Are high sample rates better for DSP?
Ethan Winer
post Jun 10 2012, 20:13
I've read many times that audio plug-ins such as equalizers work better at higher sample rates, even if audio generally doesn't benefit. It seems unlikely that there's a practical advantage to up-sampling all your files, or recording at 96 KHz in the first place, but is there a potential theoretical improvement? Or is this just another Internet myth?
--Ethan
I believe in Truth, Justice, and the Scientific Method
benski
post Jun 10 2012, 21:17
Winamp Developer
Yes, many filters work better with higher sampling rates. Particularly resonant filters (of the kind used in EQ) as well as filters feedback paths, such as emulations of analog filters. Many of these kinds of filters are only accurate (desired Fc versus actual Fc) and stable up to perhaps 1/8 Fs. With certain filter topologies, the filter cutoff point and resonance self-oscillation frequency start to drift apart at higher frequencies, also.
For these reasons, it is much better to oversample the input before the filters so that the audio band lies within the "good" range of the filter.
Unfortunately, good resampling is often slow, and more importantly, latent, so it can at times be more advantageous to simply run the whole processing chain at some high sampling frequency, e.g. 384kHz.
Also: non-linear effects, such as distortion, will almost always alias. Certain effects that seem linear are actually not, as fast modulation of parameters such as gain (for a compressor/expander) or filter cutoff (wah pedal) will introduce aliasing as well. Oversampling reduces aliasing in the audio band, as the aliased signal typical falls off 6dB/octave.
This post has been edited by benski: Jun 10 2012, 21:21
- Ethan Winer   Are high sample rates better for DSP?   Jun 10 2012, 20:13
- - knutinh   The higher the sample-rate, the better any approxi...   Jun 10 2012, 20:46
- - lvqcl   Here is an example of such filter (with explanatio...   Jun 10 2012, 20:56
- - benski   Yes, many filters work better with higher sampling...   Jun 10 2012, 21:17
|- - Ethan Winer   QUOTE (knutinh @ Jun 10 2012, 15:46) The ...   Jun 11 2012, 17:18
|- - saratoga   If your software is good, it should be upsampling ...   Jun 11 2012, 17:53
|- - drewfx   QUOTE (Ethan Winer @ Jun 11 2012, 12:18) ...   Jun 11 2012, 19:11
|- - Ethan Winer   QUOTE (saratoga @ Jun 11 2012, 12:53) If ...   Jun 12 2012, 17:46
|- - extrabigmehdi   QUOTE (Ethan Winer @ Jun 12 2012, 16:46) ...   Jun 12 2012, 18:15
- - xnor   Many EQs use simple bilinear-transformed filters (...   Jun 11 2012, 01:37
- - Woodinville   In addition to the warping one sees in a bilinear ...   Jun 11 2012, 01:46
- - extrabigmehdi   That's interesting, so basically if you want ...   Jun 11 2012, 02:30
- - bandpass   QUOTE (knutinh @ Jun 10 2012, 20:46) The ...   Jun 11 2012, 08:00
|- - knutinh   QUOTE (bandpass @ Jun 11 2012, 09:00) Tru...   Jun 11 2012, 08:30
- - bandpass   From a practical perspective, a particular effect/...   Jun 11 2012, 09:59
|- - knutinh   QUOTE (bandpass @ Jun 11 2012, 10:59) ......   Jun 11 2012, 11:55
- - greynol   I know the unofficial mantra around here is all th...   Jun 12 2012, 17:59
|- - Ethan Winer   QUOTE (greynol @ Jun 12 2012, 12:59) You...   Jun 12 2012, 19:35
|- - drewfx   QUOTE (Ethan Winer @ Jun 12 2012, 14:35) ...   Jun 12 2012, 20:29
|- - saratoga   QUOTE (Ethan Winer @ Jun 12 2012, 14:35) ...   Jun 12 2012, 21:12
|- - Ethan Winer   Thanks Drew for some hard evidence. Can you explai...   Jun 12 2012, 22:46
||- - benski   It's mostly that the shape (aka Q) is going to...   Jun 12 2012, 23:39
||- - drewfx   QUOTE (Ethan Winer @ Jun 12 2012, 17:46) ...   Jun 13 2012, 01:52
||- - andy o   I'm guessing these are the reasons why A/V rec...   Jun 13 2012, 03:27
|||- - Arnold B. Krueger   QUOTE (andy o @ Jun 12 2012, 22:27) I...   Jun 25 2012, 13:10
|||- - Woodinville   QUOTE (Arnold B. Krueger @ Jun 25 2012, 05...   Jun 27 2012, 21:59
||- - Ethan Winer   QUOTE (drewfx @ Jun 12 2012, 20:52) The 1...   Jun 13 2012, 19:55
|- - Woodinville   QUOTE (saratoga @ Jun 12 2012, 13:12) QUO...   Jun 13 2012, 01:22
- - greynol   Have you read the responses to your topic? I want...   Jun 12 2012, 19:42
- - greynol   As for the "it's best to record at 96kHz ...   Jun 13 2012, 00:53
RSS Lo-Fi Version Time is now: 1st August 2015 - 13:11
