XLD: 1 track of new CD not found by AccurateRip, “may not be accurate”
tomten_alle
post Apr 17 2012, 20:22
I have just bought Symphony X - The Odyssey (Limited Edition). When I rip it using XLD 20120407 all tracks except one rip perfectly. I have verified with many other disc that all settings are correct.
Log
X Lossless Decoder version 20120407 (140.0)
XLD extraction logfile from 2012-04-17 20:58:21 +0200
Symphony X / The Odyssey
Used drive : MATSHITA DVD-R UJ-898 (revision HC10)
Ripper mode : XLD Secure Ripper
Disable audio cache : OK for the drive with a cache less than 1375KiB
Make use of C2 pointers : NO
Read offset correction : 102
Max retry count : 20
Gap status : Analyzed, Appended
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 00:00:00 | 05:32:53 | 0 | 24952
2 | 05:32:53 | 05:32:50 | 24953 | 49902
3 | 11:05:28 | 04:22:14 | 49903 | 69566
4 | 15:27:42 | 07:53:40 | 69567 | 105081
5 | 23:21:07 | 06:19:72 | 105082 | 133578
6 | 29:41:04 | 04:44:51 | 133579 | 154929
7 | 34:25:55 | 08:21:55 | 154930 | 192559
8 | 42:47:35 | 24:13:73 | 192560 | 301607
9 | 67:01:33 | 05:59:69 | 301608 | 328601
List of alternate offset correction values
# | Absolute | Relative | Confidence
1 | 84 | -18 | 105
2 | 9 | -93 | 8
AccurateRip Summary
Track 01 : OK (AR2, confidence 11, with different offset)
Track 02 : OK (AR2, confidence 11, with different offset)
Track 03 : OK (AR2, confidence 11, with different offset)
Track 04 : OK (AR2, confidence 11, with different offset)
Track 05 : OK (AR2, confidence 11, with different offset)
Track 06 : OK (AR2, confidence 11, with different offset)
Track 07 : OK (AR2, confidence 11, with different offset)
Track 08 : NG
Track 09 : OK (AR2, confidence 11, with different offset)
->8 track(s) accurately ripped, 1 track(s) not, 0 track(s) not found
All Tracks
Filename : /Users/tomten_alle/Documents/MusikFlac/Original/Symphony X/The Odyssey/Symphony X - The Odyssey.flac
Album gain : -7.83 dB
Peak : 0.952576
CRC32 hash : 567CC956
CRC32 hash (skip zero) : 70613786
Statistics
Read error : 0
Jitter error (maybe fixed) : 0
Retry sector count : 0
Damaged sector count : 0
Track 01
Pre-gap length : 00:02:00
Track gain : -7.59 dB
Peak : 0.889496
CRC32 hash : 8D2CBE33
CRC32 hash (skip zero) : 667AEC5E
AccurateRip signature : 2CA94A8B
->Accurately ripped! (AR2, confidence 11)
(matched with the different offset correction value;
calculated using an additional offset of -18;
the signature after correction is: 70E15955)
Statistics
Read error : 0
Track 02
Pre-gap length : 00:01:00
Track gain : -6.99 dB
Peak : 0.889496
CRC32 hash : 0875E0F8
CRC32 hash (skip zero) : 9825DBC0
AccurateRip signature : 23732D47
the signature after correction is: 3BA10DB8)
Statistics
Read error : 0
Track 03
Track gain : -8.33 dB
Peak : 0.889496
CRC32 hash : 3DCC2EEF
CRC32 hash (skip zero) : E31C1AB2
AccurateRip signature : B2F9CE93
the signature after correction is: C7C421C3)
Statistics
Read error : 0
Track 04
Pre-gap length : 00:03:00
Track gain : -7.92 dB
Peak : 0.839752
CRC32 hash : 7A894994
CRC32 hash (skip zero) : 250F5EDF
AccurateRip signature : BAA1D767
the signature after correction is: 7B706844)
Statistics
Read error : 0
Track 05
Track gain : -7.93 dB
Peak : 0.889496
CRC32 hash : C6B555B0
CRC32 hash (skip zero) : 855956C7
AccurateRip signature : CD0FBDED
the signature after correction is: 499369BD)
Statistics
Read error : 0
Track 06
Track gain : -8.21 dB
Peak : 0.889496
CRC32 hash : 50240667
CRC32 hash (skip zero) : A142F143
AccurateRip signature : 83751680
the signature after correction is: 5171B6F6)
Statistics
Read error : 0
Track 07
Track gain : -8.25 dB
Peak : 0.942200
CRC32 hash : 01FFC47C
CRC32 hash (skip zero) : 8B9A6E76
AccurateRip signature : EC675883
the signature after correction is: 869E4A22)
Statistics
Read error : 0
Track 08
Pre-gap length : 00:04:00
Track gain : -7.53 dB
Peak : 0.943207
CRC32 hash : 7338D5AE
CRC32 hash (skip zero) : E3A5BCA3
AccurateRip signature : 30FB5342
->Rip may not be accurate.
Statistics
Read error : 0
Track 09
Track gain : -6.86 dB
Peak : 0.952576
CRC32 hash : 0448CFCC
CRC32 hash (skip zero) : 4CD6418E
AccurateRip signature : 0670F43B
the signature after correction is: EF858017)
Statistics
Read error : 0
Some inconsistencies found
End of status report
How can this be? I doubt the accurip DB is wrong. Am I wrong or is the DB wrong?
This post has been edited by db1989: Apr 17 2012, 20:49
Reason for edit: improving title / changing enclosure of huge log from [code] to [codebox]
spoon
post Apr 17 2012, 20:48
dBpowerAMP developer
Group: Developer (Donating)
With a Confidence of 11 it is likely your rip has the issues, perhaps a manufacturing defect on the disc. Try re-ripping the same track over and over, if the CRC changes then it is your disc with the error.
Spoon http://www.dbpoweramp.com
tomten_alle
post Apr 21 2012, 16:26
QUOTE (spoon @ Apr 17 2012, 21:48) *
I have tried ripping it several times, the CRC remained the same. It might just be a matter of time before it changes. How common are manufacturing defects? I bought the CD still sealed, though it has been in storage a very long time.
Engelsstaub
post Apr 21 2012, 23:42
There seem to exist multiple pressings of this CD and more than one "Limited Edition" to include a Japanese version with exclusive tracks.
I can't be certain which one yours is, but track 8 is "The Odyssey" which is over 24 minutes long. It's quite possible that it couldn't be ripped to match the 11 others (defective) or that you have a pressing that is unique to the 11 submitted to AR (wherein the track is not exactly the same.)
(I don't actually own the CD though I have a two others and a record by this band.)
The Loudness War is over. Now it's a hopeless occupation.
Chinch
post Apr 22 2012, 10:50
Personally, I don't know what XLD is (other than obviously it's a ripper) but... and I'm using EAC, which I'm very familiar with as my reference, so I'm not sure what features you do or don't have... have you:
Attempted to rip in file-per-track mode (each track is ripped to its own file)
vs.
Attempted to rip in disc-at-once or "image" mode where the entire disc is ripped to a single output file?
That would be my first thing to try, do the opposite of what you're doing (so it looks like you should try ripping to a single file) and see if the result changes.
Other things to check would be:
1- If you rip the same track multiple times, are you consistently getting the same CRC for YOUR file (not considering AR at all)?
2- Can you do a test+rip to see if you get a consistent CRC in a single ripping session?
I know that I rip in to single file/image, then encode to FLAC, then embed the CUESHEET and ART; that last part was immaterial, but I notice you will get different match results when using file-per-track vs. image ripping. Almost always the image rip AR+ count is much lower... but it's not an incorrect rip, because I may have tons of AR matches either way that I rip the disc... but the counts differ. I am pretty positive about this, I never leave out the possibility that I'm completely making things up, but this seems fairly certain. Let me test something really quick.
Maybe I'm full of it. My image rip matched 31/31 on the CTDB, 6/9 perfect match on AR and 3/9 matched with +6 offset (I know my offset is good). So disregarding offset mine's fully perfect... though I agree that 9 matches seems very low for such a popular CD I'm testing. The reference rip that is file-per-track actually matched 31/31 also, but it matched 0/9 for the offsets (matches were in other offsets, no "0" offset matches) -- so turns out mine was actually "better" than that one if you want to consider offset matching to bring it to the detail level. Nevermind. Forget what the previous paragraph said, but do try what I said above that if you would and report back with your results. What OS and version are you using?
tomten_alle
post Apr 22 2012, 15:32
QUOTE (Chinch @ Apr 22 2012, 11:50) *
vs.
XLD is a ripper for Mac. I run it on my MacBook Pro with Mac OS X 10.6.8.
File-per-track mode log:
XLD extraction logfile from 2012-04-22 16:06:09 +0200
1 | 84 | -18 | 105
2 | 9 | -93 | 8
AccurateRip Summary
Track 08 : NG
All Tracks
Peak : 0.952576
Statistics
Read error : 0
Track 01
Filename : /Users/tomten_alle/Documents/MusikFlac/Original/01 Symphony X - Inferno (Unleash the Fire).wav
Peak : 0.889496
Statistics
Read error : 0
Track 02
Filename : /Users/tomten_alle/Documents/MusikFlac/Original/02 Symphony X - Wicked.wav
Peak : 0.889496
Statistics
Read error : 0
Track 03
Filename : /Users/tomten_alle/Documents/MusikFlac/Original/03 Symphony X - Incantations of the Apprentice.wav
Peak : 0.889496
Statistics
Read error : 0
Track 04
Filename : /Users/tomten_alle/Documents/MusikFlac/Original/04 Symphony X - Accolade II.wav
Peak : 0.839752
Statistics
Read error : 0
Track 05
Filename : /Users/tomten_alle/Documents/MusikFlac/Original/05 Symphony X - King of Terrors.wav
Peak : 0.889496
Statistics
Read error : 0
Track 06
Filename : /Users/tomten_alle/Documents/MusikFlac/Original/06 Symphony X - The Turning.wav
Peak : 0.889496
Statistics
Read error : 0
Track 07
Filename : /Users/tomten_alle/Documents/MusikFlac/Original/07 Symphony X - Awakenings.wav
Peak : 0.942200
Statistics
Read error : 0
Track 08
Filename : /Users/tomten_alle/Documents/MusikFlac/Original/08 Symphony X - The Odyssey.wav
Peak : 0.943207
Statistics
Read error : 0
Track 09
Filename : /Users/tomten_alle/Documents/MusikFlac/Original/09 Symphony X - Masquerade '98.wav
Peak : 0.952576
Statistics
Read error : 0
Image-mode 1:
XLD extraction logfile from 2012-04-16 20:25:10 +0200
Symphony X / THE ODYSSEY (LIMITED EDITION)
1 | 84 | -18 | 104
2 | 9 | -93 | 8
AccurateRip Summary
Track 01 : OK (AR2, confidence 10, with different offset)
Track 02 : OK (AR2, confidence 10, with different offset)
Track 03 : OK (AR2, confidence 10, with different offset)
Track 04 : OK (AR2, confidence 10, with different offset)
Track 05 : OK (AR2, confidence 10, with different offset)
Track 06 : OK (AR2, confidence 10, with different offset)
Track 07 : OK (AR2, confidence 10, with different offset)
Track 08 : NG
Track 09 : OK (AR2, confidence 10, with different offset)
All Tracks
Filename : /Users/tomten_alle/Documents/MusikFlac/Original/Symphony X/THE ODYSSEY (LIMITED EDITION)/Symphony X - THE ODYSSEY (LIMITED EDITION).flac
Peak : 0.952576
Statistics
Read error : 0
Track 01
Peak : 0.889496
->Accurately ripped! (AR2, confidence 10)
Statistics
Read error : 0
Track 02
Peak : 0.889496
Statistics
Read error : 0
Track 03
Peak : 0.889496
Statistics
Read error : 0
Track 04
Peak : 0.839752
Statistics
Read error : 0
Track 05
Peak : 0.889496
Statistics
Read error : 0
Track 06
Peak : 0.889496
Statistics
Read error : 0
Track 07
Peak : 0.942200
Statistics
Read error : 0
Track 08
Peak : 0.943207
Statistics
Read error : 0
Track 09
Peak : 0.952576
Statistics
Read error : 0
Image-mode 2:
1 | 84 | -18 | 105
2 | 9 | -93 | 8
AccurateRip Summary
Track 08 : NG
All Tracks
Peak : 0.952576
Statistics
Read error : 0
Track 01
Peak : 0.889496
Statistics
Read error : 0
Track 02
Peak : 0.889496
Statistics
Read error : 0
Track 03
Peak : 0.889496
Statistics
Read error : 0
Track 04
Peak : 0.839752
Statistics
Read error : 0
Track 05
Peak : 0.889496
Statistics
Read error : 0
Track 06
Peak : 0.889496
Statistics
Read error : 0
Track 07
Peak : 0.942200
Statistics
Read error : 0
Track 08
Peak : 0.943207
Statistics
Read error : 0
Track 09
Peak : 0.952576
Statistics
Read error : 0
Image-mode 3:
XLD extraction logfile from 2012-04-22 16:17:42 +0200
1 | 84 | -18 | 105
2 | 9 | -93 | 8
AccurateRip Summary
Track 08 : NG
All Tracks
Filename : /Users/tomten_alle/Documents/MusikFlac/Original/Symphony X/The Odyssey/Symphony X - The Odyssey.wav
Peak : 0.952576
Statistics
Read error : 0
Track 01
Peak : 0.889496
Statistics
Read error : 0
Track 02
Peak : 0.889496
Statistics
Read error : 0
Track 03
Peak : 0.889496
Statistics
Read error : 0
Track 04
Peak : 0.839752
Statistics
Read error : 0
Track 05
Peak : 0.889496
Statistics
Read error : 0
Track 06
Peak : 0.889496
Statistics
Read error : 0
Track 07
Peak : 0.942200
Statistics
Read error : 0
Track 08
Peak : 0.943207
Statistics
Read error : 0
Track 09
Peak : 0.952576
Statistics
Read error : 0
They all share the same checksum:
7338D5AE
7338D5AE
7338D5AE
7338D5AE
This post has been edited by db1989: Apr 22 2012, 22:28
Reason for edit: What the… Please use[codebox] rather than [code] for huge items.
Pepzhez
post Apr 22 2012, 22:19
I have experienced this (very infrequent) problem before with XLD.
Try ripping the disc again, or even just track 8, in single pass burst mode and see what the results are. Every time I have encountered this problem of one particular track producing mismatched CRCs, a burst mode rip produces a perfect, AR-confirmed rip.
tomten_alle
post Apr 23 2012, 17:55
QUOTE (Pepzhez @ Apr 22 2012, 23:19) *
This did not work either. Perhaps the CD is "broken" after all?
XLD extraction logfile from 2012-04-23 16:16:24 +0200
Ripper mode : Burst
Disable audio cache : NO
1 | 84 | -18 | 105
2 | 9 | -93 | 8
AccurateRip Summary
Track 08 : NG
All Tracks
Peak : 0.952576
Track 01
Peak : 0.889496
Track 02
Peak : 0.889496
Track 03
Peak : 0.889496
Track 04
Peak : 0.839752
Track 05
Peak : 0.889496
Track 06
Peak : 0.889496
Track 07
Peak : 0.942200
Track 08
Peak : 0.943207
Track 09
Peak : 0.952576
This post has been edited by db1989: Apr 23 2012, 19:52
Reason for edit: See post #6.
Pepzhez
post Apr 24 2012, 07:00
I would say that there is definitely a problem with the disc, then.
gib
post Apr 24 2012, 07:15
Since the CRC was the same every time you ripped it, including in different modes, the likelihood is that your rip is good and, as Englesstaub mentioned, your disc is just a different pressing. It's possible that the disc is defective in a consistent way, but that's the less common way for a disc to be defective. Plus, ripping in different modes, as you did, reduces the chance we're seeing that. If you were using EAC, I'd tell you to enable C2 pointers and try another rip. I know very little about XLD, but maybe that'd be worthwhile here as well.
If you really want to investigate further, the thing to do would be to rip track 8 with a totally different optical drive (one with a different chipset). If a completely different drive returns the same CRC, the overwhelming likelihood is that your rip is correct.
You could also run your current rip through CueTools (if you have access to a Windows environment) just for kicks. I don't know if anyone else has ripped that disc and submitted it to the CueTools database, though.
This post has been edited by gib: Apr 24 2012, 07:31
Pepzhez
post Apr 25 2012, 04:57
I'd second ripping again with a different drive.
My guess is that this is a gap detection issue.
tomten_alle
post Apr 26 2012, 15:05
QUOTE (gib @ Apr 24 2012, 08:15) *
QUOTE (Pepzhez @ Apr 25 2012, 05:57) *
I am getting a new computer soon. I will follow up this thread. Stay tuned!
psycho
post Apr 26 2012, 17:52
Hey!
I have this CD... I've tried to rip track 8 and it works fine...
Exact Audio Copy V1.0 beta 3 from 29. August 2011
EAC extraction logfile from 26. April 2012, 17:47
Used drive : HL-DT-STDVDRRW GSA-H30L Adapter: 3 ID: 0
Read mode : Burst
Overread into Lead-In and Lead-Out : Yes
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks : No
Null samples used in CRC calculations : Yes
Used interface : Native Win32 interface for Win NT & 2000
Gap handling : Not detected, thus appended to previous track
Used output format : Internal WAV Routines
Sample format : 44.100 Hz; 16 Bit; Stereo
1 | 0:00.00 | 5:32.53 | 0 | 24952
2 | 5:32.53 | 5:32.50 | 24953 | 49902
3 | 11:05.28 | 4:22.14 | 49903 | 69566
4 | 15:27.42 | 7:53.40 | 69567 | 105081
5 | 23:21.07 | 6:19.72 | 105082 | 133578
6 | 29:41.04 | 4:44.51 | 133579 | 154929
7 | 34:25.55 | 8:21.55 | 154930 | 192559
8 | 42:47.35 | 24:13.73 | 192560 | 301607
9 | 67:01.33 | 5:59.69 | 301608 | 328601
Track 8
Filename C:\mp3\!uredi\08 The Odyssey.wav
Timing problem 0:00:16
Peak level 94.3 %
Extraction speed 25.9 X
Copy CRC A6688106
Accurately ripped (confidence 11) [FF275452] (AR v2)
Copy finished
All tracks accurately ripped
No errors occurred
And here's my log from whole rip:
EAC extraction logfile from 26. April 2012, 18:48
Read mode : Burst
Track 1
Filename C:\mp3\!uredi\01 Inferno (Unleash the Fire).wav
Peak level 88.9 %
Extraction speed 12.5 X
Copy CRC B826151A
Accurately ripped (confidence 11) [70E15955] (AR v2)
Copy OK
Track 2
Filename C:\mp3\!uredi\02 Wicked.wav
Peak level 88.9 %
Extraction speed 16.6 X
Copy CRC F8A68F60
Accurately ripped (confidence 11) [3BA10DB8] (AR v2)
Copy OK
Track 3
Filename C:\mp3\!uredi\03 Incantations of the Apprentice.wav
Peak level 88.9 %
Extraction speed 18.1 X
Copy CRC 3112F592
Accurately ripped (confidence 11) [C7C421C3] (AR v2)
Copy OK
Track 4
Filename C:\mp3\!uredi\04 Accolade II.wav
Peak level 83.9 %
Extraction speed 19.9 X
Copy CRC C454DCA8
Accurately ripped (confidence 11) [7B706844] (AR v2)
Copy OK
Track 5
Filename C:\mp3\!uredi\05 King of Terrors.wav
Peak level 88.9 %
Extraction speed 21.7 X
Copy CRC 1D23062F
Accurately ripped (confidence 11) [499369BD] (AR v2)
Copy OK
Track 6
Filename C:\mp3\!uredi\06 The Turning.wav
Peak level 88.9 %
Extraction speed 22.9 X
Copy CRC 1B8491C0
Accurately ripped (confidence 11) [5171B6F6] (AR v2)
Copy OK
Track 7
Filename C:\mp3\!uredi\07 Awakenings.wav
Peak level 94.2 %
Extraction speed 24.5 X
Copy CRC 6AB0E588
Accurately ripped (confidence 11) [869E4A22] (AR v2)
Copy OK
Track 8
Peak level 94.3 %
Extraction speed 27.7 X
Copy CRC A6688106
Copy OK
Track 9
Filename C:\mp3\!uredi\09 Masquerade '98.wav
Peak level 95.2 %
Extraction speed 30.5 X
Copy CRC A62EC8A7
Accurately ripped (confidence 11) [EF858017] (AR v2)
Copy OK
No errors occurred
Judging by our accuraterip confidence level (11), we probably have the same release of the album. I have found that there are at least 3 different releases, though. Look:
I'm afraid you might really have a deffective CD... Maybe try ripping it with another PC, like you suggested.
This post has been edited by db1989: Apr 26 2012, 19:00
Reason for edit: See posts #1, #6, and #8. This is getting ridiculous.
lame -V 0
gib
post Apr 27 2012, 03:55
QUOTE (psycho @ Apr 26 2012, 06:52) *
Actually, the AR CRCs for your tracks are different than his. His only match AR and yours (with the exception of track 8) after a -18 offset. So it would appear you have different releases/pressings.
psycho
post Apr 27 2012, 13:26
Post #15
@gib, either that, or he uses wrong offset for his drive.
He's got it set to +102, which has a confidence of 104 on this page, however, his log says:
        1  |     84   |    -18   |     105
        2  |      9   |    -93   |      8
Now, if I interpret this correctly (I could be wrong), he ought to try with -18 offset that has confidence of 105. Seems like not all DVD-R UJ-898 drives have the same offset, some have +102, some -18 and some -93. Or am I getting it wrong? smile.gif
lame -V 0
Pepzhez
post Apr 27 2012, 16:36
Post #16
That's a good observation. I didn't catch that.
Yes, he should try setting the offset to 84 (102 + -18).
gib
post Apr 28 2012, 09:45
Post #17
QUOTE (psycho @ Apr 27 2012, 02:26) *
Now, if I interpret this correctly (I could be wrong), he ought to try with -18 offset that has confidence of 105. Seems like not all DVD-R UJ-898 drives have the same offset, some have +102, some -18 and some -93. Or am I getting it wrong? :)
Yeah, that's not right. You seem to be mixing up a drive's read offset (and offset correction) with different disc pressings being offset from one another. Also, and please correct me if I'm wrong, it seems like you're trying to draw a relationship between the number of people that have submitted offset data for the UJ-898 (104) and the number of people that have submitted results for a pressing of the CD in question (105). Those values are unrelated. That they are only one apart is just coincidence.
In this particular case, the "list of alternate offset correction values" is telling us that the two pressings in the database are -18 and -93 samples offset relative to the disc the original poster has. Again, this has nothing to do with the drive; the UJ-898 definitely has a -102 read offset (and therefore needs a +102 offset correction).
As for changing the offset correction value in the ripping program, there's no point since it wouldn't change the results. AR2 (and CueTools as well) can crosscheck against different pressings, so manually trying to make a disc line up with a different pressing isn't useful anymore. Indeed, we can see in the log that, except for track 8, the rip was already verified against the pressing with a -18 relative offset. Also, for whatever it's worth, I'm not sure changing the offset correction is easily doable, anyway. I know with EAC that if you have AccurateRip enabled, you can't tinker with the offset correction value. Maybe XLD is the same?
This post has been edited by gib: Apr 28 2012, 09:57
Kees de Visser
post Apr 28 2012, 10:19
Post #18
QUOTE (gib @ Apr 28 2012, 10:45) *
Recent versions of XLD (at least since 2012) have 3 adjustable offsets:
1) read offset for cd-rip (AFAIK independent of AccurateRip setting)
2) write offset (for cd-burn)
3) read offset (for verify after cd-burn), with a check-box to use the setting of 1)
psycho
post Apr 28 2012, 12:47
Post #19
I was mixing apples and oranges.
lame -V 0
gib
post Apr 28 2012, 22:36
Post #20
QUOTE (Kees de Visser @ Apr 27 2012, 23:19) *
Thanks, good to know.
QUOTE (psycho @ Apr 28 2012, 01:47) *
@gib, thanks for clarifying. :)
No problem. I know we're all pretty interested in what's going on here.
tomten_alle
post Jul 26 2012, 15:30
Post #21
Hi again! Sorry for the delay!
Here is a log from my new computer, I have used CUERipper this time.
Log:
CUERipper v2.1.4 Copyright © 2008-12 Grigory Chudov
EAC extraction logfile from 26. July 2012, 16:24
Used drive : Optiarc DVD RW AD-7280S Adapter: 1 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 48
Overread into Lead-In and Lead-Out : No
Range status and errors
Selected range
Filename C:\Users\Alexander\Documents\MusikFlac\Original\Symphony X\The Odyssey\Symphony X - The Odyssey.wav
Peak level 95.2 %
Range quality 100.0 %
Copy CRC 567CC956
Copy OK
No errors occurred
AccurateRip summary
Track 1 cannot be verified as accurate (confidence 113) [BA48734D], AccurateRip returned [F6B44413]
Track 2 cannot be verified as accurate (confidence 113) [752AD446], AccurateRip returned [858A27CA]
Track 3 cannot be verified as accurate (confidence 113) [34840DDE], AccurateRip returned [433C39C4]
Track 4 cannot be verified as accurate (confidence 113) [FB261033], AccurateRip returned [B0E291ED]
Track 5 cannot be verified as accurate (confidence 113) [7DA8DCF8], AccurateRip returned [F151189C]
Track 6 cannot be verified as accurate (confidence 113) [F75233AF], AccurateRip returned [BEB2A651]
Track 7 cannot be verified as accurate (confidence 112) [69AFE879], AccurateRip returned [F82EE85F]
Track 8 cannot be verified as accurate (confidence 111) [30FB5342], AccurateRip returned [718437CB]
Track 9 cannot be verified as accurate (confidence 109) [9E5976D0], AccurateRip returned [8FDF69F2]
No tracks could be verified as accurate
You may have a different pressing from the one(s) in the database
[CUETools log; Date: 2012-07-26 16:24:36; Version: 2.1.4]
[CTDB TOCID: DwtY6tAwK7mGqaYUYZP4ZMrjXwg-] found.
Track | CTDB Status
1 | (10/10) Accurately ripped
2 | (10/10) Accurately ripped
3 | (10/10) Accurately ripped
4 | (10/10) Accurately ripped
5 | (10/10) Accurately ripped
6 | (10/10) Accurately ripped
7 | (10/10) Accurately ripped
8 | (10/10) Differs in 12689 samples @08:54:07-08:54:08,08:54:26,08:54:45-08:54:46,08:54:62-08:54:65,08:55:07-08:55:09,08:55:26-08:55:29,08:55:46-08:55:48,08:55:64-08:55:68,08:56:08-08:56:12,08:56:26-08:56:32,08:56:45-08:56:50
9 | (10/10) Accurately ripped
[AccurateRip ID: 0014c390-009f272a-7c111d09] found.
Track [ CRC | V2 ] Status
01 [ba48734d|2ca94a8b] (000+000/113) No match
02 [752ad446|23732d47] (000+000/113) No match
03 [34840dde|b2f9ce93] (000+000/113) No match
04 [fb261033|baa1d767] (000+000/113) No match
05 [7da8dcf8|cd0fbded] (000+000/113) No match
06 [f75233af|83751680] (000+000/113) No match
07 [69afe879|ec675883] (000+000/112) No match
08 [30fb5342|a85c8cda] (000+000/111) No match
09 [9e5976d0|0670f43b] (000+000/109) No match
Offsetted by -93:
01 [72757f4c] (008/113) Accurately ripped
02 [746cae70] (008/113) Accurately ripped
03 [8090f0ad] (008/113) Accurately ripped
04 [261eae74] (008/113) Accurately ripped
05 [7de36672] (008/113) Accurately ripped
06 [d2c483f4] (008/113) Accurately ripped
07 [49eabd48] (008/112) Accurately ripped
08 [47a30577] (000/111) No match (V2 was not tested)
09 [de69197b] (007/109) Accurately ripped
Offsetted by -18:
01 [f6b44413] (094/113) Accurately ripped
02 [858a27ca] (094/113) Accurately ripped
03 [433c39c4] (094/113) Accurately ripped
04 [b0e291ed] (094/113) Accurately ripped
05 [f151189c] (094/113) Accurately ripped
06 [beb2a651] (094/113) Accurately ripped
07 [f82ee85f] (093/112) Accurately ripped
08 [0c138644] (000/111) No match (V2 was not tested)
09 [8fdf69f2] (089/109) Accurately ripped
Track Peak [ CRC32 ] [W/O NULL]
-- 95,2 [567CC956] [70613786]
01 88,9 [8D2CBE33] [667AEC5E]
02 88,9 [0875E0F8] [9825DBC0]
03 88,9 [3DCC2EEF] [E31C1AB2]
04 83,9 [7A894994] [250F5EDF]
05 88,9 [C6B555B0] [855956C7]
06 88,9 [50240667] [A142F143]
07 94,2 [01FFC47C] [8B9A6E76]
08 94,3 [7338D5AE] [E3A5BCA3]
09 95,2 [0448CFCC] [4CD6418E]
The CRC is different. What conclusion can be drawn from this?
This post has been edited by db1989: Jul 26 2012, 15:40
Reason for edit: See post #1. And post #6. And post #8. And post #13. Any questions?
greynol
post Jul 26 2012, 16:36
Post #22
QUOTE (gib @ Apr 28 2012, 01:45) *
AR2 is only an algorithm change. It has nothing to do with checking against alternate pressings. In fact, the algorithm change has actually made checking against alternate pressings more difficult.
This post has been edited by greynol: Jul 27 2012, 01:10
DR figures too, of course.
spoon
post Jul 26 2012, 21:30
Post #23
I do not believe this, if the official way of checking pressing is used, not the scatter gun try every offset known to man method...
spoon
post Jul 26 2012, 23:20
Post #24
@tomten_alle
Re-rip in XLD, keep the ripper constant, then we can compare logs (before and after new computer).
greynol
post Jul 27 2012, 15:13
Post #25
QUOTE (spoon @ Jul 26 2012, 13:30) *
I've split this discussion away. It can be found here:
http://www.hydrogenaudio.org/forums/index....showtopic=96226
RSS Lo-Fi Version Time is now: 27th February 2015 - 08:22
