
- A number of built-in Delphi functions are not yet converted. Most are trivial, but Write() involves some work.
Please note, I know very little of how the code actually works, I basically translated it line by line, and did minor optimizations.
Developers can look over the code and compare with the Delphi source. I have tried to take into account a number of C++'s quirks, e.g.:
- integer / integer -> integer (not floating point, but if one operand is float, it returns float)
- unsigned int (opr) signed int -> unsigned int
- & is bitwise-and, && is boolean-and, likewise with or: |, ||
- c++ base 0 arrays, versus base X in delphi. (range_array class in nSupport.h emulates that)
Optimizations:
* var = var opr value --> var opr= value;
* var = var + 1 --> ++ var;
* and a few more
I added file nSupport.h that has a few Delphi emulation functions and classes. The shared global variables are only declared in the header file. I've not defined them in the cpp files yet.
Attached File(s)
[JAZ]
post Aug 27 2012, 22:01
Oops..
Yes, you're right. I should have looked better for the correct way of doing so:
#if defined _MSC_VER
#if _MSC_VER > 1500
#include <stdint>
#else
typedef __int8 int8_t;
typedef unsigned __int8 uint8_t;
typedef __int16 int16_t;
typedef unsigned __int16 uint16_t;
typedef __int32 int32_t;
typedef unsigned __int32 uint32_t;
typedef __int64 int64_t;
typedef unsigned __int64 uint64_t;
#endif
#endif
Seems this existed since VC6 (so that makes it compatible with enough older versions)
RSS Lo-Fi Version Time is now: 4th June 2015 - 00:13
