Retagging collection, need some advice.., DISCNUMBER, ALBUMARTIST, etc..
BelleAndZEK
post Jun 4 2012, 21:12
So I finally decided to retag my FLAC library because I want to get rid of the mp3 transcodes and only use FLAC instead. Will do with XBMC.
Now before I start, I'd like some advice on a few things..
EVERYTHING is tagged the same way right now:
- ARTIST
- TITLE
- TRACKNUMBER
- ALBUM
- DATE
- ENSEMBLE (for Album Artist, Tag&Rename used that.)
Here's what I'm going to do, what I want to do:
- Remove the ENSEMBLE tag and use ALBUMARTIST instead
- Use TOTALTRACKS
- Use TOTALDISCS
- Use DISCNUMBER
Now I'm wondering what's best.. Should I use a leading 0 for TOTALTRACKS, TOTALDISCS and DISCNUMBER or not?
For albums that have only 1 disc, should I use the TOTALDISCS tag or leave it blank? Same for DISCNUMBER..
For multi-disc albums, TOTALTRACKS is for each disc or the total of all discs? I'm guessing it's per disc...
Also, let say I have an album called 'Hello' and a CD-Single also called 'Hello' by the same artist. What's the best way to get the tracks of both releases not mixed together if I want ALBUM to just be "Hello" and not "Hello (CDS)" for CD-Single for instance? Is there a 'CDS' 'EP' 'Album' tag that most softwares recognize for that?
For albums with a bonus disc, is there a field I should be using for the name of the bonus disc? A field where I can add 'Live in ...' for the bonus disc for instance..
Any other tags I should take in consideration apart from GENRE? That one's too subjective.
I have thousands of albums to do, I just want to make sure I get things right before I start. Thanks!
This post has been edited by BelleAndZEK: Jun 4 2012, 21:15
skamp
post Jun 5 2012, 09:49
Xiph.org proposes TRACKTOTAL and DISCTOTAL, not TOTALTRACKS and TOTALDISCS. No leading 0 required (or even desired).
VERSION can also be of use, when you can get your player to display it.
db1989
post Jun 5 2012, 10:20
QUOTE (skamp @ Jun 5 2012, 09:49) *
Yes, and foobar2000 since v1.1.8 beta has adopted the recommended field names, though with an option in advanced preferences to use the previous ones.
godrick
post Jun 6 2012, 23:26
I generally recommend you do not pad your tags, because you can choose padding separately for display purposes using title formatting within foobar2000. For example, you can use [$num(%tracknumber%,1)] to display only one character in foobar2000, or use [$num(%tracknumber%,2)] to add a leading zero in foobar2000 for track numbers between 1 and 9. Assuming foobar2000 is your primary playback application, I find it easier to change title formatting than the actual tag value when I have the choice.
This post has been edited by godrick: Jun 6 2012, 23:29
- BelleAndZEK   Retagging collection, need some advice..   Jun 4 2012, 21:12
- - Ouroboros   I suspect that there are no definitive answers to ...   Jun 4 2012, 22:13
- - db1989   Like Ouroboros, I can only report my personal pref...   Jun 4 2012, 22:33
|- - Ouroboros   QUOTE (db1989 @ Jun 4 2012, 22:33) Indivi...   Jun 4 2012, 23:24
|- - db1989   But I use different types of case within the diffe...   Jun 5 2012, 00:44
- - Ron Jones   QUOTE Any other tags I should take in consideratio...   Jun 5 2012, 01:14
- - JJZolx   QUOTE (BelleAndZEK @ Jun 4 2012, 14:12) N...   Jun 5 2012, 03:14
|- - rohangc   QUOTE (JJZolx @ Jun 4 2012, 21:14) COMPIL...   Jun 5 2012, 03:54
- - BelleAndZEK   Yeah forgot to mention COMPILATION. I never used t...   Jun 5 2012, 04:00
|- - JJZolx   QUOTE (BelleAndZEK @ Jun 4 2012, 21:00) e...   Jun 5 2012, 05:38
- - Porcus   A few personal two-centers on both tagging and nam...   Jun 5 2012, 09:30
- - Porcus   And, if you have classical music: You cannot count...   Jun 5 2012, 09:32
- - skamp   Xiph.org proposes TRACKTOTAL and DISCTOTAL, not TO...   Jun 5 2012, 09:49
|- - db1989   QUOTE (skamp @ Jun 5 2012, 09:49) Xiph.or...   Jun 5 2012, 10:20
|- - Porcus   QUOTE (db1989 @ Jun 5 2012, 11:20) QUOTE ...   Jun 5 2012, 12:35
|- - rohangc   QUOTE (db1989 @ Jun 5 2012, 04:20) QUOTE ...   Jun 6 2012, 04:43
||- - rohangc   Now that I think of it, please tell me whether thi...   Jun 6 2012, 05:30
|||- - EagleScout1998   QUOTE (rohangc @ Jun 5 2012, 23:30) Will ...   Jun 6 2012, 06:35
|||- - rohangc   QUOTE (EagleScout1998 @ Jun 6 2012, 00:35...   Jun 10 2012, 11:32
||- - JJZolx   QUOTE (rohangc @ Jun 5 2012, 21:43) QUOTE...   Jun 6 2012, 22:40
|- - godrick   I generally recommend you do not pad your tags, be...   Jun 6 2012, 23:26
- - skamp   foobar2000 (1.1.12a) uses whichever comes first, c...   Jun 5 2012, 13:51
- - db1989   QUOTE (rohangc @ Jun 6 2012, 05:30) Now t...   Jun 7 2012, 16:24
RSS Lo-Fi Version Time is now: 7th July 2015 - 04:38
