1.1.12 ID3v2 changes - discussion, Was: "FEATURE REQUEST: The ability to disable all metadata taggin
BenB
post May 27 2012, 04:11
FEATURE REQUEST: The ability to disable all metadata tagging within foobar
With the release of 1.1.12, the developers have seen fit to implement a new way of handling custom TXXX frames within foobar that borks them everywhere else. Frames with the same name are now renamed by appending [1],[2],[3], etc. which makes them essentially different tags and no longer able to be used as intended outside of foobar. (Maybe inside too, idk, I did a separate portable install of 1.1.12 to investigate beforehand. At least the changes were vaguely referenced in the changelog.)
Also, multiple TCON frames (genre) are now joined into one frame and separated by a "/" with no spaces. This isn't so bad if you don't already utilize forward slashes within your genres, but if you do, guess what...
Oh and using the replaygain scanner on your files will alter your tags and change them as mentioned above.
So, how about it developers? Will give give us the means to disable your ability to manipulate our files according to your whims? What you've done isn't part of the id3v2.3 standard. I've been trying to understand the tagging in foobar, but it's just impossible. On one hand there's this almost strict adherence to specifications no one else abides by, while on the other hand, there are deviations from the standard implemented that conflict with the other deviations other software/hardware developers have implemented. If foobar's tagging were a person, it'd be simultaneously OCD and schizotypal. I wish someone could explain the reasoning behind this change. Was there an angry mob clamoring for it? If so, it's not apparent in the forums.
This post has been edited by BenB: May 27 2012, 04:12
kode54
post Jun 2 2012, 01:33
Group: Admin
id3lib does not enforce proper frame formatting, it will let you write as many values to a frame as you want, regardless of how many that particular frame is supposed to support.
From the ID3v2.4.0 frames document:
4.2.6. User defined text information frame
This frame is intended for one-string text information concerning the
audio file in a similar way to the other "T"-frames. The frame body
consists of a description of the string, represented as a terminated
string, followed by the actual string. There may be more than one
"TXXX" frame in each tag, but only one with the same description.
<Header for 'User defined text information frame', ID: "TXXX">
Text encoding $xx
Description <text string according to encoding> $00 (00)
Value <text string according to encoding>
If you want a library that enforces strict compliance, try libid3tag, if you can stomach the silly notion of a library being GPL.
MordredKLB
post Jun 2 2012, 02:24
QUOTE (kode54 @ Jun 1 2012, 19:33) *
I wrote up a big long post detailing how you were completely wrong and id3lib seemed extremely strict, then I checked and I've been using libid3tag biggrin.gif
So that explains why I can't get it to load more than 1 string per TXXX. I might modify the libid3tag source at some point to do this for TXXX frames, but I'm going to have to wait and see what foobar ends up doing to get around this. I don't particularly care how compliant the library is, but I do care that it works flawlessly with how foobar decides to handle these things.
- BenB   1.1.12 ID3v2 changes - discussion   May 27 2012, 04:11
- - Peter   If you insist that this behavior is problematic fo...   May 27 2012, 07:37
|- - tagtypedisplay   I'm confused. Is f2k's implementation of R...   May 27 2012, 07:44
- - db1989   If you’d actually read the initial post, you’d kno...   May 27 2012, 12:50
|- - tagtypedisplay   QUOTE (db1989 @ May 27 2012, 13:50) If yo...   May 27 2012, 13:47
- - tpijag   Using the ReplayGain scanner writes to replaygain ...   May 27 2012, 13:53
- - Peter   PS I'd like to know: * How exactly you tag you...   May 28 2012, 08:50
- - neothe0ne   The thing that really annoyed me was that upgradin...   May 28 2012, 10:37
- - Mod-Ular   @Peter First had to do some research as i did not ...   May 28 2012, 10:41
|- - mrinferno   having the same issue myself with 1.1.12a. i didn...   May 28 2012, 15:33
|- - Mod-Ular   QUOTE (Mod-Ular @ May 28 2012, 11:41...   May 29 2012, 11:06
- - montyview   Apologies if hijacking thread, but I think this is...   May 28 2012, 18:35
- - q-stankovic   QUOTE (mrinferno @ May 28 2012, 16:33) I ...   May 28 2012, 21:14
- - godrick   ID3v2.3 is terrible...except for all of the curren...   May 28 2012, 22:54
|- - wolfsong   QUOTE (godrick @ May 28 2012, 15:54) I ho...   May 29 2012, 07:26
|- - neothe0ne   QUOTE (godrick @ May 28 2012, 17:54) Edit...   May 31 2012, 14:08
- - q-stankovic   QUOTE (godrick @ May 28 2012, 23:54) Thus...   May 29 2012, 17:12
- - q-stankovic   As i didn't use multiple genres i decided to t...   May 30 2012, 22:16
- - godrick   q-stankovic, I share much of your frustration with...   May 31 2012, 01:15
- - Peter   Thanks for all your feedback. Regarding TPE2 Albu...   May 31 2012, 11:01
|- - MordredKLB   QUOTE (Peter @ May 31 2012, 05:01) Regard...   Jun 1 2012, 07:17
- - q-stankovic   QUOTE (Peter @ May 31 2012, 12:01) Regard...   May 31 2012, 19:00
- - kode54   id3lib does not enforce proper frame formatting, i...   Jun 2 2012, 01:33
- - MordredKLB   QUOTE (kode54 @ Jun 1 2012, 19:33) id3lib...   Jun 2 2012, 02:24
RSS Lo-Fi Version Time is now: 3rd March 2015 - 00:56
