iPod Classic vs. FiiO E7, Cirrus Logic vs. Wolfson
You cannot see the results of the poll until you have voted. Please login and cast your vote to see the results of this poll.
Total Votes: 13
Guests cannot vote
skamp
post Apr 26 2012, 14:26
There's a lot of hype in audiophile forums about how the new iPod Classic (with a Cirrus Logic CS42L55 DAC) sounds noticeably worse than older iPods (with a Wolfson WM8758 DAC). So I decided to compare my iPod Classic (with the Cirrus Logic DAC) to my FiiO E7, which has a Wolfson WM8740 DAC (with better specs than the WM8758).
I don't currently have a good soundcard with line inputs, so I had to use an old laptop to make the recordings, pending something better. I used Audacity (16 bit / 44.1 kHz) and recorded the iPod via its Line Out Dock and the E7 via its headphone out, both with the same 16/44.1 WAV file as a source. The song is Revenge! by Spoon, from The WIRED CD: Rip. Sample. Mash. Share., a compilation of songs licensed under Creative Commons "Sampling Plus", that can be legally shared.
I aligned the recordings and volume-matched them by running wavegain on them. Download from DropBox: A.flac, B.flac, C.flac.
C.flac is the reference file that was played back on both the iPod and the E7 when recording. I'm reluctant to say which is which regarding A.flac and B.flac, because aside from ABX logs, I'd like to know which file people prefer, if any.
This is the first time I do something like this, so let me know if my methodology is valid or if it needs an adjustment. The big question I have, is whether my recordings are good enough for the purpose of comparing the two devices, or if I need a better sound card.
saratoga
post Apr 26 2012, 17:41
QUOTE (skamp @ Apr 26 2012, 09:26) *
I've never heard that, and frankly its kind of a dumb thing to believe given that the WM8758 wasn't very good due to rolled off bass in the older iPods. I've actually got some old test results here from mine:
That is not very good by modern standards.
Listening tests can be difficult under these conditions. Have you considered just using a tool like RMAA to measure distortion and frequency response while driving a load? Generally speaking, I think most people will accept that a device with moderately rolled off bass (the ipod 5G) is not doing as good as one with correct bass (the 6/7G).
skamp
post Apr 26 2012, 17:58
QUOTE (saratoga @ Apr 26 2012, 18:41) *
Note that audiophiles usually plug their headphones into an external amp, connected to the iPod via its line out, thus bypassing its internal amp. I don't know how much of a difference it makes regarding that issue.
Unfortunately I can't install Windows on my old laptop (it doesn't have a CD-ROM drive, and I don't have a license). I do have Windows 7 on my new laptop, so it's something I could do if I decided to invest in a good USB device with a line in.
saratoga
post Apr 26 2012, 18:09
QUOTE (skamp @ Apr 26 2012, 12:58) *
Line out doesn't really bypass anything on modern players. Its still the same output, except now into high impedance. So you get the white line instead of the blue or green. It will certainly help, but you're really just polishing a turd. Why bother with a DAC that struggles with included Apple earbuds when you could have one thats a lot better. Thats how I look at it anyway.
You don't have to install Windows or RMAA on the device doing the recording. Anything that can generate WAV files will work. Use linux, or even a good digital hardware recorder if you like.
skamp
post Apr 26 2012, 18:27
QUOTE (saratoga @ Apr 26 2012, 19:09) *
Well for one thing, the line out is a hell of a lot louder (deafening) than the headphone out (which I max out with my headphones and mp3gain'ed MP3s), and volume control is disabled.
Right, IIRC I have to generate a test file with RMAA, play it back on the device and record it. I assume I can feed RMAA the recorded file directly? I'll check it out, thanks.
RSS Lo-Fi Version Time is now: 2nd March 2015 - 02:06
