File Comparison of two flac images, Using Flac fingerprint
c1c2c3
post Jul 16 2012, 22:38
Im just checking my backup drive bit by bit against my music folder which
contains all those accurately ripped and compressed flac files.
Im using Total Commander performing this check.
Here the trouble starts.
Some files are not equal, compared bit by bit. But I cant tell
if its just some metadata I changed.
Im sure flac fingerprint could do the job, but Im running on W764bit
and I cant get flac frontend to work on my machine.
Is there a versatile and easy to perform way to compare two
flac files if the audio data is identical (without using flac frontend)?
Thanks in advance
c1c2c3
Replies (1 - 9)
lvqcl
post Jul 16 2012, 22:40
foobar2000 + foo_bitcompare plugin.
c1c2c3
post Jul 16 2012, 22:46
Thanks for your fast reply. Should have read the documentation
of foo bitcompare. Shame on me and big hug to you.
This post has been edited by c1c2c3: Jul 16 2012, 22:46
c1c2c3
post Jul 16 2012, 23:31
Just to complete this thread: Worked like a charm as soon as
I figured out to mark all tracks to get the menu "compare" inside utils.
greynol
post Jul 16 2012, 23:58
Probably would have been faster and just as effective to have simply just run a test decode with flac without it actually writing to your drive (flac -t). Maybe this is too late for the OP, but at least future readers might see this as a more worthwhile (or not) alternative.
This post has been edited by greynol: Jul 17 2012, 00:04
c1c2c3
post Jul 31 2012, 11:38
Would a test decode always prove that the musical information of
a backup file is the same as the original?
Kohlrabi
post Jul 31 2012, 12:23
If you decode two lossless encodes of the same source file, then yes, the decoded stream is (and has to be, that's what lossless means!) identical, unless either one of the encoders or the decoder is broken in some way.
This post has been edited by Kohlrabi: Jul 31 2012, 12:23
greynol
post Jul 31 2012, 13:16
QUOTE (c1c2c3 @ Jul 31 2012, 03:38) *
Would a test decode always prove that the musical information of a backup file is the same as the original?
If you're concerned about audio data changing from copying a flac to a different location and/or altering its metadata then yes, a test decode does indeed prove that it didn't happen.
spoon
post Jul 31 2012, 14:28
dBpowerAMP developer
Group: Developer (Donating)
As long as the file is not held in a cache, ie you copy File >> some drive, then run decode on said file, it might come from a memory cache not the drive, to be sure you would have to do a full restart of the computer.
Spoon http://www.dbpoweramp.com
greynol
post Jul 31 2012, 15:23
Based on the information in the original post, possible caching issues won't apply.
RSS Lo-Fi Version Time is now: 3rd August 2015 - 13:28
