Best Free-software or no charge proprietary tool to downsample to 44.1
Morality124
post Apr 28 2012, 23:16
I have some audio files I've ripped that I want to down-sample to 44.1khz/16-bit format so they can burned to CDs. The audio files in questions are 24-bit (obv) and range from 96-192 kHz. I don't have any commercial proprietary audio software like Adobe Audition, but I do have the Free software programs Audacity and SoX at the moment, as well as EAC and ImgBurn. Would down-sampling using either of these programs be advisable, and if so, what is best settings and/or method(s) to do so? If not, what would be the recommended program and settings/methods? Thanks!
AndyH-ha
post Apr 29 2012, 09:10
There are some varying opinions on what is the "best" result for both resampling and for bit depth reduction. For bit depth this has mainly to do with the dither used. Unless something really gross is done, however, (and maybe even then) it is rather unlikely you could hear the difference.
For sample rate you can see some visual representations a
http://src.infinitewave.ca/
Look at the sweep tone conversion using Adobe Audition with filters and say Ableton Live 7. The Audition result is more ideal. There are other interesting displays. As with bit depth reduction, being able to hear a difference does not seem to be an established fact.
Arnold B. Kruege...
post Apr 30 2012, 14:40
QUOTE (AndyH-ha @ Apr 29 2012, 04:10) *
It's interesting to see how CEP/Audition which used to get no respect among pros and semi-pros always did a lot of things right, even when more "pro", prestigious, and expensive software like some old releases of Pro Tools didn't even do the basics right.
This post has been edited by Arnold B. Krueger: Apr 30 2012, 14:40
- Morality124   Best Free-software or no charge proprietary tool to downsample to 44.1   Apr 28 2012, 23:16
- - skamp   I use this: CODEsox -G "in.wav" -b 16 ...   Apr 28 2012, 23:47
- - Apesbrain   If you have a number of files to convert you may f...   Apr 29 2012, 01:43
- - m45t3r   The "Secret Rabbit Code" is a very good ...   Apr 29 2012, 04:56
- - Morality124   Hmmm. I actually do have Foobar 2000 also, though ...   Apr 29 2012, 06:09
|- - stephan_g   QUOTE (Morality124 @ Apr 29 2012, 06:09) ...   Apr 29 2012, 22:44
- - Morality124   To clarify, what is the consequence of using a low...   Apr 29 2012, 07:52
- - Juha   If your files are type of WAV already then try Vox...   Apr 29 2012, 09:00
- - AndyH-ha   There are some varying opinions on what is the ...   Apr 29 2012, 09:10
|- - Arnold B. Krueger   QUOTE (AndyH-ha @ Apr 29 2012, 04:10...   Apr 30 2012, 14:40
|- - stephan_g   QUOTE (Arnold B. Krueger @ Apr 30 2012, 14...   May 2 2012, 09:55
|- - phofman   SoX results on http://src.infinitewave.ca are very...   May 2 2012, 10:19
- - rednyrg721   Audacity 2.0 results are much worse than Audacity ...   May 2 2012, 11:30
- - stephan_g   That one puzzled me, too. I think I'll ask the...   May 2 2012, 17:05
|- - lvqcl   QUOTE (stephan_g @ May 2 2012, 20:05) EDI...   May 2 2012, 17:55
- - john33   If you're Windows based and like libsamplerate...   May 2 2012, 17:39
- - stephan_g   QUOTE (john33 @ May 2 2012, 17:39) If you...   May 2 2012, 21:59
|- - Morality124   QUOTE (stephan_g @ May 2 2012, 22:59) QUO...   May 3 2012, 01:28
|- - bandpass   They're essentially the same. Architectural di...   May 3 2012, 05:45
|- - phofman   QUOTE (Morality124 @ May 3 2012, 02:28) I...   May 3 2012, 12:44
|- - ArtistofMind   Hi there, I am keenly interested in using the Res...   Jan 11 2014, 02:26
- - Apesbrain   Converting Hi-res (HR) to 16/44 (CD) These instruc...   Jan 11 2014, 05:01
|- - ArtistofMind   Thanks a million for the thorough walk-thru, Apesb...   Jan 11 2014, 05:22
|- - ArtistofMind   QUOTE (Apesbrain @ Jan 10 2014, 20:01) 1....   Jan 11 2014, 09:10
- - saratoga   If you are just resampling you don't need dith...   Jan 11 2014, 09:14
|- - ArtistofMind   QUOTE (saratoga @ Jan 11 2014, 00:14) If ...   Jan 11 2014, 09:24
- - [JAZ]   @ArtistOfMind: About aliasing: The option in SOX...   Jan 11 2014, 11:37
- - Brand   There's also QSoX, for anyone who wants an eas...   Jan 11 2014, 14:06
RSS Lo-Fi Version Time is now: 25th April 2015 - 20:20
