> foobar2000 Development Forum Rules
This forum is for developer discussions only. If you have a problem / bug report / idea / feature request that isn't related to foobar2000 SDK, post it in an appropiate forum instead - tech support questions go to support forum, everything else goes to general forum.
All non-developer posts on this forum will be removed. Continued abuse of this forum will result in admin actions (warnings, account suspension).
Is it possible to have fb2k send out data through a serial port?
excsniper
post Jul 13 2012, 19:15
I'm thinking of a project that involves controlling external hardware with audio data from fb2k.
Canar
post Jul 13 2012, 19:24
You'll need to use a DSP component. Output component development tools are no longer included in the SDK.
2. Assume good faith.
excsniper
post Jul 13 2012, 19:39
QUOTE (Canar @ Jul 13 2012, 13:24) *
So is it possible to write a DSP that will interact with the serial port?
pawelq
post Jul 14 2012, 02:29
QUOTE (Canar @ Jul 13 2012, 14:24) *
I suspect that another option is writing a serial port driver that will present to the OS as an audio driver.
Ceterum censeo, there should be an "%is_stop_after_current%".
foosion
post Jul 14 2012, 09:06
Group: FB2K Moderator (Donating)
QUOTE (Canar @ Jul 13 2012, 19:24) *
An alternative would be to use a visualization. With a visualization you have more control over how many instances are created and can be sure you only process data from playback (and not from conversion). It depends on how much you trust the user. If it is only for your own use you probably would not spend as much time on making it fool-proof as you would for a public release.
In either case (DSP or visualization) your code can do pretty much whatever you want.
RSS Lo-Fi Version Time is now: 3rd March 2015 - 13:42
