WASAPI plug-in version 3.0 beta [closed], Discussion & feedback
Peter
post May 11 2012, 12:58
foobar2000 developer
Group: Admin
Closed: stable version out - get it here
What is this?
This plug-in adds Windows Audio Session API exclusive mode output support, allowing bit-exact output and muting all other sounds. Windows Vista or newer required.
Notable changes from the 2.x series:
* Faster volume control
* 32bit integer mode if 32bit floating-point is not supported by the device
* Operates in two different modes, regular and event-driven - the latter seems to be more compatible with USB devices, but not supported by some other devices.
* Separate process sandbox for improved stability.
New in beta 6:
* Made internal buffer sizes tweakable through Advanced Preferences for hopefully better compatibility.
* Increased internal buffer size for event mode for hopefully better glitch resilience on most systems.
* Changed output mode naming (now: "WASAPI (push)" and "WASAPI (event)").
How to install:
Double-click the .fb2k-component file.
If the above does not load the component into foobar2000, read here.
Preemptive replies:
"I've installed the component using means other than mentioned above and it doesn't work" => no we don't want to hear about it.
"I can't install .fb2k-component because I'm running an old foobar2000 version" => nope we don't want to hear about it either.
"The component doesn't work, I run Windows XP" => WASAPI requires Windows Vista or newer.
Download:
[s]Version 3.0 beta 6[s]
Enjoy.
Moofasa~
post May 18 2012, 02:48
I assume this plug-in will only support exclusive mode? I was wondering if there could be any benefits of using wasapi (non-exclusive) over directsound (lower latency maybe?).
Mr.Grey
post May 18 2012, 08:24
QUOTE (Moofasa~ @ May 18 2012, 03:48) *
working together a foobar2000 (exclusive mode) & other programs (non-exclusive)
with the previous version of plugin this was not possible
LynxTWO card
This post has been edited by Mr.Grey: May 18 2012, 08:25
- Peter   WASAPI plug-in version 3.0 beta [closed]   May 11 2012, 12:58
- - Emre   gave me error on my setup CODEUnrecoverable playb...   May 11 2012, 20:02
- - WarZard-X   Thank you! Works perfect with Win7 64bit ...   May 13 2012, 18:26
- - Sandrine   Added bonus: Now I can bitstream DTS files when us...   May 13 2012, 20:25
- - jaro1   Thanks Peter for upgrading the component, i've...   May 13 2012, 22:27
- - SoNic67   Thanks Peter! It works good on Win7 x64 and E-...   May 14 2012, 01:03
- - kode54   You will need to download it from this topic until...   May 14 2012, 03:12
- - Trondis   I have been trying to play back dts files through ...   May 14 2012, 17:48
- - Peter   QUOTE (Emre @ May 11 2012, 20:02) gave me...   May 17 2012, 08:10
|- - Helios61   QUOTE (Peter @ May 17 2012, 09:10) Anybod...   May 17 2012, 08:49
|- - Helios61   CODEWin7 64bit foobar2000 1.1.12 beta 6, WASAPI Ou...   May 25 2012, 09:34
- - Alex B   Thanks. It works for me just fine. Though also the...   May 17 2012, 10:21
|- - WarZard-X   QUOTE (Alex B @ May 17 2012, 11:21) Thank...   May 17 2012, 11:16
|- - Peter   QUOTE (WarZard-X @ May 17 2012, 11:1...   May 17 2012, 14:26
- - pyr0rrzzz   Upgraded, seems to work. (Win Vista 32bit, fb 1.1....   May 17 2012, 12:41
- - pyr0rrzzz   Actually, now I noticed that there are lots of art...   May 17 2012, 20:02
|- - Erich_2   QUOTE (pyr0rrzzz @ May 17 2012, 20:02) Ac...   May 17 2012, 20:52
|- - Enig123   QUOTE (Erich_2 @ May 18 2012, 03:52) QUOT...   May 21 2012, 01:19
- - Moofasa~   I assume this plug-in will only support exclusive ...   May 18 2012, 02:48
|- - Mr.Grey   QUOTE (Moofasa~ @ May 18 2012, 03:48) I a...   May 18 2012, 08:24
||- - Moofasa~   QUOTE (Mr.Grey @ May 18 2012, 02:24) QUOT...   May 18 2012, 13:24
|- - Case   QUOTE (Moofasa~ @ May 18 2012, 03:48) I a...   May 18 2012, 16:22
|- - Moofasa~   QUOTE (Case @ May 18 2012, 10:22) The com...   May 18 2012, 20:22
|- - Mr.Grey   QUOTE (Moofasa~ @ May 18 2012, 21:22) Ano...   May 19 2012, 07:12
|- - Moofasa~   QUOTE (Mr.Grey @ May 19 2012, 01:12) QUOT...   May 23 2012, 21:18
- - Jackal29a   Working fine here (i3 2100, W7 x86), no crackling ...   May 18 2012, 09:23
|- - Case   QUOTE (Jackal29a @ May 18 2012, 10:23) I...   May 18 2012, 16:26
|- - Jackal29a   QUOTE (Case @ May 18 2012, 17:26) It look...   May 18 2012, 18:39
||- - Case   QUOTE (Jackal29a @ May 18 2012, 19:39) Fo...   May 18 2012, 21:38
||- - Jackal29a   QUOTE (Case @ May 18 2012, 22:38) For the...   May 18 2012, 22:52
||- - Mr.Grey   QUOTE (Jackal29a @ May 18 2012, 23:52) No...   May 19 2012, 07:17
|- - Mr.Grey   QUOTE (Case @ May 18 2012, 17:26) It look...   May 22 2012, 08:13
|- - SoNic67   QUOTE (Mr.Grey @ May 22 2012, 03:13) foob...   May 24 2012, 02:42
- - jaro1   Under some hardware configurations low latency pul...   May 18 2012, 16:48
- - Case   Jackal29a, do you have Media Center DSPs configure...   May 19 2012, 09:51
|- - Jackal29a   QUOTE (Case @ May 19 2012, 10:51) Jackal2...   May 20 2012, 10:14
|- - db1989   QUOTE (Case @ May 19 2012, 10:51) Jackal2...   May 20 2012, 22:58
|- - Jackal29a   QUOTE (db1989 @ May 20 2012, 23:58) QUOTE...   May 21 2012, 00:00
- - jcooper138   I also have the "Unrecoverable playback error...   May 20 2012, 00:00
- - bsw11   While this version does fix the double click issue...   May 20 2012, 21:55
- - SoNic67   The above soundcards that"support" 32 bi...   May 20 2012, 22:20
- - Enig123   Works fine without "crackling" in the fi...   May 21 2012, 07:14
- - Jackal29a   I think a configurable output bitdepth like the on...   May 22 2012, 09:43
- - Peter   Topic split   May 22 2012, 18:40
- - sanaa   Tested with foobar 1.1.11 and Traktor Audio 2 soun...   May 23 2012, 20:15
- - Mr.Grey   Moofasa~ I am surprised, but it works that way ...   May 23 2012, 22:21
- - Mr.Grey   SoNic67 I agree with you   May 24 2012, 11:04
- - Peter   Beta 2 available, see the original post for detail...   May 24 2012, 16:47
|- - Emre   QUOTE (Peter @ May 24 2012, 18:47) Beta 2...   May 24 2012, 21:00
|- - Jackal29a   QUOTE (Peter @ May 24 2012, 17:47) Beta 2...   May 24 2012, 21:02
||- - Peter   QUOTE (Jackal29a @ May 24 2012, 21:02) (....   May 24 2012, 21:25
||- - Jackal29a   QUOTE (Peter @ May 24 2012, 22:25) QUOTE ...   May 24 2012, 23:12
|- - jaro1   QUOTE (Peter @ May 24 2012, 16:47) Beta 2...   May 27 2012, 03:16
- - coolcut   I have written this in another topic. I will post ...   May 25 2012, 12:33
|- - db1989   QUOTE (coolcut @ May 25 2012, 12:33) I ha...   May 25 2012, 19:59
- - Mr.Duck   Beta 2 working well here (Windows 7 64bit, Focusri...   May 25 2012, 19:04
- - coolcut   Yes, the problem is still present.   May 25 2012, 20:41
- - Enig123   With beta2 my FiiO E7 USB DAC plays files fine. Ju...   May 26 2012, 06:50
- - db1989   I don’t think that qualifies as “fine”…   May 26 2012, 10:52
|- - Enig123   QUOTE (db1989 @ May 26 2012, 17:52) I don...   May 26 2012, 19:25
- - Frank Bicking   Thread split: 32-bit capable DACs   May 26 2012, 13:57
- - jologsmaster   First of all, thanks a lot for the work being done...   May 28 2012, 10:46
- - jologsmaster   Just to update, beta 2 does not work with my HRT M...   May 28 2012, 12:56
- - Seeking_Lossless   Thanks Peter and co. Beta 2 work just fine on my L...   May 28 2012, 15:19
- - Enig123   Inspired by jologsmaster, I just re-tested beta1 w...   May 28 2012, 20:08
- - shoober420   I have Windows 7 64-bit, and a Creative X-Fi Titan...   May 29 2012, 20:23
- - Ceniza   There was a thread split recently, but I think it...   Jun 1 2012, 19:06
- - bsw11   Beta 2 seems much more stable. The only problem I...   Jun 2 2012, 18:37
- - Enig123   For me beta1 is more stable than beta2 speak of US...   Jun 2 2012, 19:47
|- - kode54   QUOTE (Enig123 @ Jun 2 2012, 11:47) For m...   Jun 2 2012, 20:38
- - jaro1   Exactly, the buffer size adjusted in the player op...   Jun 2 2012, 21:31
- - Peter   Beta 3 posted, see initial post for details.   Jun 4 2012, 14:06
- - Ceniza   Sweet! Beta 3 can now send uncompressed multi...   Jun 4 2012, 17:42
- - Enig123   beta3 event-driven mode, it went wrong just like b...   Jun 4 2012, 18:07
- - SoNic67   This beta 3.0 is working better with the VST plug-...   Jun 4 2012, 23:11
- - Jackal29a   beta 3 is working perfect with the Xonar ST!...   Jun 5 2012, 08:31
- - Peter   QUOTE (Enig123 @ Jun 4 2012, 18:07) beta3...   Jun 5 2012, 09:36
|- - Jackal29a   QUOTE (Peter @ Jun 5 2012, 10:36) Do you ...   Jun 5 2012, 10:24
- - Peter   Thanks for the log, but from now on please auto-su...   Jun 5 2012, 10:32
|- - Jackal29a   QUOTE (Peter @ Jun 5 2012, 11:32) Thanks ...   Jun 5 2012, 14:40
- - Peter   If you still have the .dmp file you got along with...   Jun 5 2012, 15:20
- - Peter   Bug fixed, thank you for your patience.   Jun 5 2012, 18:19
- - Peter   Beta 4 posted, see the initial post for details.   Jun 5 2012, 20:42
|- - Jackal29a   QUOTE (Peter @ Jun 5 2012, 21:42) Beta 4 ...   Jun 5 2012, 21:19
- - sld   This is working great! On a Go-vibe USB DAC t...   Jun 5 2012, 23:37
- - Peter   It seems low buffer values in the regular ("p...   Jun 6 2012, 07:48
|- - Jackal29a   QUOTE (Peter @ Jun 6 2012, 08:48) It seem...   Jun 6 2012, 08:36
- - SoNic67   Actually the manufacturer specs are correct. The ...   Jun 6 2012, 11:23
|- - Jackal29a   QUOTE (SoNic67 @ Jun 6 2012, 12:23) Actua...   Jun 6 2012, 11:57
|- - SoNic67   QUOTE (Jackal29a @ Jun 6 2012, 06:57) I...   Jun 6 2012, 23:49
- - off&on   QUOTE (Peter @ May 11 2012, 13:58) * MMCS...   Jun 6 2012, 12:28
|- - Kohlrabi   QUOTE (off&on @ Jun 6 2012, 13:28) Wh...   Jun 6 2012, 14:03
- - PatFromGermany   Well done Peter, well done... Beta 4 is perfect...   Jun 6 2012, 12:57
- - MordredKLB   He claims he was having audio dropouts, which woul...   Jun 6 2012, 17:28
- - db1989   Either that or it’s some alternative way to descri...   Jun 6 2012, 20:32
|- - Kohlrabi   QUOTE (db1989 @ Jun 6 2012, 21:32) Kohlra...   Jun 6 2012, 22:30
|- - off&on   Sorry I wasn't clear, and thanks to the kind s...   Jun 6 2012, 23:02
- - MordredKLB   Yeah, I never noticed a volume discrepancy when I ...   Jun 6 2012, 22:59
- - jologsmaster   Wow. Beta 4 event mode works really well with my H...   Jun 7 2012, 00:27
2 Pages V   1 2 >
Closed TopicStart new topic
3 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
RSS Lo-Fi Version Time is now: 2nd August 2015 - 19:07
