Wavpack hybrid rate playback and sweet spot?, Playback? sweet spot for hybrid file creation with no artifacts?
BearcatSandor
post May 31 2012, 23:08
I have my music collection ripped to wavpack lossless. I just got myself an Android (Galaxy Note for what it matters) and found the Neutron player which plays wavpack very nicely. Now, i want to move some wavpack files to my android and i have all these large lossless wavpack files. I'd like to convert them to hybrid files with correction. The wavpack site states the following about the -c option:
"When WvUnpack is used to restore the .wav file, it will attempt to find the .wvc file in the same directory as the .wv file. If it is found then the decompression will be lossless and will be reported as such, otherwise lossy decompression will be reported (assuming that any information was actually discarded during the original compression)"
1) That tells me that the correction file is used when wvunpack is done. I thought that i could keep the wv and wvc files on my pc for lossless playback and just move the wv files over to the android for lossy playback. Is this so?
2) I've seen some threads of people using -b5 for lossy. The manpage for -bn states a range of 2.0 - 23.9 so that seems really low. Where is the sweet spot as far as the -bn switch that will not produce any artifacts and still remain portable? I know it's a "depends" question (and i'm avoiding talk of subjective sound quality here) but what are you folks using as command lines for this purpose?
3) I'll be writing a bash script to process all these files (about 10k or so). I assume it's not possible to convert wavpack lossless directly to lossy. I'll have to unpack them to wav and then repack them to wavpack hybrid and reapply all tags. Right?
Thanks all, and thank you Bryant for an awsome file type!
This post has been edited by BearcatSandor: May 31 2012, 23:10
Music lover and recovering high end audiophile
db1989
post May 31 2012, 23:13
QUOTE (BearcatSandor @ May 31 2012, 23:08) *
Right on!
I think you’re correct that there is no way to ‘peel’ fully lossless files to lossy+correction, short of de/re-encoding. From there, if you have access to Windows, maybe this will help: http://www.hydrogenaudio.org/forums/index....showtopic=83294
This post has been edited by db1989: May 31 2012, 23:16
BearcatSandor
post Jun 1 2012, 00:26
Copytags, huh? I'll check that out. Thank you. I might be able to run it under Wine. As to the first part i think i posed the question in a confusing manner. What i meant was: Can i leave the wv files and wvc files on my pc and get lossless *playback* on it, and just move the wv files over to the android for lossy playback. The website *seems* to suggest that the wcv file is used when decoding back to wav and not for playback.
shadowking
post Jun 1 2012, 03:21
I would start with -b4 and try to avoid high modes. I think thats the sweetspot.
Generally, -b4x is fast works well. If you have more time, for more security: -b4x4.. If space isn't a big concern : -b5x
Wavpack -b450s0.7
bryant
post Jun 1 2012, 04:59
WavPack Developer
Group: Developer (Donating)
Regarding PC playback and correction files, see here.
I agree with shadowking on the use of -b that 4 bits per sample is the sweet spot and you'll probably never hear any artifact. The parameter goes up to [almost] 24 bits, but that's just for completeness...anything over 5.0 is kind of silly, especially with a correction file (the idea is that if you have the correction files somewhere, you might be a little more tolerant of an occasional benign artifact on the portable).
I actually use 384 kbps (which is the equivalent to -b4.35) for archiving stuff in pure lossy mode (no correction file) and have never been sorry.
BearcatSandor
post Jun 1 2012, 08:48
Thanks again Bryant, i'll take your advice and use around 4-5.
(to the forum i apologise for asking the same question twice in the same month. I've been exhausted lately and forgot i'd read that)
skamp
post Jun 1 2012, 09:54
QUOTE (BearcatSandor @ Jun 1 2012, 00:08) *
caudec can do that for you if you're running linux:
$ caudec -c wvh -q hx1 -b 384 /data/music/artist/album/*.wv
That command will transcode your WavPack files to WavPack Hybrid at 384 kbps with correction files, in parallel (if you have a multi-core CPU and enough RAM), while copying all the tags over. Currently there's a limitation [*] in that you can only specify a bitrate in kbps (24-9600) but that's an oversight that will be corrected in the next release.
This list of usage examples might also be of interest to you. There's one example in particular that shows how to transcode an entire library while mirroring the directory structure in one fell swoop.
[*] fixed in svn
This post has been edited by skamp: Jun 1 2012, 10:29
BearcatSandor
post Jun 7 2012, 08:47
Thanks. Caudec looks great and i'm working with your example script that you cited to create my own script. However, testing it on one directory i'm seeing:
2 ER 01-rain_on_the_scarecrow.wv
4 ER 03-small_town.wv
3 OK 02-grandma's_theme.wv
1 ER 04-minutes_to_memories.wv
2 ER 05-lonely_ol'_night.wv
4 ER 06-the_face_of_the_nation.wv
3 ER 07-justice_and_independence_'85.wv
1 ER 08-between_a_laugh_and_a_tear.wv
2 ER 09-rumbleseat.wv
3 ER 11-r.o.c.k._in_the_u.s.a._a_salute_to_60's_rock.wv
1 ER 12-the_kind_of_fella_i_am.wv
4 OK 10-you've_got_to_stand_for_somethin.wv
How do i determine what the errors were so i can fix them? Prowling around the wiki and help file i don't see the definition of those codes.
Here's the script:
find * -type f -name '*.wv' -exec dirname '{}' ';' | sort -u | while read d;
do
    echo "$d"
    mkdir -p "/mnt/backup/tmp/audio/${d}/artwork"
    cp -a "$d"/*.{jpg,png,gif} "/mnt/backup/tmp/audio/${d}"
    cp -a "$d"/artwork/*.{jpg,png,gif} "/mnt/backup/tmp/audio/${d}"/artwork/
    caudec -o "/mnt/backup/tmp/audio/${d}"  -c wvh -q hx1 -b 384 "$d"/*.wv
done
note: it's not creating the directories correctly, but i'm not asking for help with script debugging. I know this isn't the forum for that.
This post has been edited by BearcatSandor: Jun 7 2012, 08:54
skamp
post Jun 7 2012, 09:16
Those aren't error codes: the number is just the number of the process, and "ER" simply means an error occured while encoding ("DC" would mean an error occured while decoding).
One limitation caudec has, is that it doesn't work on files that have tag entries that span multiple lines.
If that's not the case with the files that are causing errors, could you please upload one of them somewhere (Dropbox or whatever) and PM me the URL?
Edit: the multiline bug occurs when transcoding from FLAC to FLAC and WavPack to WavPack. A quick fix is available in svn, which prevents caudec from failing, but multiline tags are still not copied over properly.
This post has been edited by skamp: Jun 7 2012, 09:57
skamp
post Jun 7 2012, 09:19
QUOTE (BearcatSandor @ Jun 7 2012, 09:47) *
Swing by #hydrogenaudio on Freenode (IRC), I can help you with that. I might not be immediately available during the next couple of days though.
This post has been edited by skamp: Jun 7 2012, 10:12
skamp
post Jun 7 2012, 18:18
I don't know if that was your problem, but the multi-line bug should be fixed in svn, though I need to do some more testing to make sure. You can get the latest svn revision with the following command:
svn checkout http://caudec.googlecode.com/svn/trunk/ caudec-read-only
BearcatSandor
post Jun 7 2012, 20:28
I removed the lyrics (multiline) tags from these files and still get the same error, even with your svn version. I'll PM you with more info. Thanks for all the help!
shadowking
post Sep 28 2012, 10:13
I did some more tests lately. I actually find bps in increments of 0.5 more convenient over MPEG bitrates. -b3..3.5..4..4.5 are very useful options when wanting to adjust quality . Bitrates are : 270..310..350..390
Using very high compression settings allow one to use much lower bitrate. I tried -hhx5 and had good results on critical samples using -b3.5 . -b3 was inferior but is expected to perform well when not caring for such samples.
Also the -l switch is pretty useful as it runs wavpack in low priority if you want a slow setting.
Wavpack -b450s0.7
RSS Lo-Fi Version Time is now: 26th January 2015 - 18:21
