HD 280 Pro not satisfied
zerowalker
post May 5 2012, 18:42
Okay so i bought the HD280 Pro as i read it was good, with accurate sound and such.
But i am not satisfied with it, the first is the pressure it gives, itīs like i am on the verge of getting a headache, but still not getting one.
Maybe it will disappear through use, maybe not.
But more importantly, the sound.
even my Cheap AKG something, sound better with the bass.
Now i am not one who wants enormous bass or something, but you know, normal vibrations feeling kind of bass.
That gives you that feeling.
This just, sound like there is bass, but it isnīt there;S
I tried putting on some bass sound through the night, about 10 hours to see if there is any Burn In effect.
It does sound alot better than from when i first listened, cause then it was like a Tin Can or something.
But it still doesnīt give me that Real sound feeling.
sorry for bad explanation, maybe someone knows about these headphones?
I am thinking about sending them back, but i donīt know what to get.
I want something like this, isolation, more comfortable and better sound.
j7n
post May 5 2012, 20:53
Why would you care to equalize YouTube signal? There are soundcards that can do processing anywhere in the signal path. I also happen to own a pair of AKG 141's and don't consider them "cheap". Both his and bass are perfect. Although, true bass can only be experienced with loudspeakers.
zerowalker
post May 5 2012, 20:58
QUOTE (j7n @ May 5 2012, 21:53) *
I never said what AKG i have, but itīs K512.
And well wahty i care about isnīt really youtube, itīs All as all, every sound.
I donīt really like that i will have to make the player change the sound so that it will sound "right".
If you get what i mean;O!
And well i use my onboard, but have tried my realtek pcie one, but well they sound about the same to me, and i have to use the onboard for serveral reasons.
But what should i do, do you have or anyone else have any recommendation on other headphones?
I Really really want closed one that is very comfortable, you know, cover the Entire ear any stuff:)
And i want good sound(no shit sherlock).
The price range is about Max 200 Dollars i guess?
PS: Cause i donīt guess Burn In will make That big difference from now on (not that i really know anything about it).
This post has been edited by zerowalker: May 5 2012, 21:00
C.R.Helmrich
post May 6 2012, 11:24
QUOTE (zerowalker @ May 5 2012, 21:58) *
If you're mainly going to use your phones at home in a relatively quiet environment, then I suggest you go with open circumaural headphones. Note that open doesn't mean they don't cover the entire ear (non-circumaural), it just means the sounds is allowed to travel out of the phones on the sides facing away from your ears. To me this has always had two advantages over closed headphones: 1) less sweaty ears and often less pressure on the head because open headphones don't have to be tightly sealed, 2) more natural sound reproduction because open headphones don't have to be tightly sealed. Don't know for sure, but you might be experiencing the latter now, i.e. a bit of destructive interference in the bass, which other people don't. IIRC the HD280s have very low impedance (64 Ohms) so a dedicated amplifier shouldn't be necessary.
Chris
This post has been edited by C.R.Helmrich: May 6 2012, 11:28
- zerowalker   HD 280 Pro not satisfied   May 5 2012, 18:42
- - saratoga   The HD-280s are well known for their weak bass. I...   May 5 2012, 19:47
- - zerowalker   but that doesnīt work for games youtube etc right;...   May 5 2012, 19:53
- - j7n   Why would you care to equalize YouTube signal? The...   May 5 2012, 20:53
|- - zerowalker   QUOTE (j7n @ May 5 2012, 21:53) Why would...   May 5 2012, 20:58
|- - C.R.Helmrich   QUOTE (zerowalker @ May 5 2012, 21:58) Bu...   May 6 2012, 11:24
|- - moozooh   QUOTE (zerowalker @ May 5 2012, 23:58) An...   May 8 2012, 00:50
- - j7n   Point taken about the AKG model. The ones I have a...   May 6 2012, 05:09
- - tev777   Are you using any kind of amplifier? I have the s...   May 6 2012, 05:12
|- - saratoga   QUOTE (tev777 @ May 6 2012, 00:12) Are yo...   May 6 2012, 19:12
|- - tev777   QUOTE (saratoga @ May 6 2012, 14:12) Turn...   May 8 2012, 05:54
|- - xnor   QUOTE (tev777 @ May 8 2012, 05:54) I disa...   May 8 2012, 12:33
||- - tev777   QUOTE (xnor @ May 8 2012, 07:33) QUOTE (t...   May 8 2012, 16:54
|- - IgorC   QUOTE (tev777 @ May 8 2012, 01:54) Any ti...   May 8 2012, 21:46
- - LithosZA   The HD280 PROs are my favourite pair of headphones...   May 6 2012, 05:36
- - zerowalker   Okay to C.R Helmrich, isnīt it irritating that the...   May 6 2012, 12:06
|- - C.R.Helmrich   QUOTE (zerowalker @ May 6 2012, 13:06) Ok...   May 6 2012, 16:40
- - stephan_g   I think the problem with the 280Pros is that like ...   May 6 2012, 17:35
- - IgorC   Cushions can change their form. And , yes, I have ...   May 6 2012, 17:38
|- - zerowalker   QUOTE (IgorC @ May 6 2012, 18:38) Cushion...   May 7 2012, 16:37
|- - markanini   QUOTE (zerowalker @ May 7 2012, 16:37) It...   May 7 2012, 17:08
|- - zerowalker   QUOTE (markanini @ May 7 2012, 18:08) QUO...   May 7 2012, 17:17
- - DVDdoug   QUOTE Okay so i bought the HD280 Pro as i read it ...   May 7 2012, 19:10
|- - zerowalker   QUOTE (DVDdoug @ May 7 2012, 20:10) QUOTE...   May 7 2012, 19:23
- - IgorC   I'd give a chance to run them during few mont...   May 7 2012, 19:46
|- - zerowalker   QUOTE (IgorC @ May 7 2012, 20:46) I'd...   May 7 2012, 20:39
- - IgorC   You can see if it's full size headphones (thos...   May 7 2012, 22:07
|- - zerowalker   QUOTE (IgorC @ May 7 2012, 23:07) You can...   May 8 2012, 01:09
- - IgorC   EMU 0404 probably won't be suitable to drive p...   May 8 2012, 01:25
|- - zerowalker   QUOTE (IgorC @ May 8 2012, 02:25) EMU 040...   May 8 2012, 01:34
|- - mcdebugger   QUOTE (IgorC @ May 8 2012, 04:25) EMU 040...   May 8 2012, 22:16
|- - IgorC   QUOTE (mcdebugger @ May 8 2012, 18:16) QU...   May 8 2012, 23:39
|- - mcdebugger   QUOTE (IgorC @ May 9 2012, 02:39) http://...   May 8 2012, 23:47
- - markanini   Better add a Fiio E5 to your shopping list, until ...   May 8 2012, 04:57
|- - Arnold B. Krueger   QUOTE (markanini @ May 7 2012, 23:57) Bet...   May 8 2012, 13:24
- - Arnold B. Krueger   QUOTE (zerowalker @ May 5 2012, 13:42) Ok...   May 8 2012, 13:21
- - LithosZA   Do you feel anything if you playback 'tone://3...   May 8 2012, 15:36
- - Ron Jones   The HD380 appear to have moderately better bass re...   May 8 2012, 17:03
- - Thasp   I used to have HD280s. They had AMAZING bass if I ...   May 8 2012, 17:15
- - zerowalker   Do i really need to have an Amplifier when i play ...   May 8 2012, 17:55
|- - Arnold B. Krueger   QUOTE (zerowalker @ May 8 2012, 12:55) Do...   May 9 2012, 14:18
- - Ron Jones   In my opinion, no, it will not make much of a diff...   May 8 2012, 18:00
|- - zerowalker   QUOTE (Ron Jones @ May 8 2012, 19:00) In ...   May 8 2012, 18:03
- - DVDdoug   QUOTE I read about the ATH-M50 and one said he and...   May 8 2012, 19:06
|- - zerowalker   I donīt know, i myself think there is a difference...   May 8 2012, 19:58
||- - Ron Jones   QUOTE (zerowalker @ May 8 2012, 11:58) Bu...   May 8 2012, 20:26
||- - zerowalker   QUOTE (Ron Jones @ May 8 2012, 21:26) QUO...   May 8 2012, 20:34
||- - zerowalker   How are the Sennheiser HD 598? They seem pretty h...   May 8 2012, 21:05
|- - markanini   QUOTE (DVDdoug @ May 8 2012, 19:06) Why d...   May 9 2012, 08:10
- - LithosZA   QUOTE How are the Sennheiser HD 598? They seem pr...   May 8 2012, 21:15
|- - zerowalker   Yeah, but there seems to be many versions with di...   May 8 2012, 21:17
- - LithosZA   Should be able to drive the 32 Ohm version from an...   May 8 2012, 21:25
|- - zerowalker   QUOTE (LithosZA @ May 8 2012, 22:25) Shou...   May 8 2012, 21:29
|- - Ron Jones   QUOTE (zerowalker @ May 8 2012, 13:29) If...   May 8 2012, 22:58
|- - zerowalker   QUOTE (Ron Jones @ May 8 2012, 23:58) QUO...   May 8 2012, 23:20
- - Martel   (I'm responding mostly to the stuff at the beg...   May 10 2012, 11:56
|- - zerowalker   QUOTE (Martel @ May 10 2012, 12:56) (I...   May 12 2012, 06:36
- - Martel   Do you know the brand/type of the integrated sound...   May 12 2012, 09:06
- - zerowalker   Here it is: VIAŪ VT1828S 8-Channel High Definitio...   May 12 2012, 21:00
- - IgorC   VIAŪ VT1828S http://translate.google.es/translate...   May 12 2012, 21:29
- - smok3   another + for DT 770 (comfort + bass), however per...   May 12 2012, 22:59
|- - Gecko   QUOTE (smok3 @ May 12 2012, 22:59) anothe...   May 17 2012, 15:50
- - Martel   Your sound card looks good. If I were you, I would...   May 13 2012, 08:10
|- - zerowalker   QUOTE (Martel @ May 13 2012, 09:10) Your ...   May 17 2012, 14:11
- - LithosZA   QUOTE I tried it on my Mobile Phone (Samsung, Andr...   May 17 2012, 15:52
- - Martel   Well, I meant comparing it to a device which is mo...   May 17 2012, 17:39
RSS Lo-Fi Version Time is now: 25th April 2015 - 13:54
