Using all that CD has to offer?, What types of music and specific discs use the full bits and freq.
BearcatSandor
post Jun 8 2012, 05:13
(i'm probably oversimplifying this in my ignorance about it)
QUOTE (greynol @ Jun 5 2012, 07:35) *
QUOTE (jamie_P84 @ Jun 3 2012, 14:04) *
Dynamic range of analogue vs digital cannot be compared so easily either - the former can provide subjectively useable dynamic range which exceeds that of its digital equivalent, because it 'fails gracefully' above its rated maximum range, continuing to capture information which, in the digital domain, would have simply been truncated (resulting in a clipped waveform).
You're looking at the wrong end. Where is the noise floor? As a delivery format 16 bits is sufficient in storing this information. With the vast majority of the music out there and especially from the artists referenced in this discussion this can be done with fewer than 16 bits.
This got me wondering what styles of music generally do use the full bandwidth and bit-width available on CDs? The bits provide the dynamic range, yes? So classical would be more likely to take advantage of all 16 bits than rock recordings? What about frequency response? What types of music are likely to span that 18.5hz - 22.5khz range? Electronic? Classical again?
Anyone have an specific discs that utilize all the bandwidth and bits that CD has to offer?
As an aside, i do remember reading a subwoofer shootout in some magazine where they measured some CDs as going down to 16hz. Doesn't that go below the limits of CDs? Were they probably just listening to reflections?
Music lover and recovering high end audiophile
BearcatSandor
post Jun 8 2012, 23:19
I think i might be confusing two things: the intended auditory freq. range and the freq range that the CD can produce that can be measured via equipment.. I have read (somewhere a long time ago) that the reason 44.1 was picked was because that gave you a frequency range of 44.1/2 on either side of the middle. That means up to 22.1lkhz and down to 18.1hz, and there are some people that can hear that range. If a CD (and the system it's playing on) can reproduce frequencies lower than you can hear, you can still appreciate it tactically in some cases which would still mean that the lower frequencies are of value to a listener, though i'd imagine you'd have to turn the system volume up quite a bit.
i was responding to someone saying that most music doesn't cover the dynamic and freq. range of a 16/44.1 let alone 24/96k so i was wondering what music did. It was well answered.
I'll have to check out that Kodo disk. I saw them play live once and that was an awesome experience.
Arnold B. Kruege...
post Jun 9 2012, 11:53
QUOTE (BearcatSandor @ Jun 8 2012, 18:19) *
There is simply no doubt that the CD format can handle frequencies far lower than 18.1 Hz.
- BearcatSandor   Using all that CD has to offer?   Jun 8 2012, 05:13
- - pdq   AFAIK there is no lower limit to frequencies allow...   Jun 8 2012, 11:24
|- - pawelq   QUOTE (pdq @ Jun 8 2012, 06:24) AFAIK the...   Jun 8 2012, 14:04
- - dhromed   Lots of electronic music trivially uses the entire...   Jun 8 2012, 11:52
- - Brand   QUOTE (BearcatSandor @ Jun 8 2012, 06:13)...   Jun 8 2012, 11:55
- - knutinh   Q: What music use all of the bits that CD has to o...   Jun 8 2012, 12:32
|- - db1989   QUOTE (knutinh @ Jun 8 2012, 12:32) Q: Wh...   Jun 8 2012, 12:36
- - Arnold B. Krueger   QUOTE (BearcatSandor @ Jun 8 2012, 00:13)...   Jun 8 2012, 13:12
|- - dhromed   QUOTE (Arnold B. Krueger @ Jun 8 2012, 14...   Jun 8 2012, 14:23
|- - knutinh   QUOTE (Arnold B. Krueger @ Jun 8 2012, 14...   Jun 8 2012, 22:18
- - pdq   As an aside, does anyone know the lowest frequency...   Jun 8 2012, 13:53
|- - Arnold B. Krueger   QUOTE (pdq @ Jun 8 2012, 08:53) As an asi...   Jun 8 2012, 15:30
|- - DonP   QUOTE (Arnold B. Krueger @ Jun 8 2012, 10...   Jun 8 2012, 19:01
- - greynol   Why aren't we also considering the limitations...   Jun 8 2012, 15:09
|- - Arnold B. Krueger   QUOTE (greynol @ Jun 8 2012, 10:09) Why a...   Jun 8 2012, 15:25
|- - greynol   It was in direct reply to the following: QUOTE (Ar...   Jun 8 2012, 19:26
- - greynol   Depends on the source material. Some genres fare ...   Jun 8 2012, 15:39
|- - Arnold B. Krueger   QUOTE (greynol @ Jun 8 2012, 10:39) Rathe...   Jun 8 2012, 17:15
|- - DonP   QUOTE (greynol @ Jun 8 2012, 10:39) Rathe...   Jun 8 2012, 19:21
- - greynol   Let's not make this discussion about any parti...   Jun 8 2012, 17:18
- - naturfreak   QUOTE (pdq @ Jun 8 2012, 11:24) AFAIK the...   Jun 8 2012, 19:56
- - BearcatSandor   I think i might be confusing two things: the inten...   Jun 8 2012, 23:19
|- - stephan_g   QUOTE (BearcatSandor @ Jun 8 2012, 23:19)...   Jun 9 2012, 00:28
|- - greynol   QUOTE (BearcatSandor @ Jun 8 2012, 15:19)...   Jun 9 2012, 00:28
|- - Arnold B. Krueger   QUOTE (BearcatSandor @ Jun 8 2012, 18:19)...   Jun 9 2012, 11:53
|- - dhromed   QUOTE (BearcatSandor @ Jun 9 2012, 00:19)...   Jun 9 2012, 12:30
- - greynol   I assumed it was a typo and thought he was talking...   Jun 9 2012, 16:45
- - BearcatSandor   Ah, i see where i screwed up. Thanks folks. Grey...   Jun 9 2012, 22:16
|- - stephan_g   QUOTE (BearcatSandor @ Jun 9 2012, 22:16)...   Jun 10 2012, 13:28
- - greynol   44.1kHz is how many samples there are in a second....   Jun 9 2012, 22:35
|- - mzil   QUOTE (greynol @ Jun 9 2012, 17:35) 44.1k...   Jun 10 2012, 20:43
|- - db1989   QUOTE (mzil @ Jun 10 2012, 20:43) [] can...   Jun 10 2012, 20:58
- - mzil   So our CD audio sampling rate could have been 40.5...   Jun 10 2012, 21:28
- - greynol   Actually there is no reason why a CD can't pro...   Jun 10 2012, 21:55
|- - lvqcl   QUOTE (greynol @ Jun 11 2012, 00:55) it c...   Jun 10 2012, 22:01
- - greynol   Of course not!   Jun 10 2012, 22:11
- - DVDdoug   QUOTE This got me wondering what styles of music g...   Jun 12 2012, 20:54
- - Porcus   Well CD can give you some very impressively silent...   Jun 12 2012, 21:20
- - greynol   ...and reverb tails. Better still with high-rez...   Jun 12 2012, 21:53
|- - Arnold B. Krueger   QUOTE (greynol @ Jun 12 2012, 16:53) ...a...   Jun 13 2012, 12:43
- - greynol   Oh FFS, I was continuing with the joke; but seriou...   Jun 13 2012, 13:16
|- - Arnold B. Krueger   QUOTE (greynol @ Jun 13 2012, 08:16) Oh F...   Jun 13 2012, 16:14
- - stephan_g   Back in the olden days this kind of signal actuall...   Jun 13 2012, 13:40
|- - krabapple   QUOTE (stephan_g @ Jun 13 2012, 08:40) On...   Jun 13 2012, 15:52
||- - mzil   QUOTE (krabapple @ Jun 13 2012, 10:52) QU...   Jun 13 2012, 17:32
|- - Arnold B. Krueger   QUOTE (stephan_g @ Jun 13 2012, 08:40) Ba...   Jun 13 2012, 16:55
|- - Stone Free   QUOTE (Arnold B. Krueger @ Jun 13 2012, 16...   Jun 14 2012, 16:29
- - pdq   "Nights in White Satin" was an experimen...   Jun 13 2012, 13:57
|- - Nessuno   QUOTE (pdq @ Jun 13 2012, 14:57) I haven...   Jun 13 2012, 14:46
- - stephan_g   I bought this one new a few years ago, and it seem...   Jun 14 2012, 21:04
RSS Lo-Fi Version Time is now: 2nd April 2015 - 06:11
