If the output is digital does the player make any difference to the so
db579
post Jul 31 2012, 00:21
I'm wondering whether if you had two media playing pieces of hardware outputting digital music would the quality of the device make any difference? For example say you had a cheap-to-mid range android phone or mp3 player playing a flac file and outputting over HDMI to a receiver, and a higher spec digital media player like say the Olive 06HD playing the same flac file output over HDMI to a receiver would you hear/should there theoretically even be any difference in audio quality?
xnor
post Aug 2 2012, 18:50
As I said, isochronous (adaptive) transfer can work perfectly fine.
Sighted evaluation without blind testing is blind.
Arnold B. Kruege...
post Aug 2 2012, 18:55
QUOTE (xnor @ Aug 2 2012, 13:50) *
I would like to see a real-world reliable test that shows it working any way but fine.
All we seem to have is these anecdotes.
xnor
post Aug 2 2012, 21:21
QUOTE (Arnold B. Krueger @ Aug 2 2012, 19:55) *
So you think a lot of people, including me (on my old notebook anyway), imagine audio glitches like VERY ANNOYING clicks or drop-outs with USB DACs? Screenshots of DPC latency measurements that clearly show that the hardware isn't able to stream audio glitch-free are anecdotes too?
Just because you haven't seen it yourself doesn't mean it's not real.
This post has been edited by xnor: Aug 2 2012, 21:25
saratoga
post Aug 2 2012, 21:28
QUOTE (xnor @ Aug 2 2012, 16:21) *
That does not follow. I don't think anyone here doubts that audio drop outs can happen with buggy hardware. I've certainly seen data corruption from USB drivers for instance. Doesn't mean I think the MSC spec is broken.
Thats the problem with anecdotal reports about glitches. You don't know what caused it. Driver bug? Chipset errata? Problem with the USB spec? What conclusion can you safely draw when you don't know what happened?
xnor
post Aug 2 2012, 21:38
QUOTE (saratoga @ Aug 2 2012, 22:28) *
If a user that reported the problem reduces the DPC latency and the problems disappear then I draw the conclusion that most likely a too high DPC latency was the problem. Unfortunately, not all users can fix their hardware configuration / drivers so they end up returning the device and replacing it with an S/PDIF or Firewire or PCIe or async. USB interface which seem to make less problems. HDMI, as I said, I don't know.
On my old laptop, for example, disabling WLAN reduces the DPC latency considerably and gets rid of nasty spikes that caused drop-outs. Still not convinced?
This post has been edited by xnor: Aug 2 2012, 21:39
Arnold B. Kruege...
post Aug 3 2012, 13:15
QUOTE (xnor @ Aug 2 2012, 16:38) *
My old laptop and my new laptop run audio over USB just swell using a very basic interface - the Behringer UCA 202 with no parameter changes from defaults, and both or either WLAN or wired LAN active and in use.
There was a lot of discussion of asynch USB over at AVS a while back, and subtle SQ and jitter were the only issues raised. No advocate of Aysnch USB was able to proffer a DBT or any measurement that supported their claims. In short, each and every problem was perceived and subtle which is to say, probably imaginary. I'm not saying that Asynch can't be a problem solver, I'm saying that it is an effective solution that is in search of a real-world problem that is actually causing someone audible problems. OK, it finds a few such people. Next!
I think that we all know that measuring a problem or nailing it in a DBT are both slam dunks when the kind of problems you describe are active. Since this isn't happening, the basic problem must be pretty rare.
What I take away is that the problems you mention are rare, and when they arise they are due to pre-existing technical difficulties that are both far more global within the laptop, and/or also very much peculiar to the laptop sample where they are observed. Most people are interested in Asynch USB because they are led into it by people with commercial interests ar a desire to be opinion leaders, not because of any actual audible problems that they are experiencing. In many cases you can buy a whole new really pretty good laptop (or several!) for the price premium of the Asynch USB interface.
Also, it appears that adding Asynch mode to a USB audio interface may be just a matter of changing the firmware. It shouldn't be increasing the price of the equipment by 1,000% or 10,000% which it currently is doing.
The world is full of USB audio interfaces that served their owners very well without any asynch support at all. I can wait for it to become a standard feature, which might even take a few years.
xnor
post Aug 3 2012, 15:01
QUOTE (Arnold B. Krueger @ Aug 3 2012, 14:15) *
My new computer also runs fine (average DPC latency of 60 us). So what?
Right, it's so rare that pro audio manufacturers have articles on this problem.
For example: avid/m-audio kb
or NI kb
or echo audio support
or focusrite even has a video
or just search in their forums.
Yes, it absolutely MUST be a pretty rare problem.
These problems are not limited to laptops. In fact, for example, certain nvidia driver versions had horrible latency problems. So do/did other devices' drivers.
I don't know about the firmware but I agree with the other points you make. I'm not advocating to buy an async interface either. As you've said it's probably cheaper to get a better laptop or PC that will run flawlessly with the interface.
All I'm saying is that even if the output is digital the player (a computer in this case) can make a difference under certain circumstances. These circumstances are certainly not the rule but those problems do exist and I wouldn't say they are pretty rare.
This post has been edited by xnor: Aug 3 2012, 15:04
probedb
post Aug 3 2012, 16:25
QUOTE (xnor @ Aug 3 2012, 15:01) *
or NI kb
You mean those pro audio manufacturers that are trying to get you to buy their expensive gear?
Not really a good argument there.
xnor
post Aug 3 2012, 16:55
QUOTE (probedb @ Aug 3 2012, 17:25) *
- db579   If the output is digital does the player make any difference to the so   Jul 31 2012, 00:21
- - xnor   I'd say that if you stay in the digital domain...   Jul 31 2012, 01:05
- - db579   Wouldn't jitter occur in the DAC process if at...   Jul 31 2012, 01:13
- - xnor   I think with HDMI it's entirely in the 'ha...   Jul 31 2012, 01:18
- - db579   Same thing for digital optical?   Jul 31 2012, 01:50
- - hlloyge   I think it's the same with all modern devices ...   Jul 31 2012, 07:33
- - probedb   Plus from reading around here, if you can actually...   Jul 31 2012, 08:15
- - db579   So with that in mind if you wanted portable audiop...   Jul 31 2012, 13:56
|- - Nessuno   QUOTE (db579 @ Jul 31 2012, 14:56) if you...   Jul 31 2012, 14:09
|- - Kohlrabi   QUOTE (db579 @ Jul 31 2012, 14:56) So wit...   Jul 31 2012, 14:14
|- - skamp   QUOTE (db579 @ Jul 31 2012, 14:56) So wit...   Jul 31 2012, 14:21
|- - greynol   QUOTE (db579 @ Jul 31 2012, 05:56) a good...   Jul 31 2012, 15:30
|- - Arnold B. Krueger   QUOTE (db579 @ Jul 31 2012, 08:56) So wit...   Aug 2 2012, 18:35
- - db579   I'm asking more out of theoretical interest th...   Jul 31 2012, 15:36
- - xnor   I think that portable players can easily sound bet...   Jul 31 2012, 15:39
- - greynol   The answer is yes, it is possible to get the same ...   Jul 31 2012, 15:43
|- - xnor   QUOTE (greynol @ Jul 31 2012, 16:43) To d...   Jul 31 2012, 16:54
- - db579   Interesting responses and not what I expected, tha...   Jul 31 2012, 15:48
- - skamp   The O2/ODAC is a portable DAC + headphone amp that...   Jul 31 2012, 16:46
- - db579   Thanks guys, really appreciate the detailed and he...   Jul 31 2012, 18:01
- - DVDdoug   QUOTE xnor - He seems to suggest that the response...   Jul 31 2012, 19:12
|- - xnor   QUOTE (DVDdoug @ Jul 31 2012, 20:12) It d...   Jul 31 2012, 20:07
||- - andy o   QUOTE (xnor @ Jul 31 2012, 12:07) I don...   Aug 1 2012, 15:46
||- - xnor   For example the Yamaha RX-V3900 was measured to ha...   Aug 1 2012, 16:37
||- - andy o   QUOTE (xnor @ Aug 1 2012, 08:37) For exam...   Aug 1 2012, 20:34
|- - mzil   QUOTE (DVDdoug @ Jul 31 2012, 14:12) ...D...   Jul 31 2012, 20:41
- - greynol   Identical numbers are fine and dandy, but they don...   Jul 31 2012, 20:08
- - db579   QUOTE (xnor @ Jul 31 2012, 20:07) Very fe...   Jul 31 2012, 21:14
- - yourlord   All things being equal, the delivered data should ...   Jul 31 2012, 22:33
|- - xnor   QUOTE (yourlord @ Jul 31 2012, 23:33) [.....   Jul 31 2012, 23:21
||- - Roseval   QUOTE (xnor @ Jul 31 2012, 23:21) Unlike ...   Aug 1 2012, 18:13
||- - xnor   QUOTE (Roseval @ Aug 1 2012, 19:13) As an...   Aug 1 2012, 18:34
||- - greynol   QUOTE (xnor @ Aug 1 2012, 10:34) I guess ...   Aug 1 2012, 18:40
|- - mzil   The signal the HDMI output sends gets transfered p...   Aug 1 2012, 00:16
|- - yourlord   QUOTE (mzil @ Jul 31 2012, 19:16) The sig...   Aug 1 2012, 03:33
- - mzil   ^Do you have any evidence that level is audible to...   Aug 1 2012, 17:07
- - xnor   Nope and that's why I didn't make that cla...   Aug 1 2012, 17:17
|- - pdq   QUOTE (xnor @ Aug 1 2012, 12:17) Nope and...   Aug 1 2012, 19:51
|- - Arnold B. Krueger   QUOTE (xnor @ Aug 1 2012, 12:17) Nope and...   Aug 2 2012, 18:50
- - mzil   If you are allowed to turn up the volume and liste...   Aug 1 2012, 17:31
- - greynol   Do DACs matter? Perhaps, but if you can't dem...   Aug 1 2012, 17:59
- - Roseval   QUOTE If frames need to arrive every ms but do not...   Aug 1 2012, 18:50
|- - Arnold B. Krueger   QUOTE (Roseval @ Aug 1 2012, 13:50) QUOTE...   Aug 2 2012, 18:41
- - greynol   How about the word horrible? EDIT: Just saw your ...   Aug 1 2012, 20:38
- - xnor   As I said, isochronous (adaptive) transfer can wor...   Aug 2 2012, 18:50
|- - Arnold B. Krueger   QUOTE (xnor @ Aug 2 2012, 13:50) As I sai...   Aug 2 2012, 18:55
|- - xnor   QUOTE (Arnold B. Krueger @ Aug 2 2012, 19...   Aug 2 2012, 21:21
|- - saratoga   QUOTE (xnor @ Aug 2 2012, 16:21) QUOTE (A...   Aug 2 2012, 21:28
|- - xnor   QUOTE (saratoga @ Aug 2 2012, 22:28) What...   Aug 2 2012, 21:38
|- - saratoga   QUOTE (xnor @ Aug 2 2012, 16:38) On my ol...   Aug 2 2012, 21:44
||- - xnor   QUOTE (saratoga @ Aug 2 2012, 22:44) I...   Aug 2 2012, 21:57
||- - saratoga   QUOTE (xnor @ Aug 2 2012, 16:57) QUOTE (s...   Aug 5 2012, 00:55
||- - phofman   QUOTE (saratoga @ Aug 5 2012, 01:55) No, ...   Aug 5 2012, 21:03
||- - [JAZ]   QUOTE (phofman @ Aug 5 2012, 22:03) Actua...   Aug 5 2012, 21:40
||- - xnor   QUOTE ([JAZ] @ Aug 5 2012, 22:40)...   Aug 5 2012, 23:39
|- - Arnold B. Krueger   QUOTE (xnor @ Aug 2 2012, 16:38) QUOTE (s...   Aug 3 2012, 13:15
|- - xnor   QUOTE (Arnold B. Krueger @ Aug 3 2012, 14...   Aug 3 2012, 15:01
|- - probedb   QUOTE (xnor @ Aug 3 2012, 15:01) Right, i...   Aug 3 2012, 16:25
||- - xnor   QUOTE (probedb @ Aug 3 2012, 17:25) You m...   Aug 3 2012, 16:55
||- - Arnold B. Krueger   QUOTE (xnor @ Aug 3 2012, 11:55) QUOTE (p...   Aug 3 2012, 16:59
|- - Arnold B. Krueger   QUOTE (xnor @ Aug 3 2012, 10:01) QUOTE (A...   Aug 3 2012, 16:55
||- - xnor   QUOTE (Arnold B. Krueger @ Aug 3 2012, 17...   Aug 3 2012, 17:19
||- - Arnold B. Krueger   QUOTE (xnor @ Aug 3 2012, 12:19) QUOTE (A...   Aug 3 2012, 22:26
||- - xnor   QUOTE (Arnold B. Krueger @ Aug 3 2012, 23...   Aug 3 2012, 22:38
||- - Arnold B. Krueger   QUOTE (xnor @ Aug 3 2012, 17:38) QUOTE (A...   Aug 4 2012, 23:43
||- - xnor   QUOTE (Arnold B. Krueger @ Aug 5 2012, 00...   Aug 5 2012, 00:36
||- - Arnold B. Krueger   QUOTE (xnor @ Aug 4 2012, 19:36) QUOTE (A...   Aug 6 2012, 08:14
|- - yourlord   QUOTE (xnor @ Aug 3 2012, 10:01) All I...   Aug 3 2012, 17:17
|- - xnor   QUOTE (yourlord @ Aug 3 2012, 18:17) That...   Aug 3 2012, 17:28
- - greynol   ...and poor subject/verb agreement, lol.   Aug 2 2012, 18:58
- - Roseval   A test by Jim Lesurf: http://www.audiomisc.co.uk/L...   Aug 2 2012, 19:05
|- - Arnold B. Krueger   QUOTE (Roseval @ Aug 2 2012, 14:05) A tes...   Aug 2 2012, 19:26
- - [JAZ]   @ xnor: That example does not apply. I do have hi...   Aug 2 2012, 22:13
|- - xnor   QUOTE ([JAZ] @ Aug 2 2012, 23:13)...   Aug 2 2012, 22:35
- - Roseval   It is very simple. USB Audio is a isochronous stre...   Aug 4 2012, 09:43
|- - db579   Thanks for that Roseval really clear helpful expla...   Aug 4 2012, 16:29
- - Roseval   Thanks There are a couple of exiting developments...   Aug 4 2012, 21:22
|- - db579   @roseval So am I right in thinking this would be i...   Aug 5 2012, 15:02
|- - Roseval   The USB DACs being UAC1 or UAC2 compliant (use the...   Aug 5 2012, 17:14
- - phofman   If you raise playback buffer/playback latency, wil...   Aug 6 2012, 17:43
- - [JAZ]   phofman: Yes and no. With windows Vista and upwa...   Aug 6 2012, 19:00
|- - phofman   QUOTE ([JAZ] @ Aug 6 2012, 20:00)...   Aug 6 2012, 20:19
|- - [JAZ]   QUOTE (phofman @ Aug 6 2012, 21:19) DPC i...   Aug 6 2012, 22:08
|- - phofman   QUOTE Yes, that says the maximum has been 19 milli...   Aug 7 2012, 11:46
- - Roseval   Maybe this link is of use: http://www.rme-audio.de...   Aug 6 2012, 22:43
RSS Lo-Fi Version Time is now: 4th August 2015 - 09:17
