Moving to Europe, phono preamp
tinpanalley
post May 3 2012, 02:39
I'm moving to France and my Artcessories USB Phono Plus v2 is 110-60 only. Can anyone recommend another Phono pre-amp I can use that is commonly used in Europe?
AndyH-ha
post May 3 2012, 05:46
The thing uses a wall wart. Surely there are 10,000,000 9V output wall warts kicking around France.
mzil
post May 3 2012, 06:23
QUOTE (tinpanalley @ May 2 2012, 21:39) *
From the manual:
"The USB Phono Plus operates from any external power source that provides 150mA or more @ 7 Volts to 12 Volts DC (either polarity at the tip will work with our unit) or 9 Volts to 12 Volts AC.
The USB To Computer connector is USB 2.0 compliant and should be used to connect directly to one of the USB connections on your computer. This connection also powers the USB circuitry inside the USB Phono Plus and will power the whole product if no other power source is available."
Now all you need is to be sure the plug of the new transformer you buy is the right size. You might want to bring the US transformer along (the "wall wart") as a reference. The current output should be a minimum of 150 milliAmps, but it is fine to greatly exceed that if such transformers happen to be easier to find.
I'm not sure if your local Radio Shack would have such a thing but I would think that one of the provided plugs of this universal transformer will most likely work, especially since yours is so flexible it doesn't even care what the polarity of the plug is (meaning whether the outer shield is positive or negative in relation to the center pin):
http://www.amazon.com/Hosa-ACD477-100-240V...M/ref=pd_cp_e_0
This post has been edited by mzil: May 3 2012, 06:27
Frenchy 2
post May 3 2012, 15:06
QUOTE (AndyH-ha @ May 3 2012, 06:46) *
If you're in the Paris region try going to the "Bazar de l'H๔tel de Ville" in the rue de Rivoli (BHV). It's a handyman's paradise.
BTW Welcome to France!
tinpanalley
post May 5 2012, 08:09
Thanks guys. I didn't realise I'd just need a wall wart made in Europe for the right voltage.
And Frenchy, thanks for the BHV suggestion. I will definitely be visiting when we arrive.
I just need to now make completely sure that I know what I'm looking for. huh.gif
j7n
post May 5 2012, 21:03
Is it alright to use a switching power supply, which are becoming ubiquitous, with a phono preamp (in general)?
tinpanalley
post May 15 2012, 20:53
Going along with my issue about the preamp, which I now know only needs a new wall wart, it now occurs to me that I may have an issue with my actual turntable.
I have a Pioneer PL-300. Here's the bizarre thing: it says 50/60 Hz on the back but only 120V. Does that mean, I don't have to worry about frequency as long as I have the step down converter for the 220V power?
pdq
post May 15 2012, 21:05
In the old days when turntables used synchronous motors, the speed was proportional to the line frequency. These days I would be surprised if that was the case.
RSS Lo-Fi Version Time is now: 3rd September 2015 - 06:32
