studio monitors and quality of home speakers
Bartholomew MacG...
post Apr 27 2012, 16:52
Has there ever been a documented case of a recording sounding worse on quality home speakers because the studio monitors used to make the recording where of lower quality?
Bartholomew MacG...
post May 2 2012, 04:52
I don't know if it's ever been done before, but it would be interesting to see if they've ever tried to use perfectly accurate studio monitors and then just have various applications that can mimic the performance of cheaper speakers to try to get the best overall performance as possible on a variety of speakers. I imagine a lot of that could be done with just EQ, I don't know about all the different forms of distortion and other inaccuracies.
They have digital room correction for home systems, so it would be interesting to see if they could create something similar for studios to simulate "bad" rooms and make the recording less vulnerable to sounding bad in certain rooms.
This post has been edited by db1989: May 2 2012, 06:04
Reason for edit: merging double-post
Arnold B. Kruege...
post May 8 2012, 13:32
QUOTE (Bartholomew MacGruber @ May 1 2012, 23:52) *
First problem - finding perfectly accurate studio monitors. Hens teeth!
Second problem - finding reliable eq packages that would make them sound like other real world bad speakers.
ktf
post May 8 2012, 16:03
QUOTE (Arnold B. Krueger @ May 8 2012, 14:32) *
I don't think thats very hard: measure the impulse response of the speakers (probably in a room that fits the kind of equipment) and use convolution to emulate the speaker. You could try to counter your non-perfect monitor problem by deconvolution as well. Probably the result won't be perfect (as deconvolution certainly wont give perfect results), but thats not the objective. If it emulates well, which of course has to be tested, the problem is solved. In the mastering stage, the time delay of convolution/deconvoltion won't be a problem too.
This post has been edited by ktf: May 8 2012, 16:05
- Bartholomew MacGruber   studio monitors and quality of home speakers   Apr 27 2012, 16:52
- - mixminus1   Define "worse". For years, one of the s...   Apr 27 2012, 17:49
|- - Bartholomew MacGruber   QUOTE (mixminus1 @ Apr 27 2012, 17:49) De...   Apr 30 2012, 06:18
|- - DVDdoug   QUOTE (Bartholomew MacGruber @ Apr 29 2012, 2...   Apr 30 2012, 18:52
- - Ethan Winer   QUOTE (Bartholomew MacGruber @ Apr 27 2012, 1...   Apr 27 2012, 18:23
|- - Bartholomew MacGruber   QUOTE (Ethan Winer @ Apr 27 2012, 18:23) ...   Apr 30 2012, 06:22
|- - tnargs   QUOTE (Ethan Winer @ Apr 28 2012, 02:53) ...   Oct 23 2012, 02:10
|- - Arnold B. Krueger   QUOTE (tnargs @ Oct 22 2012, 21:10) QUOTE...   Oct 23 2012, 20:28
- - RonaldDumsfeld   QUOTE the trend to market "pleasing sounding...   Apr 27 2012, 21:16
|- - Ethan Winer   Yes, plenty of examples. Some years back, a fellow...   Apr 28 2012, 17:02
|- - honestguv   QUOTE (Ethan Winer @ Apr 28 2012, 18:02) ...   Apr 28 2012, 20:15
||- - Arnold B. Krueger   QUOTE (honestguv @ Apr 28 2012, 15:15) QU...   Apr 29 2012, 17:51
|- - markanini   QUOTE (Ethan Winer @ Apr 28 2012, 17:02) ...   Apr 30 2012, 15:01
|- - tnargs   QUOTE (Ethan Winer @ Apr 29 2012, 01:32) ...   Oct 23 2012, 01:56
- - tomtomthomson   QUOTE (Bartholomew MacGruber @ Apr 27 2012, 1...   Apr 30 2012, 03:22
- - Typhoon859   QUOTE (Bartholomew MacGruber @ Apr 30 2012, 0...   Apr 30 2012, 08:18
|- - Bartholomew MacGruber   OK, I can't remember all the places that I rea...   Apr 30 2012, 08:44
||- - Arnold B. Krueger   QUOTE (Bartholomew MacGruber @ Apr 30 2012, 0...   Apr 30 2012, 14:29
||- - seditious3   QUOTE I also seem to remember stuff about recordin...   Oct 22 2012, 17:53
|- - Arnold B. Krueger   QUOTE (Typhoon859 @ Apr 30 2012, 03:18) Q...   Apr 30 2012, 14:25
- - AudioKitten   Maybe this is mostly a problem with amateur master...   May 1 2012, 16:25
- - Bartholomew MacGruber   I don't know if it's ever been done before...   May 2 2012, 04:52
|- - Arnold B. Krueger   QUOTE (Bartholomew MacGruber @ May 1 2012, 23...   May 8 2012, 13:32
|- - ktf   QUOTE (Arnold B. Krueger @ May 8 2012, 14...   May 8 2012, 16:03
|- - Arnold B. Krueger   QUOTE (ktf @ May 8 2012, 11:03) QUOTE (Ar...   May 9 2012, 14:24
|- - ktf   QUOTE (Arnold B. Krueger @ May 9 2012, 15...   May 9 2012, 14:38
- - _if   If you took a set of any of the good monitors (rea...   May 2 2012, 07:12
|- - stephan_g   QUOTE (_if @ May 2 2012, 07:12) If you to...   May 2 2012, 09:36
|- - Bartholomew MacGruber   QUOTE (_if @ May 2 2012, 07:12) If you to...   May 2 2012, 09:37
- - icstm   is that type of EQ adjustment was audacity type sy...   May 2 2012, 13:19
- - RonaldDumsfeld   Thanks to Ethan for going to the trouble to post t...   May 2 2012, 15:24
|- - honestguv   QUOTE (RonaldDumsfeld @ May 2 2012, 15:24...   May 2 2012, 16:33
|- - Kees de Visser   QUOTE (honestguv @ May 2 2012, 17:33) I w...   May 2 2012, 22:38
|- - Thasp   QUOTE (honestguv @ May 2 2012, 08:33) QUO...   May 12 2012, 05:51
- - RonaldDumsfeld   To be fair Ethan did quote the test methodology. S...   May 2 2012, 18:16
- - RobWansbeck   The dips could be the result of phase cancellation...   May 5 2012, 22:45
- - krabapple   Isn't most studio monitoring on these speakers...   May 9 2012, 16:38
- - markanini   Yeah, the equilateral triangle, each side 3-6 feet...   May 10 2012, 15:18
- - lanayapiper   QUOTE (Bartholomew MacGruber @ Apr 27 2012, 1...   Oct 12 2012, 13:13
|- - Arnold B. Krueger   QUOTE (lanayapiper @ Oct 12 2012, 08:13) ...   Oct 15 2012, 14:50
- - tnargs   QUOTE (Ethan Winer @ Apr 29 2012, 01:32) ...   Oct 23 2012, 01:36
- - markanini   What are Doug Sax and Rob Ludwig using?   Oct 23 2012, 20:45
RSS Lo-Fi Version Time is now: 28th January 2015 - 17:10
