Should I convert all my audio to 256 AAC?
DaGrandMastah
post May 3 2012, 14:51
Hi all, I'm currently researching what the best route is to go with when converting over my CD library. I realize that everyone loves Lossless (which I'll use for archiving the CD's) but I'm looking for "the best" lossy encoding.
I was originally planning to encode all my CD's into 320 CBR but it seems that almost everything I read states that this is a waste of space as their is nary a difference (except to the most trained ears) between 320 CBR and VBR v-0. Ultiamtely, I don't mind the difference in space when on my computer hard drive but it does become more of an issue when uploading to my iphone for portable listening so then I switched course and started thinking I would go with VBR v-0 (I posted a similar question to this in the mp3 forum) but now I'm reading that I may even be better off going with AAC 256?
This may make the most sense for me being that I'm a Mac user (imac, iphone, ipad) and I'm going to playing all my music out of my itunes library.
Is there any reason I would regret the decision to go AAC over mp3?
Also, for those with experience with this, could you direct me to the best possible setting to use in XLD for encoding CD's/FLAC files to aac?
flapane
post May 11 2012, 11:24
QUOTE (DaGrandMastah @ May 3 2012, 14:51) *
Two years ago I chose Nero AAC -q0.65 (via dbPowerAmp) for portable listening (TMo Vibrant and a pair of Yuin PK2 earphones), after having done some ABXs with similar bitrate VBR Lame encodings.
I'm happy with it, I barely notice any artifacts (mostly blues and jazz) but on some classical music files.
Needless to say, the advantage over my old LAME 128kbps CBR files is obvious.
I guess you could come to different conclusions, so you'd better do some blind tests with different encoders (and music genres) at similar bitrates.
QUOTE (DaGrandMastah @ May 3 2012, 15:08) *
Yeah, the thing is that I have a LOT of music to convert....and it's not just converting but properly tagging with artwork and putting it in the exact format I like within the itunes file/folder structure so I'd like to avoid having to redo anything by researching the topic beforehand.
I know what you mean, that's why I wrote a Bash script that parsed my thousands old 128kbps mp3 files ID3 tags and wrote them into my new aac files. I found a way to copy jpg covers too, but I can't find that version of the script atm.
Hope it helps
#!/bin/bash
#script per copiare le tag da un file mp3 nel file m4a con lo stesso nome
#script for id3 tag cloning from mp3 file into an m4a AAC file with same basename
#flapane.com 24jan10
for file in "$@"
do
title=$(id3v2 -l "$file" | sed -n '/^TIT2[^:]*:[[:space:]]*/s///p')
artist=$(id3v2 -l "$file" | sed -n '/^TPE1[^:]*:[[:space:]]*/s///p')
album=$(id3v2 -l "$file" | sed -n '/^TALB[^:]*:[[:space:]]*/s///p')
year=$(id3v2 -l "$file" | sed -n '/^TYER[^:]*:[[:space:]]*/s///p')
genre=$(id3v2 -l "$file" | sed -n '/^TCON[^:]*:[[:space:]]*/s///p' | awk '{print $1}' )
bandorchestra=$(id3v2 -l "$file" | sed -n '/^TPE2[^:]*:[[:space:]]*/s///p')
composer=$(id3v2 -l "$file" | sed -n '/^TCOM[^:]*:[[:space:]]*/s///p')
#publisher=$(id3v2 -l "$file" | sed -n '/^TPUB[^:]*:[[:space:]]*/s///p')
#track=$(id3v2 -l "$file" | sed -n '/^TRCK[^:]*:[[:space:]]*/s///p')
#echo $title
#echo $artist
#echo $album
#echo $year
#echo "$genre"
#echo $track
#echo $bandorchestra
#echo $composer
#echo $publisher
filemp4=$(basename "$file" .mp3).m4a
mp4tags \
-s "$title" \
-a "$artist" \
-A "$album" \
-y "$year" \
-g "$genre" \
-R "$bandorchestra" \
-w "$composer" \
"$filemp4"
done
This post has been edited by flapane: May 11 2012, 11:35
Flavio's page - www.flapane.com
- DaGrandMastah   Should I convert all my audio to 256 AAC?   May 3 2012, 14:51
- - pdq   As long as you still have the lossless files there...   May 3 2012, 14:57
- - Porcus   QUOTE (DaGrandMastah @ May 3 2012, 15:51)...   May 3 2012, 15:01
- - DaGrandMastah   QUOTE (pdq @ May 3 2012, 15:57) As long a...   May 3 2012, 15:08
|- - pdq   QUOTE (DaGrandMastah @ May 3 2012, 10:08)...   May 3 2012, 17:25
|- - JJZolx   QUOTE (DaGrandMastah @ May 3 2012, 08:08)...   May 3 2012, 21:27
- - DaGrandMastah   Also, what are the best (recommended) settings for...   May 3 2012, 15:52
|- - felix26591   QUOTE (DaGrandMastah @ May 3 2012, 16:52)...   May 3 2012, 19:14
- - DaGrandMastah   QUOTE (felix26591 @ May 3 2012, 20:14) QU...   May 3 2012, 19:45
- - mixminus1   If you're planning on ripping to lossless, pdq...   May 3 2012, 19:55
- - Kohlrabi   QUOTE (DaGrandMastah @ May 3 2012, 16:52)...   May 3 2012, 21:01
- - DaGrandMastah   QUOTE (JJZolx @ May 3 2012, 22:27) QUOTE ...   May 4 2012, 00:18
|- - JJZolx   QUOTE (DaGrandMastah @ May 3 2012, 17:18)...   May 4 2012, 01:38
- - RobertoDomenico   Just listen to your lossless (ALAC) files in iTune...   May 4 2012, 01:09
- - DaGrandMastah   QUOTE (JJZolx @ May 4 2012, 01:38) QUOTE ...   May 4 2012, 02:03
- - RobertoDomenico   If iTunes is your music player of choice just tran...   May 4 2012, 03:33
- - DaGrandMastah   I heard that was only in the older apple models bu...   May 4 2012, 04:15
|- - pdq   QUOTE (DaGrandMastah @ May 3 2012, 23:15)...   May 4 2012, 13:05
- - RobertoDomenico   Using LAme Mp3 they will not playback gapless over...   May 4 2012, 05:24
- - Engelsstaub   Most often I convert my lossless sources with XLD ...   May 4 2012, 06:14
- - DaGrandMastah   QUOTE (Engelsstaub @ May 4 2012, 07:14) M...   May 4 2012, 12:28
|- - Engelsstaub   QUOTE (DaGrandMastah @ May 4 2012, 06:28)...   May 4 2012, 12:43
- - DaGrandMastah   You guys have been a tremendous help. Ok so after...   May 4 2012, 16:07
- - Ouroboros   Constrained VBR is still wasting bits. I'm sur...   May 4 2012, 16:44
- - DaGrandMastah   QUOTE (Ouroboros @ May 4 2012, 16:44) Con...   May 4 2012, 16:56
|- - Kohlrabi   QUOTE (DaGrandMastah @ May 4 2012, 17:56)...   May 4 2012, 18:59
- - Ouroboros   Exactly. If the music's complexity doesn't...   May 4 2012, 17:25
- - polemon   QUOTE (DaGrandMastah @ May 3 2012, 15:51)...   May 4 2012, 18:44
- - flapane   QUOTE (DaGrandMastah @ May 3 2012, 14:51)...   May 11 2012, 11:24
- - DaGrandMastah   Thanks a lot! I'll check this out later ...   May 14 2012, 15:32
|- - yourlord   I rip to FLAC for a couple of reasons. 1st, I can...   Jun 26 2012, 18:02
- - F17   QUOTE (DaGrandMastah @ May 3 2012, 14:51)...   May 14 2012, 21:19
- - greynol   Could be irrelevant to this topic? No, try comple...   May 14 2012, 22:06
|- - F17   QUOTE (greynol @ May 14 2012, 22:06) Coul...   May 15 2012, 16:30
- - FLAC plz   grandmastah, i think you should conduct some ABX t...   Jun 3 2012, 22:11
- - bigshot   I've been building a music server for the past...   Jun 26 2012, 08:07
|- - Porcus   QUOTE (bigshot @ Jun 26 2012, 09:07) well...   Jun 26 2012, 09:18
||- - bigshot   QUOTE (Porcus @ Jun 26 2012, 01:18) That...   Jun 27 2012, 20:41
||- - Ouroboros   QUOTE (bigshot @ Jun 27 2012, 20:41) both...   Jun 27 2012, 21:22
||- - saratoga   QUOTE (Ouroboros @ Jun 27 2012, 16:22) QU...   Jun 27 2012, 23:37
|- - greynol   QUOTE (bigshot @ Jun 26 2012, 00:07) So j...   Jun 27 2012, 21:46
|- - bigshot   QUOTE (greynol @ Jun 27 2012, 13:46) QUOT...   Jul 1 2012, 04:08
- - Steve Forte Rio   Hi. Haven't read the whole thread, but answeri...   Jun 26 2012, 17:31
- - eahm   QUOTE (FLAC plz @ Jun 3 2012, 14:11) gran...   Jun 26 2012, 17:44
- - Ouroboros   You are absolutely right, and I meant to edit my p...   Jun 28 2012, 00:44
RSS Lo-Fi Version Time is now: 29th January 2015 - 12:03
